Red and white allignment
The red and white will not allign, not even when i try to adjust the magic focus manually. what do you think the problem is?
  • lo831 Apr 23, 2008
    Hitachi 43FWX20B
    HERE IS MY MODEL NUMBER
  • Anonymous Oct 23, 2008
    Sony Model KP51WS510 I can not adjust the red or blue over the cross pattern
  • 8,617 Answers
You need new convergence Ics. This is a easy repair. let me know your model number of your TV and I will post the Convergence ICs numbers and also post a link where you can get new Ics that come with free installation instructions with pictures and free on line tech support.
Posted on Apr 23, 2008
  • Sonny Berry
    Sonny Berry Apr 23, 2008
    your model uses two STK392-110 convergence ICs They are mounted on a large aluminum heat sink on the extreme right hand side of the chassis. You can get new convergence ICs at the following link with free instructions and tech support. You will need two STK392-110 Convergence ICs. They are usually very busy in the evenings as they have alot of customers so if you can access the site the first time keep trying.
    http://servicemanuals.vstore.ca/
Got new STK392-040 chips and picture is still distorted. Manual convergence still won't alligne all colors.
the 183 is entry into the tech menu===you need to test all the low value resistors around the convergence chips(only 6 or 8) and they will read low and a resistor with NO reading may be your problem.
Also these sets use a pico fuse going to each chip--either right with it or back at the source----know what a pico fuse looks like"
Mar 12, 2012 | Samsung HCM4216W 42" Rear Projection...
The colors are unalligned and the picture is blurry
hello,,the deffective part of your tv probably the convergience ic,it is a 2 pcs big ic with heatsink mounted on the mainboard you can replace it with a new one..or try to adjust first the allignment of your cathodes the RGB cathodes..on your front pannel there is a convergeance manual allignment button use this button to allign the convergeance..on your remote control there is also an allignment command consult your manual for the command .after the adjustment you must save the adjustments before exit the convergeance adjust..if thris adjustment do not work replace the convergeance ic ..mostly the ic is labeled STK XXXX..
GOODLUCK i hope i this helps you..
please rate my help tnx.
May 29, 2010 | Philips 51PW9303 51" Rear Projection...
My hitachi tv's picture is distorted red and green like a 3-d pic
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Feb 08, 2010 | Hitachi 57F710 TV
Will not focus
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 02, 2010 | Hitachi 57F500 57" Rear Projection...
I don't understand how to get the kirby belt on!
it's very easy: take off the nozzle, make sure the green arrows allign, then turn the knob anti clockwise untill the red arrows allign, make sure the belt is on the hook[ look at the back of the nozzle and loock in the hole to see if the belt on the hook. Now and only now you put the nozzle back onto the machine. the you turn the knob clockwise untill the green arrows allign...........
May 14, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I am getting a double image on my 48 inch television how can i get rid of it? it is showing colors green and red on double image
Assuming that your TV is a rear-projection TV, then it sounds like the separate red, green & blue tubes aren't set correctly.
Each tube needs to be alligned exactly to produce the image on the screen. If any of the 3 are mis-alligned then the effect you describe is caused.
Somewhere in the menu settings, will be an option to set the Convergence. This option will allow you to set the allignment of all three tubes.
Older sets do not have this option, and need to be adjusted via controls on the main PCB.
Apr 22, 2009 | Televison & Video
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
Magic focus, #5 Manual
Sounds like a Convergence IC problem, the convergence ics would need to be replaced. This can be done by yourself or a professional.
Jun 06, 2008 | Hitachi 57S500 57" Rear Projection...
Projection red is above other colors
Look in your menu for something called "horizontal static convergence" or just "convergence". Adjusting this will align all three tubes electronically. If physical adjustment is needed, then you have to do this manually inside the Tv. keever
Dec 09, 2007 | Mitsubishi WS-65908 TV
well i think its an circuit prob if theres any circuit break on the pcb panel or panel connector would b loose
Aug 24, 2007 | Akai PT4298HD Rear Projection Television
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
Electro Med Services...
