I have a sharp LCD TV model LC-52D64U that does not power up. When I plug it to the wall outlet, both the power indicator light and the opr light on the front of the unit flash three times and shuts down. What is the cause of the problem and how can I fix it ? Thank you.
  • 1 more comment
  • norrep Apr 25, 2008
    Thank you for your reply.
    Would it be easier to replace the whole power supply unit since I could do it myself?
  • norrep May 05, 2008
    Dear Pagebor, I have replaced the power supply unit and the same problem is still there. I also observed that when I plug the TV to the AC outlet, a relay on the power supply board clikcs and a small red LED near IC 2008 on the main board flashes. I hope this helps you in any way to find the problem.
    Thanks again !
    Luc Perron
  • norrep May 06, 2008
    I have replaced the power supply unit and the problem is still there. Also when I power up the TV, two small red LEDs on the main board flashes, one near the main CPU, and one near IC 2008. Hope this helps you in any way.
    Thanks again.
    Luc
    President:
  • 1,944 Answers
Yes you can replace it by yourself if you know what you are doing.
Posted on May 05, 2008
    Brigadier General:
  • 3,614 Answers
Yes you can replace the whole power supply area which you think having the problem, find the same specs and replaced that broke one..
Thank you & please post back if you need further assistance to this
    Genius:
  • 2,785 Answers
Your powersupply unit is not working properly better you send your tv to servicing.
Posted on Apr 25, 2008
  • Rajkumar Bordoloi
    Rajkumar Bordoloi Apr 26, 2008
    if you can locate the unit and find a replacement then you can do it
Our sharp tv model # LC-42D72U power light flashes green but there is no sound or picture. Looking for your expert opinion on what could be wrong so we can get the part ordered. The board with the power...
Green on light is blinking, but no picture - Television - iFixit
https://www.ifixit.com/.../Green+on+light+is+blinking,+but+no+pict..
iFixitOct 3, 2014 - The Sharp LCD TV LC37SB24U set worked until off button on remote ...The green light is blinking any time power cord is plugged into the wall outlet. ... It does sound like either a bad inverter board or a bad power supply. .... On the clad sidethere is no connections or ribbons that indicate hard current draw ...
Oct 20, 2015 | Sharp LC-42D72U 42 Flat Panel 1080p...
Why wont my sharp lcd LC-32D44U turn on?
Well, there could a be few issues. First thing is to verify the breaker that gives power to that wall has not tripped off in the home's break power panel. If it is not tripped then verify the wall outlet that the TV is plugged into has a reset button, like a GFI (ground fault interrupt) If it does then verify that it has not tripped. If the GFI on the wall plug is tripped simply push the reset button back in and then try plugging in your TV power plug again. Then if that checks out or does not have a GFI outlet, verify that the power plug going into the back of the TV is not loose. Unplug and replug power plug that plugs into the back of the TV in and verify it is securely connected. Lastly, the power supply in the TV might have gone out.
Aug 22, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Connecting cinemate seires II to sharp tv lc 52d64u
Please follow guidelines given in operation manuals of both, step by step.
Aug 06, 2012 | Sharp LC-52D64U 52 in. LCD HDTV
Sharp TV LC37D40U Aquos malfunction. It fails to turn on (no picture, no sound) except that power button light blinks off and on continuously. Any ideas. Thanks.
The blinking light is a indicator of a internal failure, it usually blinks as an error code, I have two suggestions, unplug the TV from the power outlet and let it set for at least 30 minutes not plugged into the wall outlet, then plug it back in and see if it has returned to factory defaults and returned to normal operation, if that didn't work then contact sharp @ 1-800-237-4277 and they will gladly assist you. Good luck !
Nov 30, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
SHARP AQUOS LC-52D64U TV WITH NO POWER
I had one that was doing the same.   swapped out a back light inverter board... fixed it.  this doesn't mean that my fix will be your answer. to help find which one is of the 2 sides is bad..unplug power to the board one side at a time & half the lcd will fire up.  good luck
Feb 26, 2009 | Sharp Aqous LC-26D5U Television
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
