Question about RCA D61W20 61" Rear Projection Television
Tv will not fully power on
Use the remote or manually turn on tv, but tv will not fully turn on and stay on. No sound.
  • blackoaks1 Apr 30, 2008
    TV will not turn on. Green light comes on, then blinks off, then on, then off. Tv does not power up.
  • ALBERT GARCIA
    ALBERT GARCIA May 11, 2010
    does the red light goes on and off ?? need to know this for further assistance
    Genius:
  • 2,920 Answers
Bad power supply
Posted on Sep 03, 2008
Sony bravia screen just stays on black and wont go to picture.
It sounds like a main board failure but could be a power supply issue as well. The set will need to be diagnosed
Oct 01, 2012 | Sony Bravia Kdl - 60Ex700 60 inch 1080P...
Cannot program dvd player. unit does not fully answer commands from remote.
To program the DVD player's remote control to operate your TV, follow these steps:
  1. Turn on the TV, and then aim the DVD player’s remote control at the TV.
  2. Press and hold the [TV Power] button on the DVD player's remote control.
  3. While holding the [TV Power] button, use the number buttons on the remote to enter the two digit code assigned to your brand of TV.
Note 1: If your DVD player's remote control can be programmed to operate a TV, the TV brand codes will be listed in your owner's manual. If you don't have your owner's manual available, click here to go to the download center and download a copy.
Note 2: Many TV brands have more than one code. If the first code does not work, try the next available code.
  1. If the TV turns off, the code worked correctly and your remote control is now programmed. If the TV stays on, repeat steps 1 through 3 with a different code listed for your brand of TV.
Note: If none of the codes listed allows your DVD player's remote to control your TV, then the remote is not compatible with your specific model.
Let us know if you want something more else please accept the suggestion.
Thank You for contacting Fixya.com
Jun 11, 2010 | Audio Players & Recorders
New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Jun 01, 2009 | Sylvania LC320SS8 32 in. LCD Television
TV cycles on and off but never fully turns on
Tv POwers on shows a picture then picture goes and audio stays on
Apr 14, 2009 | Philips 43PP9202 43" Rear Projection...
42mf231d/17 fails to turn off manually or w/ remote.
there's no signal comes to you tv that why the screen is blue, the problem of your tv is the tuner, so check the the requirment of the tuner to determen if its good or not.
Sep 17, 2008 | Philips Magnavox 27MS343S 27" TV
Ge 94948 universal remote instrutios for progaming t.v.
Hiya this is how i got mine to work.Manually turn on the tv.
Press and hold setup on your remote till the light comes on and stays on.
Then press the tv button then release. The light will flash then continue to stay on.
Now press and release the power button waiting 2 seconds before you press it again until your tv switches off.. you may have to press it for awhile.
Once your tv cuts off press the mute button and now your remote is set for your tv.
Feb 19, 2008 | GE RM24948 Remote Control
JVC AV-27530 27"
WHEN YOU TURN THE SET OFF,SOUND LEAVES BUT PICTURE STAYS ON--SOUNDS LIKE THE MAIN POWER RELAY IS STUCK-NEEDS TECH TO REPLACE BUT SHOULD BE A CHEAP JOB!!
Dec 03, 2007 | JVC AV-27530 27" TV
Need programing guide and codes for a Jensen 6-device Universal Remote (Jer622)
I have this remote...only Pioneer listings are as follows: TV: 1004,1006,1089 VCR/DVR: 2010,2055,2071 DVD: 3312,3311,3287,3286 To program (for example TV setting): Press and hold down TV while entering code i.e. 1-0-0-4 To manually cycle through all codes (example for TV): Press and hold TV while pressing and holding ON/OFF, after 3 seconds the on/off button light should come on and stay on - release all buttons. Turn your TV on and press ON/OFF once each 5 seconds until your TV turns off. When it turns off, you have the correct code - press the stop button. Good luck.
Jan 18, 2007 | Jensen 6-Device Universal Remote Control...
RCA D61W20 61" Rear Projection Television Logo
42 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
