How do you remove the panel to change the lock mechanism in the washer body of a kenmore front loading washing machine, model 42822? NOTE: this is the lock mechanism on the washer side itself, not just the plastic hook piece on the door?
  • Anonymous Mar 25, 2014
    I want to change the seal on my Bosch w/m and have managed to locate all of the screws on the top panel, the control fascia and the bottom panel but I can't work out how to get at the screws which clearly hold the front panel on, above and below the door lock. There are what look like two plastic tops, possibly with the screws underneath them. Do I prise these off or are they some special kind of screw? I'm nervous of breaking the plastic tops if I use force. Help!
    Genius:
  • 1,073 Answers
Remove the top and the bottom acces cover you will be able to get at it from the top or bottom it just makes it easier to get to the wiring this way
Posted on Apr 23, 2008
I get a Fo6 code problem and can't get it to wash. KENMORE H3 model
Get the bottom service panel off and check the tech sheet for what an F-6 error is.b578ec7.jpg
Aug 28, 2010 | Kenmore 42822 Front Load Washer
Kenmore Elite model 42934. Problem washer only
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 26, 2010 | Kenmore 42822 Front Load Washer
Door Seal
Just follow this link and it will explain how to replace the door seal:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is a very simple repair, if you follow the step-by-step instructions. Take your time and if you have questions, let me know. I hope this helps you.
PS An alternative method is to work through the door with the front panel in place, but this limits access. To make things easier, it is strongly recommended that you remove the front panel.
Apr 13, 2009 | Kenmore 42822 Front Load Washer
Kenmore front loading commercial washer door will not opne
You need to get access behind the front panel, taking the top panel off is probably best. Then you can see the the door release mechanism and release it.
Feb 09, 2009 | Kenmore 43042 Front Load Washer
My Kenmore Elite Frontloading HE3 is flashing a Sud, what do I do
apply a small amount of cooking oil imside tub ,, must use only HE deteregent if you are ,,, maybe too much
Jan 01, 2009 | Kenmore 42822 Front Load Washer
Kenmore HE3 model 42822 flashes HF??????
probably fh ..be sure drain hose is at least 30 insches from floor and fits loosely in standpipe to prevent siphoning also ckd all fill hoses for obstructions in inlet valve ends most likely problem is flowmeter remove top round object left side with 2 small hoses try tapping it this may at least let you know for sure it is problem even it doesn't flowmeter is most likely the problem
Nov 20, 2008 | Kenmore 42822 Front Load Washer
Kenmore Washing Machine
check the lock switch on the front load washer sometime it gets stuck
Mar 18, 2008 | Kenmore 44042 Front Load Washer
Kenmore front load washer
pull despencer out ck if its dripping inside washer has a bad inlet water valve
Mar 01, 2008 | Kenmore 42822 Front Load Washer
Kenmore Elite front loading washing machine
My machine just died. No codes, no nothing. I thought it had blew a fuse. But the outlet is fine. There is no power to the unit. There is a load in the machine and I can't get it out. Help
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
