HELLO I HAVE 670ZX WITH OLD STYLE VU METERS. EVERYTHING WORKS GREAT EXCEPT THE VU METERS ARE SLOWING TO A STOP ALMOST. THERE IS OUTPUT ON BOTH CHANNELS AND IT SOUNDS GREAT BUT...........METERS ARE FAILING.
  • 88 Answers
Hi, a vu meters is a coil with a magnetic field, if it is slowing to stop, probably the coil is to old and you have to calibrate it (specialist) the best for you: replace the vu meter.
Posted on Apr 23, 2008
Samson xp200
From the Owner's Manual, page 7:
2: Output VU meter - This three-segment bar meter shows the XP200 output
level. For optimum signal-to-noise ratio, set the Volume control (see #6 below)
so that program material is usually at or around 0 VU, with occasional but not
steady excursions to the red "+3 dB" segment.
http://www.samsontech.com/site_media/legacy_docs/ExPro_OM_4L_B_V4_1.pdf
Jan 03, 2014 | Audio Players & Recorders
I have an Olds Cutlass, the heater fan will not work on high, it will work on everything except high. Please tell me what is the fix for this problem. Thanks
Unfortunately, you will need to replace the heater fan to correct this problem.
BUT just to be sure, I would put a meter on the switch output and make sure that you have voltage on it. If you do, then it is the fan. If not it is the switch.
Jun 06, 2011 | 1985 Oldsmobile Cutlass Supreme
Nikon F3's light meter always underexposed
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Mar 06, 2010 | Nikon F3/T 35mm SLR Camera
I installed my tascam mk2.under Cubase LE4. Midi tracks work good.In "set-up devices" I see the Tascam inputs and outputs.Monitor VU-meter is not moving in this audio track and consequently there is no...
Have you clicked the little "monitor" icon (looks like a speaker) on the armed audio track so that it goes orange? Once on, you should see a signal on the VU meter (assuming the line in has a good signal etc). Once recorded, turn the monitor off again to listen to the track with all the others.
Jan 26, 2010 | Tascam US-144 Sound Card
Vestax pmc07 pro powers up, but no output through amp or phones????
most likely one or some of the op-amps are blown. you are using the right ac adaptor too? sometimes when underpowered it will give a low output. also are you getting a read out on the vu meters? if so then most likely the op amps. if there is no read out on the vu meters, it could be the input stage. have you also tried your mic and aux in too?
my suggestion is, that if its under warranty get it fixed.
Aug 30, 2009 | Vestax Pmc07pro DJ Mixer System
Replacement parts for Pyle power amp PT-2000
VU meters are generally illuminated by small bulbs at the back of them. It's unlikely to be a powerfull bulb perhaps 12 volts perhaps around 200ma at the most. Most electrical shops should sell something that should suffice. It could be an LED though!
Apr 15, 2009 | Pyle PT-2000 Amplifier
TASCAM 80-8 DECK NO VU LIGHTS NO REEL MOTORS CAPSTAIN MOTOR RUNS VU METERS THUMP WHEN SWITCH /MAIN POWER IS DEPRESSED
the machine vu lights were dim the reel motors ran then the lights got dimmer and the reel motors stopped its quite old now but never let me down . best regards kirk
Dec 07, 2008 | Tascam Audio Players & Recorders
MS Entourage is very slow - the spinning wheel of death
Michael, if you have the option can you use IMAP instead of POP3 for your email server settings? If your email service provides IMAP you might try it as it may appear to work faster than POP3.
Dec 18, 2007 | Microsoft Entourage For Mac for Mac
 Grubhead
Grubhead
