Question about Acer Aspire 5050-3242 Notebook
Laptop to TV
I have an Acer Aspire 5050, when I connect using the S video I only gewt black and white, while some S video cables I get nothing, then I trid the VGA connection through EZ to TV converter and still nothing. Yes I tried the fn pf5 to video then went through the settings. I've reloaded software. I'm going nut's withthis thing. I'm runnning windows Vista. I need some real help on this one.
  • 2 more comments
  • cbmott1 Apr 23, 2008
    Actually I'm going through RCA's to the TV. The TV doesn't have S video in Just RCA in. The converter I used also sent it through an RCA cable out. The only thing I got form that was colored vertical lines. Others have tried on their TV with the RCA's as well with the same results with their own lap tops. I figured the converter would have worked as it also routed through the Blue monitor out to the RCA's. I tried both video ouot ports on the laptop with different results on both.
    I'm using a s video to rca or the pc to video ez control box. Both send it via rca's or s video. Other people I know have experienced the same problem. I've used both s video to rca and vga to rca both with different symptoms. Yes others have tried on different Tv's.
    I bought the computer less than 3 months ago and have never used these ports. Vga or s video. There has to be some other thing like maybe it only works s video out only. I'll give it a shot and let you all know.
  • cbmott1 Apr 24, 2008
    The test results are in, s video to s video is perfect picture. soloution is not all s video to RCA cables are wired the same. Some had no picture some had black and whie picture, wich brings me to the conclusion that it may require a cable from the manufacture or a home made cable with the pins connected to the positive and negative sides of the cable. It may not even be possible to connect to RCA's with this computer's video card. I hope this helps others in the search for the big picture.
    Scholar:
  • 103 Answers
Have you tried this with more than one TV? It may be possible that the TV or the laptop have a faulty S-video port.
Posted on Apr 23, 2008
  • Richard Wilbur Apr 23, 2008
    If others are experiencing the same issue, at least one of them must have found a solution by now. If they havent, at least your manufacturer should have something by now. It still sounds hardware related to me, but I would contact Acer to find a resolution. They may be aware of something that I cant locate online.
  • Richard Wilbur Apr 25, 2008
    Thats very interesting to know. Thank you for updating us!
How to connect acer aspire 5315 to LG led tv
Acer Aspire 5315 doesn't come with an HDMI port. So, you have the following options:
1. Use a VGA Cable to connect the PC to TV if the TV has PC-Input facility
2. Use an S-Video cable to the TV's S-Video-in port if the TV has it
3. Use and S-Video to HDMI converter if the TV has HDMI port
(http://www.amazon.com/Composite-S-video-Audio-HDMI-Converter/dp/B003NS0UUQ)
for audio, you can use 3.5mm to RCA (Red/White) connector to connect to TV's audio-in port.
Apr 15, 2013 | Acer Aspire 3680 Laptop
Tip
Acer aspire 5050 Battery
Acer aspire 5050 laptop batteries
  • Chemistry :Li-ion
  • Voltage : 11.1V
  • Capacity :4400mAh
  • Color : Black
  • Condition : Brand New
  • Availability : In Stock
  • List Price : £ 55.82
  • Now Price : £ 40.82
  • Acer aspire 5050 Battery Description
    We focus on bringing you the best replacement Acer aspire 5050 battery to our customers and hope that our customers can buy their satisfying Acer batteries, the Li-ion laptop battery on sales will be the perfect replacement to your original Notebooks. We guarantee the Acer aspire 5050 battery with a full one-year warranty from the date of purchase, 30-days money back, if the battery(s) have any quality problem! If you have any question or suggestion about this Acer aspire 5050 Battery,Please contact us
    There are several steps you can take to help you get maximum performance from your Laptop Battery:
    Prevent the Memory Effect - Keep the Laptop Battery healthy by fully charging and then fully discharging it at least once every two to three weeks. Exceptions to the rule are Li-ion batteries which do not suffer from the memory effect.
    Keep the Acer Laptop Battery Clean - It's a good idea to clean dirty battery contacts with a cotton swab and alcohol. This helps maintain a good connection between the battery and the portable device.
    Exercise the Battery - Do not leave the battery dormant for long periods of time. We recommend using the battery at least once every two to three weeks. If a Laptop Battery has not been used for a long period of time, perform the new battery break in procedure described above.
    Battery Storage - If you don't plan on using the Laptop Battery for a month or more, store it in a clean, dry, cool place away from heat and metal objects. Ni-Cd, Ni-MH and Li-ion batteries will self-discharge during storage; remember to recharge the batteries before use.
    on Mar 26, 2010 | Audio Players & Recorders
    The white screen just suddenly appearsin mya acer laptop, what shall i do?
    To determine if the LCD screen is faulty or the video card.
    Connect an external monitor to the laptop's external video port. Power up the external monitor first and then the laptop. The video will automatically switch to the external monitor and if you see a normal Windows image then the video card is OK and the fault is with the LCD screen,
    If this is the case power down and re-seat the video cable/connector on the laptop. This hopefully will fix your problem.
    Oct 12, 2009 | Acer Aspire 5050-3242 Notebook
    Problem black screen for acer aspire 5050
    Probably the video card. Check in Device manager to ensure the drivers are not corrupt. If they are there will be a yellow, red or black sign next to the video device. Right click, uninstall the driver then reboot. The plug and play will load the correct driver. If that does not work then replacing the video card is needed.
    Rate with 4 diamonds.
    Mar 07, 2009 | Acer Aspire 5050-3242 Notebook
    Acer aspire 4315 connect to TV problem
    you should be able to right click on an empty space on your desktop and choose graphics properties and then the output option should be able to be set and the resolution changed if needed, set your tv for AV3 or s video and connect a seperate audio cable as s video is video only
    Sep 10, 2008 | Acer Aspire 5050-3242 Notebook
    Configuration to display video on TV using Acer Aspire 5052 laptop
    just right click on an empty space on your desktop and you will get the options to clone or extend desktop.
    Oct 09, 2007 | Acer Aspire 5050-3242 Notebook
    Acer Aspire 5050 Notebook series suggested PCMCIA TV Tuner Card
    Hi, Most brand/models will work for your laptop as long as the correct drivers are installed for the laptop's OS (Vista). One thing noticeable is slight heat build-up on most PCM CIA cards. On the other hand external TV via USB connection tend not to heat as much and does not load nor draw power from the laptop since they have their own power adapters. Both however will have a lower video quality compared to cable directly connected to TV connection. There are a number of models from AverMedia which should work straight out. My experience with Leadtek models has also been satisfactory so far. Hope this be of some help to you. Post back should you need additional information. good luck and kind regards.
    Oct 03, 2007 | Panasonic Toughbook 27 Notebook
    Acer Aspire 5050-3242 Notebook Logo
    273 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
