3M MP7740i Projector no input is detected
The projector turns on and works, the picture is great but all i can get is the main menu. When an external source is plugged in it maintains saying "no input is detected." I have tried plugging in multiple different auxiliary sources through different means (A/V, RGB, S-Video) but nothing has worked. it seems like everything works perfect on the projector except it cant detect input... any ideas?
  • Anonymous May 03, 2008
    Toshiba TDP-S8 has the same problem, no input is detected. I was told to take it to Radio Shack. But if the board is fried, that I best just return the
    item.
  • 563 Answers
Hi mrus821
If the signal won't go through you will have to either have your Mainboard Repaired or Replaced.
This is unfortunatelly a common Mainbaord problem , and the above is the only way to get it fixed.
Posted on Apr 23, 2008
Continuously searching for input. have changed both vga boxes and cables.
I would go into the menu of the projector and turn off the auto source search function and set it to the VGA input. If you have tried your FN and 'F' keys simultaneously to send the signal through the VGA port and still have nothing, you may have a faulty video card.
Good luck, hope I was of help
Aug 15, 2011 | 3M x66 LCD Projector
Screen is turning a pink/purple colour
You should firstly test the projector using some alternative input sources, and using different cables to establish that the pink/purple tinge is consistent across all inputs.
If it is, then your projector is in need of professional repair. You should be able to contact 3m here who can advise who their local repair agent is.
Best of Luck
Feb 15, 2011 | 3M S20 Multimedia Projector
I need to reset the filter timer for the 3M S15 multimedia projector.
u go to ur main menu,then select the option 4 advance etc,then filter,then reset,then confirm,then done.
Jul 01, 2010 | 3M S15 Multimedia Projector
When I plu-in the VGA cable my screen goes blank on my HP-1170. I then have to reboot to fix video on laptop. Done all the resolutions and I cant seem to get the external projector to show anything other...
reset the settings to factory default through the menu. swap out the cable. depending on your laptop, press function-f4 or function-f7. if still nothing, you may have a main board issue.
Dec 27, 2009 | 3M MPro110 Micro Professional Digital...
Projector menu keeps popping up after Directv box change
Is the projector menu that comes on the menu that tells you the projector is not receiving an input signal?
Dec 18, 2009 | Refrigerators
Turn on, the screen is white, no menu, no words
need more info. make? model? dlp or lcd? just by what you said, i'd say main board; but the more info provided, the more accurate the diagnosis.
Nov 10, 2009 | Office Equipment & Supplies
What is wrong with my Panasonic PT-L711XU projector?
try to clean the air filter of your projector... in case the problem occur check the lamp ballast board and replace it.
jahting
Oct 10, 2009 | Panasonic PT L711XU Multimedia Projector
Manual for 3m mp 8730?
http://www.projectorcentral.com/pdf/projector_manual_386.pdf
your projector is the exact same as the hitachi cp-x950w/e. as a matter of fact, hitachi made the 3m mp8730.
Apr 26, 2009 | 3M MP 8730 Multimedia Projector
Optoma EP716 source detection
It sounds like your module that controls the menu and the "cycling through" may not be in sync or may needs to be replaced. I had times have had to make sure the Optoma EP716 had to be first plugged in and "on" before the PC can communicate with it. Once the Optoma is "ON", then turn your PC/Notebook on. If there is no connection via USB, "S" cable and/or your VGA (be sure your PC/Notebook is set to have the external VGA "active"). Let me know if this works or not. Then we can try to move forward with other options for troubleshooting. BTW...how long have you had this multimedia and how many hours of use does it have?...JGUAM
Oct 21, 2007 | Optoma EP716 Multimedia Projector
1,007 people viewed this question
k24674
jasbo
jasbo
