Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Unable to get ac compressor to start
Installed a Hunter 44155C Thermostat. Here are my connections:
Green--G, Red--RC, Jumper RC-RH, Yellow--YO, White--WB, Y1 open.
Can you help?
  • 2 more comments
  • MemphisNurse Apr 23, 2008
    Thanks, already tried that
    The manual was no help, nor was the website.
    Still not getting anywhere. I reset the dip switches back to factory specs. May just wind up getting another thermostat. This is a piece of junk. I realize I'm a girl, but gee whiz. This is too complicated. thanks anyway.
    Thanks, but this is a dead end too. I am on my way to Lowe's to get another thermostat.
    No digital.
    Thanks for your help. I appreciate it.
    Genius:
  • 3,422 Answers
HI,
you may get a pdf download of the manual form this site Programmable thermostats at discount prices at hunter-thermostats.com.
they may have the model you require .
Goodluck,
Please don't forget to rate the solution
Posted on Apr 23, 2008
  • 1 more comment
  • Priya darshan Apr 23, 2008
    I have got the perfect link and this will fix your problem:
    Please CLICK HERE
    Please CLICK HERE
    Please don't forget to rate the solution no.2
    Genius:
  • 1,142 Answers
  • 19,396 Answers
The thermostat (I installed myself) is not working. I have no heat. It's a combination heat/ac. I read instructions. I'm thinking maybe I have a wire connected wrong. before I go any further, I'd like to...
Wiring color to Thermostat Depending on what thermostat youhave and existing wires. Typically red and white are for heat and yellow andgreen are for cooling. On base of thermostat there should be initials stampedto identify wires by color. R. W. Y. G. Possible Rc. and Rh if so for most usesyou need to jumper these two together. You may have a blue wire instead ofyellow or green. If so just hook blue to y or g. Hope this helps you. Thanks.
Jan 09, 2011 | Heating & Cooling
I bought a Hunter 44155C programmable thermostat to replace my Carrier non-programmable one. The wiring on the carrier is: W- white wire O- no wire G- green wire R- red wire C- blue wire Y- yellow...
Hello,You need RH/RCjumper together=red wire...C=blue wire...G=green wire...Y=yellow wire...W=white wire...O/B unused for reversing valve for heat pump.Hope that helps. : )
Nov 10, 2010 | Hunter Heating & Cooling
Honeywell RTH230B cooling problems...
I printed out the instructions for your thermostat. It looks like you should have the following.
There should be jumper wire between Rh & Rc
Red wire to Rh or Rc whichever is easier since there is a jumper. This is the hot wire and all the thermostat does is connect to route it to the components needed for heating or cooling.
Blue wire, tape it up and don't use it. There is no spot on this thermostat for it. It is only used on thermostats that are powered by the transformer.
White wire to W. Powers the heat relay
Yellow wire to Y. Powers the cooling contactor
Green wire to G. Powers the indoor fan relay
There is a black jumper on the back of the face plate. Look at section 2.4 Setting J2 Jumper in the installation instructions. Make sure you have it in the right position for what you have. If you don't have them just google them.
Hope this helps.
May 24, 2010 | Honeywell Electronic Programmable...
Not working
"G" terminal is for the fan, typically using a green wire. "C" terminal is the common, basically a ground, typically using a blue wire. Also, leave in the jumper between "RH" and "RC".
May 19, 2010 | Hunter Fan Company 5/1/1 Programmable...
I have a Red, White, Blue and Green wire , need to wire a Hunter B01 MOdel or 44110 Thermostat has the following ports available G, RC, RH (RC & RH Have a jumper between them), Y/O, W/B, Y/1
From what you describe you have a heat only system with no AC. If that is so, then you would wire it as follows.
Red wire = RC (leave the jumper in place)
Green wire = G
White wire = W/B
Blue wire = is unused because the thermostat is battery powered and does not require a common wire.
I reccomend you consider not using the Hunter T-stat. They are so extremely problem prone and unreliable. You will be much better off with a Honeywell or White Rodgers T-stat.
You will also need to program the Hunter T-stat for your system per the instructions.
Oct 04, 2009 | Heating & Cooling
Changing a White-Rodgers 1F56-444 to a Hunter 44155c digital.
The W- terminal is for the HEAT RELAY.
Connect the brown and white wire to the WB terminal which is heat relay of the Hunter thermostat.
Aug 09, 2009 | Hunter Fan Company 5/1/1 Programmable...
Switching old thermostat to Hunter thermostat model 44155c
By describing the wires from your new thermostat and your old one, it sounds like your new thermostat is not compatible with your system. If you have seven wires now, then you more than likely have a heat pump system and you have to get a thermostat that is compatible with this type of system. Then you will have the connections you need.
Jul 11, 2009 | Hunter Fan Company 5/1/1 Programmable...
Need help with wiring on Hunter 44110
There is no real color code for wiring but the standard is red wire to r, yellow wire to y,white wire to w, green wire to g, blue wire to c. since there's no c on your t- stat its probably battery operated, but in your case im betting white wire to w, and blue wire to g.
Mar 08, 2009 | Hunter Fan Company 5/1/1 Programmable...
Thermostat wiring
your best bet and where i would start is to identify where the coulors are conected at the fernace. in the industry we use standard wireing coulors wher green is g for fan and red is rh=switched trans power for heating . rc=switched transformer power for cooling . now normaly there is only one transormer so you would put a jumper from rc to rh and conect the red wire from the furnace to eather of these.jumper installed. the y is your cooling witch is normaly the yellow wire. o on the stat is for a heat pump if you nead to energize reversing valve in cooling mode . w is first stage heating and this can be conected to eather brown or white youll have to check at the furnace to see witch it is . the final wire eather brown or white should be conected to c or 24v common witch you didnt say you see on the thermostat. once again
red to rc and rh
green to g
yellow to y
brown or white to w
brown or white to common or c
please post feadback hope i was of help
Oct 19, 2008 | Heating & Cooling
Hunter 44155c wiring from manual thermostat
I have a manual thermostat with the following wire connections (Y, G, R, O, C, & E) with the respective wires attached (yellow, green, red, orange, blue, white). My 44260 has available G, Rc, Rh, Y/O, W/B, Y1. Which wires should I connect to which terminals on the 44160. Thanks.
Jun 19, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
633 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
