Question about Microsoft Windows XP Home Edition
All External storage devices "USB Device Not Recognized"
Windows XP - After using an intermittent USB extension cord with a flash drive, when I connect any external storage device driectly to a USB port I get "USB Device not recognized" "One of the USB devices attached to this computer has malfunctioned." In Device Manager under USB it shows an unknown device. External hard drive does not show up in disk drives in device manager. I tried uninstalling all USB items in Dev Mgr, they reinstall but still get same message for flash and ext hard drive. Other devices work fine in the same USB ports. I tried System Restore. No luck. HELP!! Thanks!
    Habit-Forming:
  • 23 Answers
Dear Sir,madam
You have to do some steps about fixing this problem :
1: Go to Device manager by right click on my computer then manage and then device manager.
2: Go to universal serial bus controller and export it.
3: in each USB root hub right click and then properties.
4: In properties screen select power management tab and unmark on " allow the computer to turn off this device to save power ".
5: After finishing this steps in each USB root hun restart your computer and then done
Posted on Jul 24, 2010
SOURCE:
Zippysltd com
*Change USB ports, the one you use may be bad.
*Use a different USB connector cable, yours may be bad.
*Try it on someone else's computer; does it work?
*Control Panel >Device Manager: is it listed?
*Enter BIOS >Storage Devices (usually the 1st screen): listed there?
*Control >Administrative Tools >Disk Management: listed there?
*If answer is "no" to all questions above, the ext. drive failed.
Jun 09, 2013 | Zippy Computers & Internet
Smartdisk Firelite model usbflb80 is not recognized on my laptop
A USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Or even get a usb 3 lead. USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Sometimes they become faulty due to overstretching age or heavy objects sitting on top of them. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. Windows 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error. This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition. Now I have seen cases where Malware can break the link of a Hard Drive. So let's try a couple of steps. Let's go back in to "Disk Management" Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths" Now try selecting a new Drive Letter. This will restore the path if it has been broken. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Jan 24, 2013 | Computers & Internet
My Windows 7 cannot recognize my Sata/usb connector
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
b>
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
Not recognice by usb hard
Hope this helps
Nov 07, 2012 | Computers & Internet
I'm trying to sync an apple ipod shuffle 4th generation to my windows xp pc. The famous USB device not recognized thing pops up. What do i need to do so i can use and sync my ipod.
Shutdown Windows.
Turn the computer off.
Unplug the AC power cord.
Reconnect the AC power cord.
Restart the PC.
This will eliminate many "intermittent" problems.
Now, connect some other USB device (mouse? keyboard? memory-stick?) into the USB port, to confirm that the USB port is working, at least for some USB device.
Now, connect the iPod to one of the USB ports.
If it is not recognized, connect the iPod to a different USB port.
This should work.
Jun 01, 2011 | Computers & Internet
Not recognized in "my computer" when plugged in
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Nov 17, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
Hi, im having problem with my windows usb it cannot be detected by my windows xp.. in the device manager the mass storage device is marked (x) on it. what would i do to make this functional on my...
First of all try changing the usb port you are using I am sure that there will be more than one usb ports in your PC. After this try using another similar USB device.
I mean if you are trying to plug in a Flash drive use a different one or If you are trying to connect an external Hard Disk (as it is obvious from the mass storage device marked with an x as you have pointed out). Try using a different External Hard Disk that you may borrow from someone checks will help you locate the problem. The reason why your USB device is not being detected by your PC must be the driver of the USB drive is out dated. Check the version of the USB Is it 2.0? or the driver might have been corrupt.
You can download USB Mass storage driver from the following site. You can search for USB drivers on other sites also.
http://download.cnet.com/windows/usb-drivers/
Best of Luck!
Jul 31, 2010 | Microsoft Windows XP Professional for PC
HOW TO USE PENDRIVE AS RAM IN WINDOWSXP
You cannot use a pendrive as RAM in a computer or laptop, but you can use the pendrive as an external USB storage drive/device.
Jun 05, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
DRIVER FOR EASYDISK USB FLASH DRIVE WHICH WORKS ON WINDOWS 98 BUT I WANT THE SAME TO BE ACCESSED BY WINDOWS XP TO HELP ME ACCESS DATA STORED THEREIN. THIS IS A 16 MB FLASH DRIVE MANUFACTURED BY SHENZEN...
you do not need a driver for windows xp - the flash drive should be recognized automatically.
the driver and utilities can be found here http://www.easydiskusa.com/eddrivers.php
Mar 22, 2009 | Lexar JumpDrive Classic Portable USB Data...
Can not access my hard disk
It would be a good idea to run a anti spyware and anti virus to check the drive.
Thanks
Aug 22, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
249 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
