The printer well not turn on when all plugs are hooked up...
    Scholar:
  • 41 Answers
Hi ,
if its a dell printer , then disconnected the power brick from the printer and rub the contacts on the power brick using an eraser , wiggle the power cable and try connecting the power brick to a different wall outlet
Posted on Apr 23, 2008
Printer won't turn off
Check the power supply cords; make sure they are attached properly. If you are using a power strip, surge protector or any other device where the power supply cord is not plugged directly into a wall outlet, bypass them and plug the printer into a wall outlet; see if that changes anything.
If that doesn't work, remove the printer's power cord from the outlet and all the other cables that the printer connects to the computer to.
Wait 5 or 10 minutes for the printer's CMOS and RAM chips to power off completely.
After enough time has elapsed, plug only the printer's power cord into the wall outlet (do not hook up any of the communication cables in e.g. USB, or serial cables, or network cables.)
Then press the power "on" button.
If the error message is gone, power off the printer.
Uninstall the printer and all its programs from the computer.
Do a clean install and follow the procedures of hooking up the printer as though you are installing it for the very 1st time.
You may have to obtain firmware and/or software updates from HP on your specific printer.
You may also have to check with your OS vendor to make sure you have all the updates/service packs on your PC or laptop
Nov 23, 2013 | HP Photosmart C7280 Printer
Hooking printer laptop
connect the printer cable to the usb port sir, and plug the power cable to the printer.. then turn it on.. thats all...
Oct 23, 2013 | Canon BJC Office Equipment & Supplies
Dont know how to hook up printer
if by hook up you mean install. then follow these directions plug the printer into power, plug onto your system, power on rhe printer, insert the cd which came with your printer into your cdrom, run the setup and follow the instructions. this should do it
Aug 07, 2010 | Epson Stylus 880 InkJet Color Printer
Was trying to hook up hp printer. when i plugged
HP Printer driver problem. Disconnect Printer and see if the computer boots up properly now.
Mar 09, 2010 | HP Compaq Presario 6320US (DA202A#ABA) PC...
My HP all in one wont turn on since I hooked it up to my new Mac.
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr18
Aug 11, 2009 | HP Officejet 5610 All-In-One InkJet...
I want to hook the printer to my computer
What brand printer? Is it an HP laserjet/inkjet?
If the printer is relatively new, there should be a USB Type B port on the printer. You'll need a USB cable that can connect the printer to the PC.
Once you have the USB cable plugged in, make sure the printer is turned on. If running Windows 2000/XP/Vista the hardware manager should automatically try to install the printer for you.
You can check that the printer installed by going to Start > Control Panel > Printers and Faxes. You should see the printer listed.
Jun 01, 2009 | Lexmark Color JetPrinter 3200 InkJet
My printer is hooked up to my laptop but it will not print.
To save lots of time and effort, I'd uninstall the printer and reinstall it. Be sure you install the software before you plug the printer in, or you'll get a bad installation.
Mar 11, 2009 | HP PhotoSmart C4280 Laser Printer
Lexmark 4200 all-in-one problem
I got my old printer hooked up last night. THANKS!!!!!!
Sep 10, 2008 | Lexmark X4270 All-In-One InkJet Printer
Hp officejet g85 - problem
hi,
unplug the telephone cable from the back of the printer and then turn off th printer.
turn it on after few seconds. check whether you have the error message and if not plug the telephone cable back to the printer.
if it is not working please contact me again.
thank you
agnel
Mar 14, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
49 people viewed this question
jasbo
jasbo
