Question about Seagate Barracuda 7200.9 500 GB ATA-100 Hard Drive
New hard drive was installed and will not boot
When D Top turned on I get the following message;
Reboot and select proper boot device or insert boot media in selected boot device and press any key_
I have tried every boot device available to no avail. Followed all the suggestions from Seagate and still no help! Any other help would be appreciated.
    Genius:
  • 2,785 Answers
Plz check if your hard drive is detecting,if yes then try to reinstall the OS otherwise your hdd is dead and replace it.
Posted on Apr 23, 2008
Error message on screen: "Reboot and select proper boot device or insert boot media in selected boot device and press a key"
In the bios be sure the boot sequence starts with the hard drive, and that the hard drive is recognized by the bios, if both of these are true than you may need to re install windows.
Aug 29, 2013 | Gateway PT.GBL02.001 DX4850-27e Desktop PC...
Booting up new motherboard
You need to re enter system setup Press Del and change boot device order to floppy, CD/DVD and Hard Disk
Worldvet
Jul 05, 2008 | ASUS P5PE-VM Motherboard
Hello, My laptop shows the following message when I turn it on- Realtek PCIe FE Family controller Series v1.19(08/10/09) PXE-EGI-Media test failure,check cable PXE-MOF-Exiting PXE ROM Reboot an
It can't locate a working boot disc. Most likely lost communications with hard drive. Look in BIOS again to see it recognizes the drive. If not try re-seating / reconnecting drive.
Feb 16, 2013 | Dell Inspiron N5010 Black
G31M-VS reboot and select proper boot device or insert boot media
check whether the hard drive is detecting or not, select the first boot device as hard disk
Feb 02, 2013 | Computers & Internet
At the startup menu i am getting a message that says, Reboot and Select Proper Boot Device or Insert Boot Media in selected Boot device."
Firt thing you can check is wthr your harddrive is detected or not. to do that you have to enter to the BIOS,To Enter BIOS you have to press DELET or F1 or F2 key(Mostly DELET). Now inside the BIOS in main menu check if your hard drive is showing or not. If it is showing there then you try to find out boot sequence, option after getting the boot sequence optuon check if the first device is other then hard drive.
if your harddrive is detected and your first boot device is also set to HARD drive then it might that your Operating system is Crash, in that case you need to re install the OS.
Now if you can see your hardrive in your BIOS then you can open the case( remember to unplug all the cable, Power, VGA, KEYboar ...etc) and try to inter change the harddrive cable connting cable, i mean just try to chage the port of the cable to other one and try switch on your computer ... if still you find the same problem then try changing new cable. ....well if still you have the same problem then i am afraid that you might need to replace the hard drive with new one.
Sorry for the Bad Englsih. Hope the above steps will work for you and you understood what i tried to say.
Cheers:)
Jul 25, 2012 | Gateway DX4300-03 Desktop PC
Replaced hard drive and am getting a "Reboot and
Hi seqhdha,
The reason why you're receiving that meesage is the system is not detecting any bootable device on the computer or it is boot from a media that is not bootable (CD/DVD/USB). To fix this problem if you already installed the Operating System you can change boot priority setting and select the Hard Drive as the First Boot Device however, if you havent install the Operating System you need to select the CDROM as the First Boot Device and insert the Windows Installer.
Here are the steps on how to access the BIOS Page.
1. Restart the computer and while it is booting tap DELETE button.
2. On the Bios page look for the BOOT tab then set the priority to either Hard Disk or CDROM depends if you already installed the OS or not.
3. Follow the instruction on how to install the Operating System
4. Rate me if this helps so i can help others.
Thanls for using Fixya.
Jan 31, 2011 | Gateway 550GR PC Desktop
its basically telling you that your master hard drive with O/S installation cannot be found in the booting system...Check if your master HD is not corrupted and see if your O/S still exist or maybe wiped out..
Mar 31, 2010 | Computers & Internet
When I turn it on it says Reboot and select proper boot device or Insert boot media in selected boot device and press a key.
Please verify if you don;t have a floppy disk in your drive. If you don't then you have to verify in BIOS if is selected proper boot device - HDD.
If everything is set then you have problem with your hard disk, must check and install new operating system.
Feb 24, 2010 | E-Machines eMachines Desktop PC
When I turn on my MSI M510C notebook - ''reboot and select proper
Your notebook does not see the proper boot files on your C drive. Many times the boot.ini has been corrupted.
You will need a Windows XP Install CD mounted in the CD Rom. When you boot the system you need to choose the CD as the boot device (if the notebbok does not do it by default) then typr R to enter the recovery console. Once you get the C: prompt you will need to create a new boot.ini file using the bootcfg command. See the following website for details in using the Recovery Console:
http://commandwindows.com/recovery.htm
Jun 15, 2009 | MSI M510C Notebook
I/o error. press any key to restart
The jumper on the hard drive may be on the wrong pins for this motherboard. If it's on MA try CS and vice-versa.
May 17, 2009 | Intel Computers & Internet
Seagate Barracuda 7200.9 500 GB ATA-100 Hard Drive Logo
111 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
