Question about Dryers
How to route the belt - Dryers
  • twatty Apr 23, 2008
    trying to place belt guide and spring back into dryer along with belt around tumbler is a simpson maxidry 361
  • 40 Answers
Hi there, I am a dryer repairman of some six years experience.
I used to have this problem also, at the beginning of my work!
Firstly, put the "belt guide" in its correct postion, that is with the 2 metal prongs fitted into the 2 slots on the mounting plate below the motor. If it doesnt stay in place, remove and bend the 2 metal prongs outwards slightly. (belt guide = idler pulley assembly)
Secondly, feed the belt in, through the middle of the metal idler pulley arm, and loop it over the bottom pulley of the motor. Next, pull the belt out to the side, to check that its properly located on the pulley. You can pull the belt to the side with one hand, while feeling with the other, if the belt is neatly on the pulley.
Thirdly, while keeping a little tension always on the belt, slip it over the drum while keeping the idler pulley on the outside (RH side ) of the belt. Now reposition the belt on the idler pulley. While doing this, you are always keeping a little tension on the belt, by pulling out to the side, taking up the slack with left hand. Always keep a little tension on the belt, until spring is in place. Next, you push the belt down into its normal running position on the drum, this can be just approximate for now.
Fourthly, you fit the tensioning spring, between the idler pulley arm, and the hole in the seam of the dryer case. (or if there is a belt-break switch, you put it around that) This is a bit tricky, as you need a strong right hand to stretch the spring. Can use pliers to help, but sometimes makes it harder!
Lastly, after you have done all this and finished, must check that all is firmly in place before closing up the dryer. Rotate the motor pulley by hand, carefully, to see if the belt is running smoothly, not twisted or misaligned. Correct as needed. If there is a loud TWANG, then the idler pulley has come out of its seat, and you begin again from step one, being more careful, checking as you go.
Posted on May 06, 2009
Need belt routing diagram gmc 2500 6.6 duramax
I need a belt routing diagram for an o 06 Duramax with air ps etc
Jun 29, 2011 | 2006 GMC Sierra 2500HD 2WD
Timing belt routing diagrams for cars and trucks? Click the link below:--- http://technoanswers.blogspot.com/2011/10/timing-belt-routing-diagrams-for-cars.html
Drive belt routing diagrams for cars and trucks? Click this link below:--- http://technoanswers.blogspot.com/2011/10/drive-belt-routing-diagrams-for-cars.html
Jun 20, 2011 | 2000 Kia Sportage
Where is the ac compressor located on a 2002 xl7 suzuki above or below the engine
It depends on the engine size for the belt routing.
Click on the "x" for the diagrams on the following engine sizes:
FIRING ORDER AND BELT ROUTING Firing Order and Belt Routing X90, Vitara & Grand Vitara Fig. 1: 1998 1.6L engine Firing order: 1-3-4-2 Distributor rotation: Counterclockwise 79243g34.gif
Fig. 2: 1999-02 1.6L engine Firing order: 1-3-4-2 Distributorless ignition system (coils over No. 2 and 4 cylinders) 93023g03.gif
Fig. 3: 2.0L engine Firing order: 1-3-4-2 Distributorless ignition system (one coil over each cylinder) 93023g05.gif
Fig. 4: Accessory V-belt routing- 1.6L engine with A/C 93024g03.gif
Fig. 5: Accessory V-belt routing-1.6L engine with A/C and P/S 93024g04.gif
Fig. 6: Accessory V-belt routing-1.6L engine with P/S 93024g05.gif
Fig. 7: Accessory serpentine belt routing-1.8L and 2.0L engines 93024g07.gif
Fig. 8: Accessory V-belt routing-1.8L and 2.0L engines 93024g08.gif
Fig. 9: Accessory V-belt routing-2.5L engine with P/S 93024g09.gif
Fig. 10: Accessory V-belt routing-2.5L engine with A/C and P/S 93024g10.gif
Sep 02, 2010 | 2002 Suzuki XL-7
I need a diagram for a installing a serpintine belt in a 2005 toyota tacoma
Depends on engine. Copied below diagrams from AutoZone.com:
Drive Belt Routings
0996b43f80209580.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Accessory drive belt routing-2.4L engine
0996b43f80209581.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Accessory drive belt routing-2.7L (3RZ-FE/M) engine
0996b43f8020209e.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Accessory drive belt routing-2.7L (2TR-FE) engine
0996b43f80209582.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Accessory drive belt routing-3.4L engine
Aug 26, 2010 | 2005 Toyota Tacoma
Serpentine belt diagram/ installation?
Fig. Accessory drive belt routing-4.0L engine
Hope helps (remember rated this).
Jul 13, 2010 | 2005 Toyota Tacoma
Looking for diagram of serpentine belt
0996b43f80208ca1.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Serpentine accessory drive belt routing-3.0L (VIN U) engine
0996b43f80208ca2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Serpentine accessory drive belt routing-3.0L (VIN S) engine
0996b43f80208ca1.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Serpentine accessory drive belt routing-Ford 3.0L (VIN U) engines
0996b43f80208ca2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Serpentine accessory drive belt routing-Ford 3.0L (VIN S) engine
0996b43f80208c9f.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Serpentine accessory drive belt routing-Ford 3.4L SHO engine
0996b43f80208ca0.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Water pump drive belt routing-Ford 3.4L SHO engine
i wasnt sure what engine you had hope this helps good luck
Jan 15, 2010 | 2000 Ford Taurus
Need a diagram on how to refit fan belt
Like a lot of people...you didn't post your engine size....so out of these 11 photos, please choose the correct one for your application:
Accessory drive belt routing—1.8L (AEB/ATW/AWM) engines
Accessory drive belt routing—1.8L (AWP/AWV/AWW) engines 2.0L (AEG/AVH/AZG/BDC) engines without A/C
Accessory drive belt routing—1.9L diesel (ALH) engines without A/C
Accessory drive belt routing—1.9L diesel (ALH) engines with A/C
Accessory drive belt routing—1.8L (AWP/AWV/AWW) engines 2.0L (AEG/AVH/AZG/BDC) engines with A/C
Accessory drive belt routing—2.0L (ABA) engine without A/C
Accessory drive belt routing—2.0L (ABA) engine with A/C
Accessory drive belt routing—2.5L (BGP) engine with A/C
Accessory drive belt routing—2.8L (AFP/BDF) engines
Accessory drive belt routing—2.8L (ATQ) engines
Accessory drive belt routing—4.0L (BDP) engine
Oct 31, 2009 | 2003 Volkswagen Passat
Need diagram of drive belt assembly forcaddy
You didn't list your motor size so please pick the applicable diagram:
Accessory serpentine belt routing—4.8L, 5.3L & 6.0L engines
Accessory serpentine belt routing—5.7L engines with A/C
Accessory serpentine belt routing—5.7L engines without A/C
Accessory serpentine belt routing—6.5L Diesel engines
Accessory serpentine belt routing—7.4L engines
Accessory serpentine belt routing—8.1L engines
Oct 26, 2009 | 2002 Cadillac Escalade Ext
NEED DIAGRAM FOR ROUTING THE SERPENTINE BELT
PLEASE DON'T FORGET TO RATE--You didn't post the size of motor so please pick the applicable one:
Accessory serpentine belt routing—4.8L, 5.3L and 6.0L engines
Accessory serpentine belt routing—4.3L, 5.0L and 5.7L engines without A/C
Accessory serpentine belt routing—4.3L, 5.0L and 5.7L engines with A/C
Oct 22, 2009 | 2004 Chevrolet Express
How do I change the timing belt on a 2003 Tiburon
2003 Hyundai Tiburon 2.7L MFI DOHC 6cyl
Inspection
Inspect the drive belt for signs of glazing or cracking. A glazed belt will be perfectly smooth from slippage, while a good belt will have a slight texture of fabric visible. Cracks will usually start at the inner edge of the belt and run outward. All worn or damaged drive belts should be replaced immediately.
Removal & Installation
  1. Raise and support the vehicle.
  2. Remove the engine splash shield.
  3. Rotate the drive belt tensioner clockwise to release the drive belt tension.
  4. Remove the drive belt from the alternator.
  5. Slowly release the drive belt tensioner.
  6. Remove the drive belt from the accessory drive pulleys.
To install:
  1. Install the drive belt to the accessory drive pulley.
  2. Rotate the drive belt tensioner clockwise.
  3. Install the drive belt to the alternator.
  4. Ensure the drive belt is properly aligned and seated into the grooves of the accessory drive pulleys.
  6. Install the engine splash shield.
  7. Lower the vehicle.
Fig. Accessory drive belt routing-3.0L and 3.5L engine
Fig. Accessory drive belt routing-2.5L and 2.7L engines
Fig. Accessory drive belt routing-2.4L engines
Fig. Accessory drive belt routing-2.0L engines
Fig. Accessory drive belt routing-1.5L engine
Fig. Accessory drive belt routing-3.0L engine
Fig. Accessory drive belt routing-2.5L engines
Fig. Accessory drive belt routing-1.8L and 2.0L engines
I hope help you with this (remember rated this help) Good luck.
Sep 15, 2009 | Hyundai Tiburon Cars & Trucks
Dryers Logo
335 people viewed this question
Top Dryers Experts
