I'm trying to connect my PS3 to a JVC TV (model AV-27F476). I have the standard cable that comes with the PS3 and I think I've tried connecting it to all the different combinations and switched through all the inputs... still no picture or sound.
Any help would be greatly appreciated.
SOURCE: JVC model AV 278p6 standard television
I'll bet you have vertical output IC with some pins not soldered. This IC ( integrated circuit) is a "chip" that makes the picture fill out from top to bottom. After a period of time heat will cause the pins to crack loose on the circuit board. You need to have a tech check it for you. Stargazer
SOURCE: Difference between JVC AV-32F703 and AV-32F704?
the tubues are not the same the 703 is part number A80AJZ90X03 and the 704 is pert number A80ERF042X17
SOURCE: Connection to Dish service
Your t.v is having only RFin , and if you connecting dish receiver , normaly their are two o/p for receiver one is RF and two is for audio out and video out. if your connecting direct RFout to t.v RF in then you have to tune the t.v in all bands. if your receiver do not having RFout facility, then you have to connect AV out to converter and then RFin of t.v. if you having a vcr, then connect AVout of dish receiver to vcr AVin and then vcr RFout to t.v again tune the t.v and pwer on the vcr.
SOURCE: JVC AV-36D502: Input #3 doesn't work
Good day sir, its a different issue, about the capacitor, for as long as your replacement part is correct, it will work, now, there are several things you should check, the I/O device that controls the inputs of the TV, usually an IC, check your schematic diagram to trace the fault. check also the line from the input 3 to the controller IC on your diagram. Measure the voltage across the IC Vcc to ground if the IC is getting the right power, Low voltage can be cause by faulty capacitors, on the power supply line, or the IC itself is faulty, Circuit analysis and voltage measurements are needed to trace the faulty part. hope this helps thanks.
