Question about Brother MFC 240C All-In-One InkJet Printer
Phone & fax/copier etc
Hi, If I move my fax machine to a different location. The phone and the fax are the same number. Will the phone "not" work at the old location because it was tied to the fax machine ???
Thank you !
It was the problem of the Local Phone Company. It did not have anything to do with the Printer/fax/copier.
Thanks
Posted on Apr 24, 2008
My fax machine MX532 won't let me send a fax though the machine
This is probably an issue for the receiving fax. Try this:
1. Find a piece of paper and write fairly large:
Call me if you get this
Your name
Your phone number
2. Send this to a different fax machine at a different company and location. If it works, then attempt to send it to the same fax you initially attempted.
- If it works then your document may be too large and you will have to send it over a couple pages (or less at a time).
- If it doesn't work then there is a compatibility issue with either your or the receiving end fax machine. You will have to find an alternative fax number to a different model fax machine. Don't expect the company on the other end to just change out their fax machine but they may have another model at a different phone number.
Another alternative - you can attempt to scan your documents and send them by email but check with your and the receiving destination security departments.
Best wishes,
Joe
Aug 25, 2016 | Canon PIXMA MX532 Wireless All-in-One...
Hi there, someone has sent us hundreds of faxes that have crashed our fax machine. Is there a way to clear the "receiving" que and block incoming faxes from that sender. We cannot send or...
Hello Ihall,
Wow, That sux , and I mean it.Fax "spam" is difficult to deal with, and has been an increasing problem.Typically tho, its just an AMWAY fax or a free trip to Panama, discount tanning bed etc... . This is a fax bomb and someone is actually breaking federal law BIG TIME. They have (for whatever reason) dedicated significant resources on their end to do this. There are major hurdles and differences between NETWORK traffic, where you can select the IP addresses that you wish to allow or exclude, and phone traffic.It's just like if someone decided to hit redial aimed at your personal phone.Fax traffic cannot really be tracked at the end user level other that running an activity report, establishing that a specific number is harassing you and calling the phone company or whomever provides your phone service.Then you have to file a complaint thru this provider who will contact the FCC.The copier/ fax only knows to accept the incoming call. Lets look at it this way.If it was your home phone you could pay for services that could block a certain phone number perhaps but I bet your fax line does not have caller ID, call block, etc.If I were you I would disconnect the phone line from the copier briefly. Then locate the system monitor block at the bottom of your display and press it. Locate the fax tab at the top and press it.Select print list and it will tell you all the activity both incoming and outgoing, with phone numbers ,times etc. Determine the number that is wearing you out and call your phone provider.They won't think this is funny especially as you will have a report that lists all the activity. Again this is a federal crime and they will actually send Marshall's to the location, rip out their communication **** and possibly arrest them on the spot.I hope I have made sense here as I am livid that someone would do this. Now since you have already indicated that you know how to delete these faxes, and it has taken you hours, You should ACTUALLY be able to highlight as many "**** faxes" as you wish as you go down the screen, and just check them off and at the end say "delete". I guess my bottom line is, No the device does not have the capability on its own to differentiate phone numbers. You need to get law enforcement involved. And you should be able to get rid of those faxes in mass. This is truly jeopardizing your device and your business as it is tieing up memory and processing capabilities and can bring the device to a screeching halt. I hope I have helped you, I am sure that the fundamentals I have explained are accurate. I wish you the best. If I helped you, please let "FIXYA" know. Good luck. I hope they cook the turd, I have been thru similar ****. Spinal
Feb 02, 2011 | Canon ImageRunner 3025 Black and White...
You might have to do a system reset for your printer. To do this:
1) Unplug power cord.
2) Press hold button "6" and "#".
3) while holding buttons 6 and #, return the power cord, then release buttons.
You may now setup your faxing using the new number you have.
Hope this helps. Thanks for using Fixya.
Jan 13, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
When I dial a number to fax to the number just rings and rings and I can never send the fax. This has happened with several different numbers. At my home, where the fax is located, I do not have a separate...
To test it try faxing a test sheet to a known good # using "hook" you will be able to hear the prosses, if the rx unit picks up hit start button and it should go, this tests the line modem etc.
-Carl, please let me know if this helps.
Jun 26, 2009 | HP OfficeJet D145xi All-In-One InkJet...
Need to set up phone/fax instead of just fax
I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time.  I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.  It worked for me. Hope this works for you too.
Apr 24, 2009 | Brother MFC-260C All-In-One InkJet Printer
Not able to send or receive faxes...trying for 2 weeks, HELP! :)
set it to fax only, then call your machine from a different phone line, if it answers then you are working, if not you then have a telephone line problem. please repost & I can advise further.
Apr 18, 2009 | Canon Office Equipment & Supplies
How do I change my fax number?
I found you manual to download right HERE:
- as I´m informed, you don’t need to change you FAX number, as your fax machine will receive any call on the number you connect the machine to.
5757e4d.pngdo vote, if this helped you.
regards
/Teis
Jan 16, 2009 | Brother Multi-Function Center MFC-240C...
Hi, Remote Fax Error being displayed
What happens if you dial the remote fax number as a voice call on another phone? Does that number pick up? Does it give you the modem handshake noise? If not, the remote side has a problem.
Can you fax other numbers? What happens when you dial your own fax line from another phone? If your fax does not pick up and talk to you, your fax may have a problem.
Jul 24, 2008 | Dell 962 Photo All-In-One InkJet Printer
Move to a different phoneline
You need to change the phone number in the settings menu to reflect the new location. Erase the old, enter the new. Dont forget the area code, if different.
Jun 10, 2008 | Muratec F320 Plain Paper LED Fax
Fax ring tone or ring leader
im sorry to say the machine you have does not have DRD distinctive ring detect.
Jan 21, 2007 | Panasonic Workio DP-2330 Printer
Brother MFC 240C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
