Question about Canon PIXMA iP5000 InkJet Photo Printer
Pixma 5000 Canon
I have a Pixma 5000 Canon that suddenly dosn't work right. While it's printing the printhead does more noise as usual and at the end the print isn't straight printed and I have a 5100 error. When I print a cd the tray sometimes blocks itself. Can you help me? Bob
Have replace all cartaages put the blue wont print
Posted on Oct 06, 2008
When I print a glossy photo print, right at the end the printer makes a noise as if its labouring and there are excess ink smudges on the corners of the print. It only happens when printing glossy paper.
i think the problem is with your print head. i have the same problem before. when i put out the print head to check. there's a lot of excess ink. this may be the reason for the ink smudges on the corners of your print. and when you set your printer to photo printing. it is programmed to put larger amount of ink than normal printing. the best way is to have your printer checked by your service center or change your printhead to a new one. goodluck!
Apr 19, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Poor color quality (Canon Pixma pro 9500)
recalibrate the printhead, clean the printhead. In the printer driver you need to select the right paper.
Jun 09, 2010 | Canon PIXMA Pro 9500 InkJet Photo Printer
Canon Pixma MX700:one print cartridge not working
The cartridge is only a tank that holds ink. The printhead is the device that you put it into and probably has a blockage in the magenta head. Open the machine so the carriage moves to the center. remove all the cartridges.
TCT How to remove and clean Canon Printhead see the link below. The MX700 may have the locking mechanism at the front of the carriage, so you should move it slightly right and then pull the colour bar forward to release the printhead. carefully remove the printhead. Sit it in a shallow dish/tray of hot water for a few minutes and dry with a paper towel. Put it back in the printer reset the locking bar and cartridges. Try a nozzle check through the tools menu. Yoyu may need to repeat the process if the magenta printhead is badly blocked
Feb 13, 2018 | Canon PIXMA MX700 All-In-One InkJet...
Hello, My Canon MP830 suddenly shut off when I told it to print a sheet. It will not turn on, and the print head is stuck to the right, and I can't move it. I left it unplugged for several days, but still...
When the carriage is stuck on the right there's not much you can do, When the printhead goes bad it keeps your printer from powering up. You need to either remove the printhead, or unplug the light color ribbon cables from the circuit board on the right side of the machine inorder to power up, and then change the printhead. QY6-0061-000 around $60.00
Sep 30, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon pixma mp780 auto feed does not print
You probably need a new printhead, but that problem cann also be caused by the purge or cleaning station not working properly. If you do a cleaning cycle with no carts. and the little pads in the printhead come back with no ink on them then the purge is working and you need a new printhead.
Aug 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My prints have white horizontal lines, i don't have a manual
You may end up replacing the printhead as well; this, as with most inkjets, don't tolerate longer stand times without printing, the ink solidifies in the tiny jets and 'cleaning' doesn't help.
If you are adventurous and have too little to do, you can try cleaning the printhead using the detailed instructions found here:
Canon Printhead Rescue
I tried it, without success, gaining only little improvement in print quality and after buying two heads purportedly for my 4000 and getting 'Wrong printhead' emssages with both, I did my own research and found that the printheads first bought were in fact NOT for the 4000. I even tried an ultrasonic bath of some power without success. Ordering the right printhead (QY6-0049-00) which I found new on eBay solved the problem.
Feb 03, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon pixma ip3000inkjet printer
The printhead is clogged.
See the following guide:
Canon iP3000/4000/5000 Printhead Cleaning Guide
If it does not work, replace the printhead: Genuine Canon Print Heads
Nov 25, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma MP780
I simply want to set the printer to print confirmations and also to know the code to print a confirmation report at days end.
Apr 04, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Won't print black, won't clean
You should consider that NOT PRINTING a long time (30 days) with a printer can lead to ink drying out in the printhead, clogging the nozzles. If you have some tehnical skills, you can remove the cartridge and desassembly the printhead (where the cartridges are in) and do the following:
Put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the printhead with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridges back on the printhead (without installing it in the printer), rap it in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles.
Get the cartridges again out of the printhead, install it in the printer, then install the cartridges again and run a few cleaning processes from the printers maintenance software.
It should work if it's just a clogging of black nozzles.. If you dont have the tehnicall skills needed, Canon gotcha, or you can visit a local specialist to make all this for you, they usualy have better equipmens, as ultrasonic cleaners and special solvents that makes all this easyer.
If it doesn't work after that, then the printhead is dead, and here Canon tertminated you because a printhead is more expensive as the whole printer.
So kiss your printer good bye and get a new one, but at least this time get one that uses cartridges with printhead ON THE CARTRIDGE (like HP and Lexmark) or, if you are in love with Canon, take one that uses the cartridges PGI-5 for black and CLI-8 for color, they also have sepparate printhead from cartridge but it seams they are more durable. And easy to refill, as well!
Hope it helped you in any way!
Rate this solution please. Thx.
Jan 19, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Canon Pixma MP780 Printer - black 3e fails to print
installed a new Print-Head, but that was no changes. I use refill ink, and it seams the BlackInkTank is not exactly on the Printhead and it is Air in the Pipe, i take the Printhead and the Ink-Cardridge in the Bathroom, and press the Ink-cardrige on the Printhead and take a hard breath and blow in the Air-Holes of the Ink-Cardrige until black ink come out of the Printhead, reinstall in the Printer, end it works well.
sorry about my bad english
Jan 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA iP5000 InkJet Photo Printer Logo
385 people viewed this question
old marine
old marine
