Question about Sharp Comfort Touch AF-R120EX Air Conditioner
First Time this year Using A/C
It's not cold at all coming out. What can I check?
  • 149 Answers
If you pretty handy get the run capacitor checked probably it shorted out make sure thermostat is set correctly and that it is in cooling mode if you have a remote, just press the snowflake button.
let me know if it helps or if not, e-mail me @
Posted on Apr 23, 2008
I have a 2005 ford escape. when its very cold, my power steering hose comes off and leaks alll the fluid out. This is the 3rd time it has happened. Suggestions?
Change the hose and both hose connections. The hose since it is 6 years old is very soft because of the fluid. Try to get a better quality hose at the parts store. Hope this will work for you and thanks for using FixYa
Jan 24, 2011 | 2005 Ford Escape
Refrigerator won't get cold enough
My fridge is running but not cold enough: Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section . For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermister and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
You can get required parts from
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 27, 2010 | Kenmore Refrigerators
Things are not freezing
the gas is near finish in the system,or check out if the door is close firmly,no leaks
Jul 22, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer does not freeze fast enough, icecream gets soft
Faulty Cold control (Temperature Control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
If the control is not closing, the compressor and all fans will cease to operate. Check the control for continuity.
This is usually not a do it your selfer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 25, 2009 | GE GTS22KBP Top Freezer Refrigerator
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore coldspot
hi thanks for the question i would check the cold control what is happening is that the fridge gets cold enough but because of this bad control it wont send power to the rest of the fridge replace cold control thanks the appliance doc
Sep 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ge nautilus dishwasher
Check inlet valves as if you have 2, it may fill using 2 inlets (hot & cold) but only rinse on using 1 ((cold only). So if the cold inlet is faulty, then you will only notice on the rinse. If thats not it then chances are it is the controller unit. regards
Jul 22, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Sharp Comfort Touch AF-R120EX Air Conditioner Logo
161 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
