One for all code needed
I have a SV2000 DVD Recorder/VHS and I am in need of the code to be able to use the One for all remote control. Can someone help please? The remote that came with the item works when it wants to.
  • 1 more comment
  • Rottie95 Apr 27, 2008
    Hi Ekse:
    I have the Cinema 7 One for All, URC-7800B00
    Thank you, Karen
    It won't work using either steps. Any other advice?
    Thanks
  • Rottie95 Apr 28, 2008
    I was told elsewhere that my device is made by Funai and that ONE FOR ALL URC10820 10-DEVICE UPGRADABLE LEARNING REMOTE will work with my device.
    Thank you for trying. Have a great day
  • 13,433 Answers
Can you post me the details of the universal remote controller you are trying to use with the Dvd vhs combo.
Brand and model if you can.
Posted on Apr 27, 2008
  • 2 more comments
  • Ekse Apr 27, 2008
    You can find the device codes from here
    http://www.hifi-remote.com/ofa/codes-vcr...
    Since I'm not sure which brand your device is I cant give you a strate ansver.
    If none of the codes work then we have two other solutions:
    1. Searching For Your Code
    If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
    If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
    1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
    2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
    3. ENTER 9-9-1 (two blinks on the remote)
    4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
      Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
    5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
    2. Learn the buttons from the original
    Line up your original remote and the head-to-head before completing the following steps.
    1. PRESS and HOLD the SETUP button until the red LED flashes twice.
    2. PRESS 9 - 7 - 5, the red LED will flash twice.
    3. PRESS the DEVICE key where you wish to learn the function.
      The next 3 steps must be completed within 10 seconds.
    4. PRESS the button that will receive the learned function, the LED will flash radidly.
    5. PRESS the button on the original remote to be learned.
    Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
    To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
    More help for programing your remote can be found here: http://www.hifi-remote.com/manuals/ofa-l...
    If you need more assistance let me know.
  • Ekse Apr 27, 2008
    note: If your remote uses 3 digit setup codes, just drop the leading zero, your remote won't have codes greater than 1000 so don't worry about those codes.
  • Ekse Apr 28, 2008
    What is the brand of your device? Samsung? Philips?
  • Ekse Apr 28, 2008
    Ok, good luck. if you need anything else, let us know.
I have a magnavox dvd/vhs recorder/player and need the RCA Universal controller code number
You have this backwards. Your RCA universal remote has a "code search" feature that lets you try to find a code that will control some or all functions of your Magnavox DVD/VHS recorder. If a thorough search does not produce a result, you may have to try another remote.
Aug 29, 2014 | Televison & Video
I need a remote controller for my sv2000 dvd vhs combo it was not in the box
the first thing I'd do is check the packing list to see if it was suppose to have one and wheather it did or didn't; I'd go back where I bought it and ask them.but you can always buy universal remotes at just about any electronic stores or better yet online
Dec 18, 2011 | Funai FDR90E DVD Recorder
IS THERE A CODE TO SET MY FUNIA SV2000 DVD RECORDER TO WORK WITH MY DIRECT TV REMOTE
Remotes are set to the DVD recorder in the REMOTE. It is difficult to control a DVD recorder with a universal remote except for basic functions. The remote manual needs to list the DVD Recorder or a similar Funai model to control it. Try different Funai codes from your remote book. One might work for minimal stop, play, pause, etc.
Mar 20, 2010 | Funai PY90DG DVD Recorder
After recording vhs to dvd it only plays on that player. it will not play on other dvd players. This is not an Emerson but it did not give an option for the SV2000 dvd/vhs recorder.
if you recorded using a dvd- disc then it needs to be finalized on the recorder to allow it to be played on most other players. if you used a dvd+ disc then the other player(s) may not support dvd+ playback.
Jan 22, 2010 | Televison & Video
Need code for SV2000 tv/dvd combo & Comcast remote,
Any remote supporting Sylvania TV/DVD combos will work for these tvs. I had a Zenith universal remote working with this TV.
Nov 26, 2009 | One For All URC-4021 Remote Control
Please can I get the code to program in my SV2000. Thank you
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
Apr 28, 2009 | Jensen JR400 Remote Control
SV2000 tv/dvd code
the code for the SV2000 using a oneforall remote is 0456
Jul 08, 2008 | One For All URC-4021 Remote Control
I need the instructions and codes for my really big remote control
HAVE THE REALLY BIG UNIVERAL REMOTE SENTRY RMC-10 .
I NEED THE CODE FOR THE DVD/RW SV2000 RECORDER
Jan 02, 2008 | Bushnell Sentry 78-1836 (18-36x50 mm)
Televison & Video Logo
731 people viewed this question
Top Televison & Video Experts
