Question about Zenith R56W36 56" Rear Projection Television
Sound problem I have a 1997 Zenith r56w36 56: I was watching tv last night and the tv started to make popping sounds and the sound went off. Tried to hook up speakers to the pack for surround and got no sound there either. can you give me any ideals and possible cost?
  • letterman25 Apr 23, 2008
    this tv does not have the ypbpr wires connected to it from the sat receiver. I pulled up the menu did not find component audio in it.
    I have no YPbPr cable connected to this tv from the sat receiver and when I pull up memu cannot find compoent audio. The tv has the regular cable coming from the receiver. Any ideals?
  • 3,037 Answers
This problem definitely sounds internal. If there is nothing coming from the headphone jack output, then I am afraid you have lost the sound detector which is part of an Integrated Circuit that supplies the audio and video to the set after coming from the tuner circuits and IF strip. What it means is the high likelyhood that the IC will need to be replaced. The cost of replacing it will be over $75; maybe $100, plus or minus.
Please let me know if you have any further questions
Thank you for using Fixya and Good Luck
Posted on Apr 23, 2008
    Genius:
  • 1,142 Answers
Did u try to turn the tv off completely remove the power cable and leave it turned off for at least half hour then try to turn it back on and make sure all the cables are connected and if youhave any external speakers attached that that should be turned on too.
  • Zenith Master
  • 19,396 Answers
Check what type of cable is connecting your sat box to your TV
If it is via a red/green/blue cable, make sure you also have an additional red and white audio cable connected, and select YPbPr (or component audio) in your TV's menu
Posted on Apr 22, 2008
Panasonic Plasma 50 TH-P50U30A blacked out with no sound
Appears to be a power supply issue with everything being so dead.
Jan 22, 2017 | Panasonic Televison & Video
Hello, Last night my Samsung plasma TV made a fairly loud popping sound while I was watching it and then the power went off. When I turned back it on, no picture but sound was o.k.
Yes the caps on theower supply, but you can check power supply board by smell an look for burnt parts it is common. May need more than one board if they are cheap get both.
Jan 29, 2015 | Samsung Televison & Video
My Vizio LCD TV went out. Its just a black screen. The Vizio symbol turns on and off but no picture and no sound. It sounds like its similar to most peoples issues on here. How do I know if its my mai
There could be a few things that would cause this. I would suspect that you have a problem with either the power supply board or the main board. Based on my experience, the main boards go before the power supplies. What is the model #
Jan 26, 2013 | Vizio E550VA 55 in. LCD TV
It started 3 days ago the picture started getting darker and darker everyday then last night after turning the tv off which was off for several hours I turned it back on and a few min later there was a...
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER 915B403001 Lamp (180W)
Dec 16, 2010 | Mitsubishi WD-65736 Television
While watching TV last night, sounded like a light bulb popping. The screen went blank but the sound remained. Does this sould repairable of an LG 42 - 46 inch flat screen?
Yes it does. WHat has popped was most likely a fuse (along with a component that caused the problem) and it is most likely an inverter board.
The best thing you can do is test the fuses on both inverters first.
The fuses are small rectangular, usually white with golden plates on both sides of their about 6 mm long bodies near the cable connectors.
A burned (open) fuse indicates faulty board.
And here is a listing I found for you on eBay that sells them REALLY cheap:
http://cgi.ebay.com/Zenith-42LC2D-inverter-boards-6632L-0153D-6632L-0154D-/320600922120?pt=LH_DefaultDomain_0&hash=item4aa54dd808
I am not anyhow associated with this seller. Picked it because the sale gives both inverters for the price for which others are selling one of them...or at least it seems so. You may want to talk to the seller first.
Hope this helps. If it does do not forget to rate it :-)
Oct 25, 2010 | LG 42LC2D 42 in. LCD HDTV
Sound no pic
Convergence ICs are STK392-110 you will need two of them they are available at the link I am posting and they give free instalation instructions with pics and free tech support so you can do the repair yourself.Heres the link.
http://servicemanuals.vstore.ca/
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Toshiba 50HP66 Blank Screen with sound
I would suggest to read what other members have reported by clicking here.
Good Luck.
Apr 28, 2008 | Toshiba 50HP66 50 in. Plasma Television
No picture on screen
MYGR8-YOU HAVE TO LIST BRAND NAME AND MODEL #. JOE TV
Nov 30, 2007 | Televison & Video
P42W46X
take visa or mastercard to local best buy for new tv. sorry
May 26, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Zenith R56W36 56" Rear Projection Television Logo
56 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
