Need the main board numbers on it include: 4143039205 08.30.2005 VER:0.08 STL 0546 94v0 e2222841 this is for Soyo Monitor VT19N79
  • m_elias Jan 03, 2009
    I have some power components on the main board burn out. After replacing what we could find wrong, still no go. A replacement board would be great!
  • Anonymous Mar 20, 2009
    have you found a replacement board?
2 Suggested Answers
  • 16376 Answers
SOURCE: need parts list for mother bd. HP Pavilion m9500y ,ms-7548 ver i.0
you are going to find those close to the atx (main power) connection
Posted on Sep 26, 2012
I have a sinotec stl-55d2000 led tv and now im looking for a main and t.con board.because there was a load shedding by us .thank you
The fault might be with its main power regulator board. Not with T'Con. Power outage will cause this fault only. The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Feb 11, 2017 | Televison & Video
Soyo tv won't change between inputs
The main board is having an issue thats why the inputs wont switch.
Apr 05, 2013 | Soyo 26 in. LCD TV
I need a mother board for my 32' soyo
Since you did not intimate model number of your Soyo 32 inch tv so click ShopJimmy.com and put your tv model number in search bar to locate required main board for tv.
Hope these info will help you.
Thanks.
Dec 13, 2010 | Panasonic Televison & Video
Computer 19" LCD Monitor with TFT 1280 x 1024 8ms DVI Connector Integrated Speakers - DYLM1967 ...: After a thunderstorm, my Soyo monitor would not tu...
If it uses AC adapter, then check the DC voltage at the DC plug to see if you get any voltage, if it use Direct power cord then it may have blown fuse inside the monitor, then you will need to open up the monitor.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 17, 2010 | Soyo TFT 19" LCD Monitor
BIOS for motherboard
got to web site make sure that you have the bio ver on board look for updates on site jim
Mar 15, 2010 | Soyo P4VTE (SY-P4VTE) Motherboard
I need the drivers for this unit
u can need widescreen driver for soyo.
u just go on that and check it out:
www.techsupportforum.com/.../driver.../264735-widescreen-driver-needed-soyo.html -
thnxxxx
Sep 18, 2009 | Soyo DYLM019A 19 in. LCD Television
Tv only turns on, will go to soyo screen then black screen. when you can get the menu it only has symbles and no words can not turn off with out unplugging. never has a picture
Sounds like the Main Mother Board is the problem. Basically, it's the brain inside the TV. Controls and functions is that board's job.
Soyo parts are hard to come by. You can try running the number off the mother board on the internet and maybe a supplier will pop up.
Their Soyo.com web site isn't working. So, I'm thing they maybe out of business.
If you have some electronic experance and if your lucky, the heatsink on the chip processor is the problem.
Aug 05, 2009 | Soyo DYLT032D 32 in. LCD Television
Need code
Try the Following Five Programs
1) Program for Prime Number Generation
#include <stdio.h>
main()
int n,i=1,j,c;
clrscr();
printf("Enter Number Of Terms
printf("Prime Numbers Are Follwing
scanf("%d",&n);
while(i<=n)
c=0;
for(j=1;j<=i;j++)
if(i%j==0)
c++;
if(c==2)
printf("%d ",i)
i++;
getch();
2)Program for finding the prime numbers
#include <stdio.h>
#include <conio.h>
void main()
int n,m,k,i,max;
char c;
clrscr();
repeat: max=0;
k=2;
n=1;
printf("You want prime numbers upto:- ");
scanf("%d",&max);
printf("
for (i=1;i<=max;i++)
again: m=(n/k)*k;
if (m!=n)
k=k+1;
else
goto try1;
if (k < n/2)
goto again;
else
printf("%d",n);
printf(" ");
try1: n=n+1;
k=2;
fflush(stdin);
printf ("
Do you want to continue?(y/n):- ");
scanf("%c",&c);
if (c=='y')
goto repeat;
getch();
3)
  1. #include <stdio.h>
  2. int main(void) {
  3. int n,
  4. lcv,
  5. flag; /* flag initially is 1 and becomes 0 if we determine that n
  6. is not a prime */
  7. printf("Enter value of N > ");
  8. scanf("%d", &n);
  9. for (lcv=2, flag=1; lcv <= (n / 2); lcv++) {
  10. if ((n % lcv) == 0) {
  11. if (flag)
  12. printf("The non-trivial factors of %d are: \n", n);
  13. flag = 0;
  14. printf("\t%d\n", lcv);
  15. }
  16. }
  17. if (flag)
  18. printf("%d is prime\n", n);
  19. }
4)
#include<stdio.h>
#include<conio.h>
void main()
int n,i,c=0;
clrscr();
printf("enter the number:");
scanf("%d",&n);
for(i=1;i<=n;i++)
if(n%i==0)
c=c+1;
if(c==2)
printf("number is prime");
else
printf("number is not prime");
getch();
5)
#include<stdio.h>
#include<conio.h>
void main()
int a,b,c;
clrscr();
scanf("%d",&a);
for(b=2;b<a/2;b++)
if(n%i==0)
printf("\n Its not a Prime number");
c=1;
break;
if(flag==0)
printf("\n Its a Prime Number");
getch();
Sep 02, 2008 | Computers & Internet
TV PARTS FOR SOYO
Have you checked PTS 18008447871 ?
Mar 17, 2008 | Televison & Video
Computers & Internet Logo
306 people viewed this question
David Payne
David Payne
