Question about DeLonghi EC140 Espresso Machine
Steamer My steamer just stopped working. I hadn't used it in a while, and I took out the water tank. I'm wondering if both tubes are supposed to be in the water? Or did the steamer just stop working? Please help!
    Problem Solver:
Both tubes must be in the water. If you haven't used the machine for awhile, fill the water canister, turn the espresso maker on and also turn on the delivery switch (the top switch on the EC140). You'll hear the pump and in a second or two water will begin to exit the boiler nozzle. Immediately turn the delivery switch off. Wait for the "OK" light to come on. Press the "Steam" switch (the middle switch on the EC140, place an empty cup under the frother and turn the steam control knob on top in the counterclockwise direction. Steam will come from the frother. Be very careful to avoid contact with this steam.
Posted on Apr 28, 2008
Delonghi stiromeglio master steamer iron , why no steam to the iron?
If you have been using tap water it may be plugged up with minerals.
Sep 13, 2014 | Coffee Makers & Espresso Machines
Oreck vacum steamer stopped steaming
Probable failure of the steam generator
Jun 03, 2014 | Oreck steam-it Stick Vacuum
Mr Coffee Pump Espresso machine not working. Lights alternately flash between coffee and steam icons, machine makes noise, but coffee does not brew, water does not flow, steam does not come out.
The espresso portion may be clogged with hard water deposits, and the steamer tube with casein. Run a tank of plain white vinegar a couple of times then run a couple of tanks of plain water to flush the vinegar, Open the steam valve while the espresso portion is running and set the steamer pot under the steamer. Don't be surprised if a long white tube of hard white material slides out of the steamer valve. That's the casein, actually a form of organic plastic.
Sep 27, 2013 | Mr. Coffee Coffee Makers & Espresso...
Steamer has quit steaming. I have not used distilled water (didn't know I was suppose to. It seams to be stopped up.
Any device that actually makes steam should use distilled water. You are boiling away the water to make steam. Everything in the water that is not water will remain in your 'boiler'. So, what to do now ... treat it with vinegar. Vinegar should disolve the minerals left in your boiler.
Thanks for your question @
Sep 13, 2011 | Dirt Devil Easy Steamer Upright Wet/Dry...
Steamer not working at all. water tank / electrical outlet all check ok/plugged in and not doing anything
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
Oct 24, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
After pressing the 'coffee' button, a lot of noise but no coffee!!
this happens to me when i get air in the line that pulls the water out of the tank (i.e. you forgot to fill it up every now and then). you fill up the tank, wash you hands really well (don't want soap or germ in tank), partially put tank into machine and submerge the tube. then with your index finger flick the screen covered tip until no more air comes out. then, push the tank all the way back with the tube submerging all the way to the bottom. turn machine, push steamer butten, and turn knob to turn on steam for a few minutes to remove any remaining air in the tube. then, turn off machine, unpush the steamer (takes too long if machine on and unpush it for the espresso icon to light up so i just shut it off to reset it), turn on machine, wait for espresso icon to turn on, and then press button. voila. problem solved. i find the finger flicking step key b/c takes forever to purge a line full of air just using the steamer step.
May 29, 2010 | Saeco VIA Venezia
I had exact same problemeven took entire machine apart - all fine. Solution is very simple... descale with Gaggi descaler solution. Remove filter and block, mix solution with 1.5L of water, turn on for 20 seconds, wait 20 rinse through steamer, wait 3 minutes and repeat until all solution used - rinse compeletly with clean water
Jan 19, 2009 | Gaggia Baby Espresso Machine
IS8100 Commercial Steamer is leaking water
Try "cleaning it" with vinegar. It could be clogged with calcium carbonate. Replace the water with a potent solution of white vinegar and water and operate the unit until the vinegar solution is used up. I use 100% of the supermarket white vinegar and avoid breathing in the "steam." Repeat the procedure once or twice with plain water. If this works, let me know.
Dec 24, 2008 | Rowenta Commercial Garment Steamer - White
Dirt Devil Easy Steamer Deluxe
Follow the plastic extension that runs from the trigger through the length of the handle. This requires more disassembly that at just the trigger. At the end of the plastic extension you will find a triangular-shaped "ramp" that pushes against a "button" plunger that opens the valve that releases solution. When you release the trigger, the triangular ramp retreats and the plunger is supposed to be pushed back out by an internal spring in the valve. This plunger sticks because of accumulated soap from evaporated solution. Try cleaning that valve and plunger by running clean, hot water through the system OR replace the valve. In the future ALWAYS thoroughly flush the system with hot, clean water after using the machine.
Jul 15, 2007 | Dirt Devil Easy Steamer Upright Wet/Dry...
DeLonghi EC140 Espresso Machine Logo
580 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
