Noise when agitating
Washer started making horrible sound when agitating. There is no noise when spinning. I opened the front panel and noticed that the black rubber piece that used to be on the panel (to act as a buffer between tub and panel?) was missing. I located it at the bottom of the washer. Who knows what damage this might have done. Removing the rubber piece did not solve problem. I can't see anything that looks odd. Any ideas?
  • Marian4620 Apr 24, 2008
    It is a Maytag. Sorry I didn't mention that earlier.
  • 240 Answers
If it is whirlpool then skid plate could be out of place. Ge has a total different suspension system. black rubber could be the strap that restricts movement - 4 that attach from frame to tub ring.
Posted on Apr 23, 2008
Makes a horrible noise when spinning
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 11, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Washer is making a horrible sound while draining water from tub
if horrible sound is while drainpump is draining but before washer starts to spin either obstruction in drain pump or impellar on pump is bad and the complete pump needs replaced... if noise is while spinning the spider support is cracked which is very exstensive repair and dont reccomend repairing unless you have a couple of hours for dissasembley and reassembley...
Jan 24, 2011 | Samsung WF337AA Front Load Washer
Washing machine makes a horrible noise in spin cycle and turns itself off. When we hold the Start and Cancel button together we get code E23.
Washer Problems Washer noise when spinning
heatman101
Sep 04, 2010 | Frigidaire Affinity ATF6000F Front Load...
Amana washing machine makes loud noice when trying to spin
sounds like you are dealing with the same problem as me .
take off the front panel (after unplugging power) take a flash lite and look at the large pulley at the back just below the pulley is the helix check to see if they are worn .
http://fixitnow.com/wp/2008/10/21/amana-washer-makes-loud-ratcheting-noise-during-spin-but-doesnt-actually-spin/
Feb 26, 2010 | Amana NAV3330AW Top Load Washer
Loud noise
it sounds like you have something stuck under the agitator thats causing a rubbing noise when it goes to spin or agitate.maybe a penny or something like that
Dec 28, 2008 | Frigidaire GLTF2940ES Front Load Washer
Thumping/knocking/rattles during wash agitation cycle
Mine is doing the same thing. I opened it up to see what was happening and it was the drive belt tension arm bumping around. Soon, the belt started slipping during the spin cycle. Now it won't spin and the belt starts to smolder from the friction of the drive motor. If you haven't checked your belt, that's a good place to start.
Jun 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
How do you open up a ge wwwse3160aoww washer. the wash agitates fine but makes a lot of noise when it try to go to the spin cycle. it makes a bagging noise and spins slowly
Slip a putty knife or other thin object between the top and front panels a couple inches from each side. You should see the clip release from the top panel. Pull the front panel down from the top
Jan 05, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
151 people viewed this question
Top Washing Machines Experts
