Question about Kyocera Slider Cellular Phone
Kyocera Slider broken directional buttons
I've been having the best of luck with this phone and lately the directional keypad isn't working. I can't scroll down or to the right so i can't see the end of text messages and i can't select any applications that aren't in the farthest left hand column of the menus. Also the back key isn't working either... any ideas on how to fix it?
  • aero28 May 07, 2008
    this phone sucks...I had never dropped it and the down button, call button, right button, and back button don't work for me either. also, i have to use speaker phone in order to hear or talk to anyone. What is worse is that on occation the buttons will start to work again, but only for a day or so.
  • Harry5315 Aug 11, 2008
    I have the Kyocera remix and have had the same problems. I took it into
    US C & they replaced the ribbon cable, under the keypad, for free
    (got a nice tech?). This solved the problem for about a month. Same
    thing started up again so I took it back in. This tech told me it would
    cost $20 to replace the cable, I told him to do it. He does it and the
    keys still don't work. He doesn't charge me for replacing the cable and
    says the actual board must be going bad. Only solution, send it in for
    reapir. Not worth the cost and wait.
I have the Kyocera remix and have had the same problems. I took it into US C & they replaced the ribbon cable, under the keypad, for free (got a nice tech?). This solved the problem for about a month. Same thing started up again so I took it back in. This tech told me it would cost $20 to replace the cable, I told him to do it. He does it and the keys still don't work. He doesn't charge me for replacing the cable and says the actual board must be going bad. Only solution, send it in for reapir. Not worth the cost and wait.
Posted on Aug 11, 2008
Lately, my T-Mobile Samsung t239 phone's buttons on the slider part with the monitor attached to it won't work, like for example, the right side button that, when the home screen is on,...
i gues you have dropped it or it got wet. Bring it to your local telephone shop and ask to clean it. That only cost like 10 dollars and when they put it back together the align the keyboard
thats the best way to go
good luck
rene
May 28, 2011 | Samsung T239 Cell Phone
N 81 is 1234567890*# is not working plise give me a solushion
Well, 2 things, there is a lock keypad slider on the side of the phone, once you slide this even if you restart the phone, the keypad still wont work, try sliding this into the unlock position, if this does not work...well best bet is that the connector cable for the keypad is dislodged, broken or the contacts on it need to be cleaned, whatever the case, you will need to carefully disassemble the phone and unplug everything, clean with rubbing alcohol, reassemble and it should work, Hope this helps
Oct 29, 2010 | Nokia N81
Slider part keypad not working properly, only number keypads are working
Possible that the flexible membrane strip of the connection to the slider keypad is broken off there by cutting off the connection.
These membrane strip wires must be procured to be installed back into the main board and connected to the slider pad.
Attempt only if you are experienced to do these delicate jobs.
Oct 23, 2010 | Cell Phones
When phone is on charger it just shows Kyocera
I had the same problem with a phone I had of the same model. I sent it in numerous times and it continued, so I got a new one, and 2 months late I had the same problem. My advice is to go with a different phone. Kyocera is not a very popular brand because of the many problems they have with their electronics. I've done lots of research on that model phone and have found very few satisfied customers. Cheaper in the long run to just get a different phone.
Feb 11, 2009 | Kyocera Slider Remix KX5 / Sonic Cellular...
Kyocera slider sonic
go to cellphone shop .com, they have things like that for this phone very cheap.
Jun 06, 2008 | Kyocera Slider Remix KX5 / Sonic Cellular...
Keypad settings
the only options Ive found for this are if you hit a button with the slider closed it asks if you want to unlock the keypad. Then you hit the right top button (says "ok") and it unlocks...this stays like this until you open and then close the slider. This is the only way I know of to unlock the keypad, I have not found any other way in settings menu or anywhere else. Good luck!!
Dec 20, 2007 | Samsung SGH-t629 Cellular Phone
Kx5 (slider sonic) from Virgin Mobile USA
you cant transfer ringtones to your phone using cable, you need to download that ringtone from virgin mobile website,http://www.virginmobileusa.com or through your phone menu go to VXL
Dec 05, 2007 | Kyocera Slider Remix KX5 / Sonic Cellular...
My back button does not work
****! I got the same problem!!!
Oct 24, 2007 | Kyocera Slider Cellular Phone
When i call someone or they call me i can t hear them
I have the same problem with mine and luckily am still under warranty. My son has the same phone and the same problem. If your phone is still fairly new and not abused, as in water damage or been banged around you'd be best advised to bring the phone back to the store and raise some "hell" on them for selling defective devices. I was offered a new phone from my provider. Good luck
Aug 12, 2007 | Kyocera Slider Cellular Phone
Kyocera Slider Cellular Phone Logo
63 people viewed this question
Top Kyocera Cell Phones Experts
Ben Darden
Ben Darden
Casey Mckinney
Casey Mckinney
Level 1 Expert
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
