Please go to below website you can get the codes to programme out remote.
http://www.urc.philips.com/
Please follow the below instruction.
1.Location
2.Select your remote
3.On your left side you will have an option called as REMOTE CONTROL CODE FINDER.
4.Select the device you need to programme and the make of the device you will get the codes.
Thanx
SOURCE: universal remote codes for a philips remote
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. -You can rate this solution with one of
four votes, if you feel your issue is resolved (remember that at times a bit of
to and fro dialogue may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
SOURCE: philips universal remote codes for zenith t.v.
If
yourbrand is not listed, and you are still not able to get the unit to
respond, trythe following procedure to search for your code.
If
youreach the end of all the codes for this device type.
Make sure
that the remote is pointed at your device during the search, You may
Line up your original remote and the head-to-head before completing thefollowing steps.
Now
keysor press and hold SETUP until the Cinema's red light flashes twice
to lock inyour new feature. (If the red light does not blink twice,
stop and repeat stepsthrough 6).
release the device key in which the newfeature was learned followed by
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): We could not find an exact match, we think this code will work. 10054 Setup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
SOURCE: need code to program philips universal remote
most philips universal remotes have the "code search" option this is done by:
1: Manually turn on ur tv
2:hold setup untill red
indicator stays on and release button
3: press and quickly release what
you wanna program (i.e tv,vcr,ect.)
4:press channel up repeatedly
untill your t.v changes channels(up to 300 times) if you over shoot the
channel change press down til it changes again.
5: press and release
MUTE to install the code.
SOURCE: i have a philips universal remote code-cl043 and
I just move and lost my code sheet for my phillips universal control is there some where i can get some codes,i have a emmerson television thanks.
