I just bought you epson stylus cx9400 printer fax series and it was suppose to come with the ink and there was not any in there. I have it all set up and no ink if I take it back to the store I have to undo every thing. They talked me in to buying unk which I did so I put my ink in but I am suppose to get ink with it WHAt can I do can you send me the ink?
    Genius:
  • 1,447 Answers
HI bingoliz,
You are right, you are supposed to get an ink with it. Here's what call Epson technical support and inform them that you didnt get an ink with it. Try to doublecheck the foams in the boxes because sometimes inks are embedded on those foams. if there is none call this number 562-276-4382
Hope this helps
Posted on Apr 23, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 23, 2008
    pls dont forget to rate solution. thanks!!
How to open up an epson 9400fax to clean
Page 16 of the manual shows you how to properly clean your Epson Stylus CX9400.You can view the manual here:
http://www.manualbuddy.com/3570/epson-stylus-cx9400-fax-user-manual
Jan 30, 2013 | Epson Stylus CX9400 Photo Printer
Just purchase and set up Epson Stylus CX9400 Fax Series. States "Cannot recognize ink cartridges." It also has a RED box with a Y and a YELLOW box with a Y both have same number (69) next to them Removed...
Make sure cartridges are part number 69 on all four or 68 on the black if its the high cap cart.
Also check the carts contacts and the machines contacts in the cartridge recetacle for contamination or damage.
Apr 27, 2010 | Epson Stylus CX9400 Photo Printer
I would like to refill Epson Stylus CX9400 old ink
I wouldn't recommend it because it will void your Epson warranty.
Color Ink prints are nice, but this cannot be an everyday printer --- the cartridges will put you in the poor house.
Buy a cheap monochrome laser printer (recommend the Brother brand) and save the purple ink for the elections.
Cheers!
Mar 19, 2010 | Epson Stylus CX9400 Photo Printer
How do I enlarge the print on an Epson Stylus CX9400 fax series?
the printing wizard it has the size choice ...but the actual size its established by the limitations of the printer ..anyway all documents may be re-sized in the computer and than printed...even in pieces and reattached after if the printer supports only A4 paper maximum
Sep 04, 2009 | Epson Stylus CX9400Fax InkJet Photo...
Horrible ink issues..
Unless you are printing a lot in that color, my Epson Stylus photo color R300 uses black at about twice the rate as the color ones. Most packages or ink, I find, also come with two black and one of every color. All my color ones seem to emply at approximately the same time as the others.
Mar 08, 2009 | Epson Stylus CX9400 Photo Printer
Can't send or receive
fax machines are analog devices and will not work reliably on a digital phone line.
Mar 03, 2009 | Epson Stylus CX9400 Photo Printer
New out of box!!
If you already have tried reseating all of the inks and and inks are still not recognized, Please contact Epson tech support for a replacement ink or if they find out after some diagnostics that it is the printer that is having an issue they would be replacing your printer.
Jun 22, 2008 | Epson Stylus CX9400 Photo Printer
Help
no.you need dial tone to send faxes. dsl is for computer use.
wg
Feb 10, 2008 | Epson Stylus CX9400 Photo Printer
Cx9400fax
Epson Quick Guide is incorrect.
Not sure of your exact situation but .........
Your answering machine MUST be connected directly to the output of your CX9400 and you can't use an answering machine with multiple "mailboxes". Set your answering machine to 4 and your CX9400 to 5/6 rings. Epson "Technical Support" has no clue of this problem .... yet.
The machine routes the call to your answering machine, it it's an incoming FAX and the answering machine starts the CX9400 will recognize the incoming transmit signal, turn on the FAX function, and disconnect your answering machine.
You may need to adjust the CX9400 rings setting based upon the duration of your answering machines announce message (longer message = greater number)
Jan 28, 2008 | Epson Stylus CX9400 Photo Printer
jasbo
jasbo
