Question about ASUS P4S333-VM Motherboard
My asus p4s333-vm won't beep
When i turned on my PC, there's no beep that was heard (POST) and i have tried replacing the memory card, video card, power supply and replacing the battery, clearing CMOS but nothing happens.
Please help me.
Thank you and more power
    Novelist:
    Champion:
  • 236 Answers
You have basically replaced all the parts that could affect your system not to post. that would mean your motherboard is already damaged.
Posted on Apr 24, 2008
  • Redentor Rivera Apr 24, 2008
    ooopss, one thing, have you alwaso tried changing CPU? will you try to remove/re-insert your CPY at least 3 times then try to power up.
Hello sir my computer in motherboard an problem something inside power i diagnose a out put parts like a SMPS & RAM & PROCESSOR & Temperatures & HDD I diagnose Bios I m just start...
When you open up your PC does it have a beep sound continuously.. if it has try this steps make sure you turn off and unplug your pc power chord before doing this 1. check your memory card and graphic card by disconnecting it in your motherboard..after doing it 2. Clean it using pencil eraser the bronze plated part of your video card and memory card you connect to your motherboard rub it with pencil eraser in a single stroke vertically..After doing it connect it again to your motherboard the video card and memory card then turn on again your pc. If the beep stops and this solved your problem good. But if not try to re install your operating system...Hope it will help you..
Jul 11, 2011 | ASUS P5PE-VM Motherboard
I'am working on ASUS P5PE-VM mobo, I removed the memory, video card and isolate the mobo away from the casing so no short circuit may occur during test. I plugged in the power supply and the front switch...
HI,
Clear CMOS or remove CMOS battery, Press the on off switch for 30 seconds.
Now go to BIOS setup,and set bios fail save default,and press F10>enter.If the problem same change the RAM if you have a spare.
http://www.computerhope.com/help/phoenix.htm
Hope it helps.
Jan 13, 2011 | ASUS P5PE-VM Motherboard
I cant find motherboard model in my pc
Google for a program called Speccy - run that and you will get all your details.
Nov 24, 2010 | Intel ASUS P4S333-VM Socket 478 Pentium 4...
Problem with ASUS P5GD1 mobo
Try taken the bios battery out for about 30 secs, replace it and then reboot, after post press F8 untill you have a screen pop up with a safe mode option use the arrows keys to navigate to safe mode and press enter. In safe mode goto my conputer c:drive(boot drive) windows. In the windows folder look for a file called prefetch, delete all it contents. Exit out of everything and restart the pc. If same thing happens post back.
Feb 05, 2010 | ASUS P5GD1-VM Motherboard
P5RD2-VM mobo will not post at boot
Three beeps for that bios is a memory error.Are you sure it's not a memory issue? Did you clear the CMOS and try to boot up again?
Dec 10, 2008 | ASUS P5RD2-VM Motherboard
M2a-vm mother board
Hi auriaskate,
Currently you are using the onboard PCI video adapter. This graphics adapter uses you're system memory to function.
If there is a problem with you're system memory the beeps can lead one to think there is a problem with the onboard video.
You can not remove the onboard adapter so there may be a problem with you're system memory. (I doupt you're memory is bad) but on the other hand it might not be fully installed correctely. Power off the PC & unplug the power cord from the PC.
Please remove you're system memory & firmly reseat it.
Plug the power cord back in. Start the PC & listen for any beeps except the 1 normal beep known as P.O.S.T = Power on self test. Any beeps after that there is a problem with a device connected to the board.
You're Asus M2A-VM uses an Award bios. Click on the link below to see what Award beeps mean.
http://www.bioscentral.com/beepcodes/awardbeep.htm
Try the memory reseat & check. Let me know if this helped.
Mike
May 03, 2008 | ASUS M2A-VM (0610839149438) Motherboard
ASUS Motherboard A7N266-VM
If you have another video card you can try (you can put an AGP card in there, it will disable the onboard video automatically), take that route first. If you can't, or it occurs with another card, it may be your power supply. It would help to know if your pc beeps when you turn it on, and how many - if any - beeps there are.
Feb 18, 2008 | ASUS NVIDIA nForce Chipset A7N266-VM...
My monitor screen stays black when i turn my pc on help
have heard some beep,eihther long beep or short beep? if you heard a short beep replace your memory and when it is long beep replace your video card but if no beep,there is a problem in your motherboard
Nov 01, 2007 | Fujitsu Siemens Siemens Business Line 19P4...
ASUS P4S333-VM Motherboard Logo
88 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
