Question about Dell Inspiron 1501 Notebook
Screen distortion when coming back from idle/sleep mode
After my computer sits for a while, of course it goes to the screen saver and then to sleep mode. When I turn the computer back on from sleep mode, the screen is scrambled and distorted. I have to shut the computer down totally in order for the display to show correctly. Any ideas how to solve this???
  • Anonymous Mar 15, 2014
    I just updated the computer to Windows 7. I have changed the screen sleep modes for both plugged in and battery to "Never". The screen saver mode is also set properly and is working well. The screen goes blank after it has been inactive about 1 hour. The computer continues to run with the screen blank. I try to re-activate the screen with the mouse but no response. I have tried hitting the escape key but with not positive results. The only course I have to to push the power key of the computer in order to shut it down. What solutions would you recommend to this problem?
  • Anonymous Mar 16, 2014
    only shows white square on dark screen.will not do anything else.will not go to apps,password or anything.looks like it is in some kind of sleep mode that will not turn off
This could be an issue with your Video drivers. I would try and Download the newest drivers for my system and see if that helps the problem
Posted on May 01, 2008
Hp pavilion all in one AMD goes to sleep after 1 minute idle then asks for password to open up.. how to extend idle time to 2 hours
What you are experiencing isn't "sleep" mode, it is the screen saver. If you have WINXP, right click on a clear area of the desktop, and select "Properties". When the DISPLAY PROPERTIES window appears, select the "screen saver" tab. Change the "WAIT" time to the time you wish the scrren saver to delay. If you don't want to have to login after a screen time out, uncheck the "On resume, display Welcome Screen" box.
Nov 27, 2013 | HP Black Pavilion 20-b013w All-in-One...
I put my Dell Dimension 9200 XPS 410 into sleep mode after connecting a wireless keyboard and mouse and the only way to wake it is to hold the power button in until it shuts off and then switch the power...
I would say it is in the Hibernation Mode To get it out of this mode you need to go to your Control Panel, open "POWER OPTION'S" and deselect the Hibernation mode then reboot.
Sep 26, 2013 | Dell Dimension 9200 PC Desktop
How do I turn off the sleep mode on my monitor?
Control panel Power options adjust time for monitor time to sleep you can adjust 5 minutes to never the option available same can be done for hard disk. This is necessary as even monitor is active and when hard disk goes to sleep you may end up in same situation
Alternatively you can activate screen saver by
right click on desktop, settings screen saver choose screen saver set time to activate screen saver.
Sep 03, 2011 | Computers & Internet
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
I am unable to access the internet from sleep mode Can only get on internet from shut down mode
Three possible causes of sleep mode. first, an extensive screensaver with password lock prevents display. A condition that is observable as a blankscreen also known as sleep mode. Second, a computer power saver settings that shutsdown during idleness. Third, An improper shut down of the computer would have caused a sleep mode to save the system data files.
Restoring the computer to regular functionalioty
First solving predictable sleep mode settings
1. A movement of mouse pointer across the screen should reestablish unprotected password modes
a. password protected sleep mode would display an promp message requiring key code soon after the mouse pointer has changed direction
sloving unpredictable sleep mode settings
1.A computer power saver, screen saver, or splash screen displays prevnting programs acess would require manually powering off the computer system.
a. A manual power back on of the system should restore to program functionality mode
important notes
1. contact expert technical assistance
Dec 20, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
HP 2338H Monitor Goes into Sleep mode and I have to power comput
you meant w2238w , right, you left off the w?
circa 2006 monitor, 11 years old.?
if the monitor fails on 2 PC, the monitor is bad ! ok, do that...
then
push the monitor menu buttton, connected to a running PC.
if the OSD is dead, , (on screen display , menu button front of monitor)
that means the monitor is dead, CCFL tubes are bad.
cold cathod florescient laml tubes all day this old.
the menu button can be in lock mode, hold the button for 10 seconds, and it unlocks
then go in the OSD screens if they work,. and turn off the sleep timer.
this timer is marked in the OSD as power saver,. turn it off.
it is a time clocked feature, and a pain to use on modern PC.
your PC does sleep modes today and never us this timer,inside monitor (default is on, turn it off)
all that is on page32 in your manual,
https://www.manualslib.com/manual/71500/Hp-W2338h.html?page=32#manual
Sep 21, 2017 | HP Computers & Internet
Monitor goes to sleep
go to control panel, display properties, screen saver, turn off,
than go to power options, turn off the "turn off display" option.
Jun 06, 2009 | HP Computers & Internet
Aspire one with windows XP. Won't turn back on while in sleep mod
I've had spotty luck with Windows and sleep or hibernate modes. I would suggest just disabling sleep/hibernate mode. The options can be found under the control panel under power options. While turning off the sleep mode won't help your battery life, if you ask me, it beats having to power off the laptop by pulling the battery out. If you don't want to turn it off, you can try adjusting the amount of time it lets pass before it goes to slee.
Mar 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
When the computer is turned on the monitor goes to sleep mode
Go to safe mode,select boot in vga mode.
If this allows you to start,
Click start,Run type desk.cpl
Screen Saver tab | click on Energy
Under desk or office settings frame, set all values to "never".
Then click
Advanced Options, you'll see a frame asking you what to do.
Just select the options to turn off sleep mode.
check that out.
If you can't start this way,you need to try another monitor to change the setting above.
Please rate this a fixya
Feb 14, 2009 | Computers & Internet
Dell Inspiron 1501 Notebook Logo
205 people viewed this question
Alun Cox
