Disk Drive Malfunction
I sent out my laptop for servicing through best buy, and when it came back, the disk drive appeared a little loose and doesn't go all the way back in. And everytime the computer starts working/processing, a loud, violet vibration comes from within the drive leading me to think a tiny part is loose. And when i try to play a CD rom game, the Sims 2, the game freezes within minutes forcing me to restart the computer.
Are there any steps i can take to fix this, or should i just have the Geek Squad take a look at it?
  • 291 Answers
Why won't u send it back to Best Buy to do the right job? Are they going to charge u again? Is the job under warranty? You will have to get someone to go inside the computer to do the right repair if not yourself!!
Posted on Apr 23, 2008
I have a message stating hdd mount failed. Please check hdd connection.
Either your hard drive connection is loose or your drive may have a formatting issue.
You can try a number of things before it needs to be sent for repair.
1. Enter the bios my pressing f10 repetitively as the computer starts up.
From here you will need to find the boot options. In this menu will be the disk drive and hard drive. Select hard drive and hit f10. Then yes to save changes.
2. Unscrew the back of the laptop and find the hard drive. It should have a disk icon on the cover. Remove the cable and insert it again then try the start up.
3. Put in a windows disk and try to reinstall windows.
If you dont see the drive in the bios or at the windows install screen your device will need to be repaired by the manufacturer.
Nov 13, 2014 | Computers & Internet
I dropped my Inspiron 1545 laptop about 2 feet from ground while it was on. At first, when I tried to start it it goes directly to a screen that says software or hardware malfunction and recommends I start...
If you got lucky and the shock only damaged the hard drive, what you need is a formatting and a reinstallation of the OS. If the damage is more extensive than that, say, the soldering on the circuit board was knocked loose, it is probably a cheaper and less painful venture to buy a brand new laptop. The RAM is most likely not the problem here, so there's no need worrying about that.
If you have replaced the hard drive, you need to make sure that an operating system is installed on it. If the hard drive is completely blank, your computer doesn't know what to do because it doesn't have anything to do. Does anything at all on the screen appear on startup? If there's an image saying 'Dell' or something to that effect, you can access the BIOS from there. justkos_0.jpg
All computer motherboards have a built in program called BIOS (basic input/output system) where you can accomplish simple tasks like looking at your machine's statistics and choosing from where to boot from. Typically, to access bios you must immediately hold down a key while the computer boots (usually F2 or F12). Once you are in BIOS, you can have your computer booted off of an operating system disc in the disk drive by selecting the disk to boot from.
If you still have the old HD, I recommend taking it to a professional who can extract all of the documents and files you want, if the old hard drive is indeed damaged. I hope I helped in some way. Good luck!
Jul 19, 2011 | Dell Inspiron 1545 Notebook
I just purchased a StoreJet 2M 320 GB drive. I would like to format it for use with my iMac. The MAC software doesn't seem to have a solution. How do I format the drive?
When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it using a computer with Windows OS. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy. You need to format the flash or external drive. Format thedrive as primary drive and in FAT32. (FAT32 will allow data to be exchangedbetween MACs and PCs also between XP/Vista and earlier versions of Windows).
Jul 06, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
Dell inspiron 1525 can't boot up, keeps on saying hard drive cannot be found. What could be the problem. Tried safe mode and it did not work, tried installing the operating system again without luck,...
please check if you can remove and reinsert the hard drive from its's location. usually you would have to remove 3 or 4 screws on the bottom part of the laptop and slide the hard drive out. once it's out put it back in and make sure that it's tightly on its place.
If this does not work you may have to replace the hard drive because the message means that it cannot detect the hard drive and it might just have to be replaced.
Jun 07, 2011 | Dell Inspiron 1521 Notebook
When i turn my compaq Evo N600c i get this message "1720 SMART hard drive detected imminent failure (failing attr : 05 ) " please help
If you want to save your data, start backing it up now!!!
That hard disk has detected bad sectors or other issues that is causing read, write or read/write failures.
The best thing to do if it's out of warranty is get a new hard disk and clone this drive to that one using a program like Acronis True Image.
Where you get the new hard disk will probably sell external enclosures or a USB adapter cable that you can use to have both hard disks hooked up at the same time to perform the drive cloning, or most computer shops if you are buying the drive from them will provide this service either free or for a modest fee.
Use the drive (meaning the laptop) as little as possible until you get a new drive into it.
Mar 25, 2011 | Computers & Internet
I have an HP pavilion dv6000 laptop and it has been really slow for about a month. It froze up yesterday and I had to cut it off and back on and when i did not it just boots up for a few seconds cuts off...
You could buy a new (bigger? faster RPM?) disk-drive, and remove the old disk-drive.
Install Windows onto the new disk-drive.
Then, buy an adapter (USB connector at one end, and adapter for a disk-drive at the other end).
Connect the old disk-drive to the adapter, and connect it to a USB port on your computer.
Copy all your important stuff from the old disk-drive to the new disk-drive.
All your files will be there, even though the "essential" files that you need to start-up Windows have been corrupted.
Finally, buy an external disk-drive, and use it to create weekly backups of your stuff.
Do NOT delete the files from your disk-drive, to leave the ONLY copy of your files on the external drive.
Nov 26, 2010 | Computers & Internet
The disk-drive has malfunctioned.
Search online for a professional "data recovery service".
For a significant fee, they can repair your disk-drive,
just long-enough to copy your files to a new disk-drive.
If it still has a valid WARRANTY, exercise the warranty to get it repaired/replaced.
If the warranty has expired, then open the case, remove the disk-drive, buy a new "compatible" disk-drive, connect it, and thus "revive" your external storage device.
Oct 23, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My computer won't read disks.
There's only two possiblities either your driver has been corrupted or the drive itself has failed. Try reinstalling the driver, first find or download the driver for your CD drive, when windows tell you it already has the best driver hit back and tell it to install the driver at the location where your driver is at. If this doesn't fix the problem your best fix is to buy a new CD drive, given the current cost of DVD drives this might be a good time to upgrade.
Jul 05, 2010 | Dell Dimension C521 PC Desktop
When switching the machine, it takes long and
1. There is no electrical power to the disk-drive, i.e., a loose cable has become disconnected.
2. There is no data-cable to the disk-drive, i.e., loose cable.
3. The disk-drive's built-in electronics has failed.
4. The disk-drive's motor (that spins the hard-drive) has failed.
5. The read/write "heads" that move over the recording-surface of the disk-drive are "stuck" -- not moving when being commanded to.
6. Those "heads" have scratched a recording-surface, namely the part that contains the "boot" information part of MS Windows.
Those are the problems you could be encountering.
Now, the best "solution" is to take the computer to a qualified technician, for trouble-shooting, which may involve extracting the
disk-drive, and shipping it to a (expensive!) "Data Recovery Service",
who can repair your disk-drive just long enough to copy all your data-files to CD/DVD disks (or to a new disk-drive).
Jan 04, 2010 | E-Machines eMachines M5305DP Notebook
Mini disk downloading
Pls post back the make & model of the "laptop wifi card".
Good luck and kind regards.
Thank you for using FixYa.
May 10, 2008 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
