Question about Oreck XL Ultra Bagged Upright Vacuum
Oreck XL9100 Brush clogged with hair
Does anyone know how to dismantle the brush for the Oreck vacuums? They appear to be the same for the newer models. I've had to replace several brushes due to hair, or whatever, clogging up the brush so it won't turn. I've tried getting a pocket knife in there but it won't really get the hair that's hidden and stopping the brush from turning freely.
  • Anonymous May 13, 2008
    My brush does not appear to be clogged by anything, but it is not spinning when the vacuum is running and thus it is harder to push the vacuum. Any ideas as to what the problem could be?
    President:
  • 1,673 Answers
The pulley will turn off, then the end will pull off. Some of the replacement brush rolls, the pulley may be pressed on and may or may not come off with out ruining the end.
Posted on Apr 24, 2008
Oreck vacuum cleaner stop and burn smell
sounds like hair or string or something like that is wrapped around the beater bar(the long brush under the head that brushes the carpet) keeping it from turning. The belt that drives the bar is getting hot because the beater bar is stuck.
Aug 12, 2014 | Oreck Vacuums
Oreck brush only turns a tiny bit and belt pulley get hot belt not turning much either
If your brush is not turning properly then you need to check the bearing ends to see if there is any hair, string, or thread wound around the brush shaft. If there is and you can remove it, that might fix your problem otherwise I would suggest getting a new brush roller.
Jun 30, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Oreck brush only turns a tiny bit and belt pulley get hot and smells bad
Sounds like you probably have a brush issue since it does not turn very much. I would pull the brush and take the bearings off each end if you can and look to see if there is a build up of hair or string around the bearing shaft. If you see that and can clean that out that might help. If you cannot get to the bearings you may just have to purchase a new brush roller.
Oreck magnesium keeps shutting off
Need to check your brush roller to see if it is spinning. Turn the vacuum over and turn it on. If the brush spins before it shuts off, you may need to check the bearings to see if any strings or hair has built up around the brush bearing shafts and is causing the brush to spin slower. If the brush does not spin, you have a broken belt and you will need to replace it. The Magnesium has a sensor that looks for the brush to spin at a certain speed and if it does not, it will shut down. Hope this helps!
Apr 12, 2014 | Oreck Vacuums
Suction problem
Probably have a clog some where in the base and that is what causes it to throw stuff back out.
Apr 04, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Oreck upright hard to push
If hard to push, only a few things to check:
(1) Rear wheels will get hair or thread wrapped around axles, dust, etc. and be hard to turn. Make sure each wheel turns easily.
(2) Small wheels on newer models (since about 1997-98) toward front are worn, missing or have same problem as item 1.
(3) Brush roll not turning. The brush roll actually helps pull this unit along the floor, as it rotates in the "forward" direction. If the belt broke, and you do not realize it, it may suddenly seem harder to push.
Oct 11, 2009 | Oreck XL2000 Bagged Upright Vacuum
Brush doesn't rotate
If the brush don't rotate.the first thing you need to do is check to make sure there is nothing jammed in the brush.Like a piece from a carpet,or hair.If it still don't work.then you need to change the belt inside the vacuum itself.
Jul 31, 2009 | Oreck XL Ultra Bagged Upright Vacuum
My Oreck XL was working fine, then when I vacuumed a shag rug is started smoking and smelled like something is burning. (I changed the bag, checked for clogs--none found, and roller brush is turning. It...
Even though the brush is spinning, the belt is probably worn out and stretched. when you vacuum the shag carpet, it puts more drag on the brush. try running it on a shorter carpet or hard floor for a few minutes. if it doesn't smoke, then you know it's your belt. if it does smoke, then it's probably the motor burning up.
Jim
Jun 02, 2009 | Oreck XL2000 Bagged Upright Vacuum
Oreck xl
Sounds like the Oreck is clogged. You'll have to undo the bag by the way of the clip in the middle at the back of the main black spindel neck and then at the bottom. Then take apart the main neck by pushing the rubber mounts upwards to release the pip fitting locks and holes. You should find that either the top of the neck or the bottom - where the dust channel feeder is located - is clogged. Either that or there may be a clog in the main dust channel after the roller brush or wedged into the fan unit itself - the Oreck XL is a dirty fan system which means clogged dirt can often get stuck between the dirt and the dirt channel.
Dec 28, 2007 | Oreck XL2200 Bagged Upright Vacuum
Oreck XL
Your roller brush is probably bound with hair and is not able to move
Nov 30, 2007 | Oreck XL2600 Vacuum
Oreck XL Ultra Bagged Upright Vacuum Logo
215 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
