Sure that the outlet you are using is powered? Is power reaching the motor? - I had my power switch on my karcher break internally rendering machine dead. If power is reaching the motor for sure and it does not run then there has to be an open motor winding. If pump jammed you would hear a humming noise from motor and the breaker would pop.
I'am made $84, 8254 so far this year working online and I'm a full time student. Im using an online business opportunity I heard about and I'AM made such great money. It's really user friendly and I'm just so happy that I found out about it. Heres what I do,.for more information simply open this link thank you....
Optimum km range for changing oil in any bike should be 1000km or 6 months which ever comes first. The oil in a motor is designed not only for lubrication but also to keep the engine clean, if you leave oil in a motor for too long than you are lubricating your motor with dirty oil, oil also loses its viscosity to lubricate and that is why there is a time span. Both oil companies along with manufacturers have increased there oil change (servicing) intervals to some silly kilometre and time spams, sometimes common sense prevails. Use a good quality oil, no need to buy the top of the range and maintain your bike
Take the spark plug out and then try to turn it over. If it still won't pull, it's probably locked up. If it got tipped forward or towards the spark plug oil may have went into the valves. If it pulls you may see some oil spray out. Clean off plug and try to wait for the smoke to clear. Hope this helps. Please rate me
Use 10w40 motor oil in the gear box. Don't use any synthetic oils, oil marked "EC", or oil with "special" additives. Stick with the major brands; Pennzoil, Quaker State, Mobil or Shell.
My Kracher 2500 pressure washer has no pressure unless I remove the nozzle. If, I remove the nozzle and pump the trigger several times and quickly replace the nozzle it works fine until I release the trigger. Karcher (online) suggested I remove and clean the unloader which I did. It still doesn't work correctly. What another solution?
hello
the reccomended oil from honda is their GN4. this is a motorcycle blend 10w40. so other 10w40 motorcycle blend oils will work as well. i would stick with hondas oil. but other companies like bel-ray are a good alternative as well.
with an oil and filter change you are looking at approx. 2 us quarts of oil. manual states 2.06 quarts. so may take either a touch more or a touch less.
hope this is helpful. thank you.
