HI,
Just check out these two links:
CLICK HERE
CLICK HERE
Goodluck,
Please don't forget to rate the solution
Try doing the following:
1. Uninstall Adobe Reader thru the Control Panel's Add/Remove Programs.
2. Delete the Adobe directory in the Program Files directory.
3. Restart your computer.
4. Download and reinstall Adobe Reader.
Please let me know if this doesn't work.
Thank you for using Fixya and Good Luck
you tried my solution?
From another guy
Try holding down the left-shift key right after
launching Reader. This disables plugins. If the error goes away, figure
about which plugin is vexing you.
The plug-ins folder is Program Files\Adobe\Acrobat 8.0\Reader\Plug_ins
In
my case after a clean install of Reader 8.1.0 a plugin called
AI2Z_PDFAHOI.api was being added by something. I could not find any
info on google. I found the plugin by looking at plugin creation dates
(not modification) and noticed it had been created after the time of
Reader installation. I removed it and made a folder with the same name
to prevent it from being put back; plugin folders already existed so I
figured another one won't hurt. That worked to quell the error.
were you able to get it working with the newest information that I posted?
Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
otherwise please let me know if you have further questions
Thank you
Give the exact error please
Helpful site
http://kb.adobe.com/selfservice/microsit...
Run windows vista update and after that uninstall adobe reader then reinsall it back and it should work fine.
I have tried this several times and still get the same code ''invalid plugin'' adobe reader 8 will shut down
