Question about Maytag Performa LAT2500A
Washer does not stop filling and it overflows!
My Maytag Washer, 4 years old, does not stop filling up with water in any of the cycles. The other day it overflowed and it inundated my basement!
  • ebradt Oct 14, 2008
    I have the same problem. I would like to fix it , but do not know where to start. Can someone help.
    Thanks
  • carmelomonta Nov 25, 2008
    I have the very exact problem. Any help will be great,carmelomontanez@hotmail.com
    Genius:
  • 1,073 Answers
Check the pressure switch tube connectiong to the tub for a hole or crack first
Posted on Apr 23, 2008
Maytag Neptune TL washer overfilling
yes i would agree the water valve is defective as if unplugged it should close,but also sounds like a pressure sensor or pressure hose problem that is also defective too due to the fact that it should at least start the wash cycle even though the water doesn't stop filling,so also it could be the central control unit,pressure switch or pressure hose
May 07, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Water refills when not on
We came home to a flooded basement because it appears the washer filled on its own when we were gone for several days and are in the middle of an investigation about why/how this happened. If anyone has any information on similar malfunctions please let me know. We purchased our machine on 1/22/05.
Sounds like there may be a mechanical problem and Maytag has some explaining to do...
Nov 25, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washer didnt fill when turned on, but filled when holding "reset"
sounds like your water level switch is bad OR the small hose that goes from the waterlevel switch to the bottom of the tank has a hole in it.Try replacing this small hose first.you can go to an auto parts store and match it up.it's usually about 3' long and about 1/4" inside diameter and about 99cents a foot.
Aug 26, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag washer leaking between cycles or if stopped during fill
lift the top up on the washer and see if the fill hose is crack or broke,hose on right side
Jun 18, 2009 | Whirlpool LSN1000LW Top Load Washer
Older Maytag fills with water, but doesn't run.
I have a 20 year old A512 & replaced only a very few items on it (fill valves, belts & air gap).
I would troubleshoot it & repair myself....can you use a voltmeter & are you comfortable exposing the timer / wiring.
My guess is motor (or timer, but less likely since its dead in all cycles). but you've got to get a solid diagnosis so you can order parts.
I suggest oyu find a guy on Craigslsit to repair..
cheers
Bob
Feb 05, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Washer won't stop filling with water
In yor machine control panel you have A part called a pressure switch or water level switch. that controls the water level and tells the timer to start aggitating .If the part is bad the machine will over fill and keep running the water!!
Sep 01, 2008 | Maytag PAV2300 Top Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Washing Machines Logo
275 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
