Question about Ovens
Flavel 100 finesse problem
We have a Flavel 100 finesse range style cooker and the left hand side will no longer work (fan assisted oven or grill) however the right hand side works fine along with the 8 gas hob rings, i just wondered if someone could give us an idea how to solve/fix the problem?
  • 6 more comments
  • semm May 08, 2008
    I to have had the same problem, but managed with the other oven and grill as my 1 year guarentee was out, but yesterday the fan oven and grill stopped working! it is two years old I am not impressed, have rang them 4 times but never get through to customer services. did your timer stop working as well. Flavel 100 oven rubbish
  • blueboy95 Oct 07, 2008
    I have the very same problem and can't find the fuse
  • Anonymous Apr 07, 2009
    samr problem here....went a week after the guarantee expired. Any help out there please?
  • rupert12 May 17, 2009
    I have same same problem, has anyone been able to fix it as I am just out of warranty??
  • Anonymous Mar 12, 2014
    Oven stopped working fan and grill ok
  • Anonymous Mar 20, 2014
    The fan works I can hear it but not heating up
  • Anonymous Mar 29, 2014
    Bought the Flavel FSE50 second hand but now that its wired in I cant seem to get the grill to work so an online manual would be useful. Thank you
    how does the grill work
I have a Flevel 100 and wish I had checked out all the problems everyone is having first as I would never have bought it...what a waste of money...already replaced the element on it...the ordinary cooker died weeks ago...now the fan one has died leaving me with no means of cooking in an oven...this is going to the nearest dump as soon as I can get to the shop to buy a very cheap standin...Flavel I hope you are ashamed!
Posted on Jun 08, 2010
If you take off the back pannel (both sides) you will note that there is fuse - little whit circular thing held on with two scres - there will be one for each side. If one side is working, the other not, then try swapping these - if this changes over the side that works then you need to sourse a spare - I am struggeling to source a spare.
Posted on Dec 26, 2011
  • Ros Jones Dec 26, 2011
    think this is the problem with ours have you sourced where you can get fuses from
  • Phil Westley
    Phil Westley Aug 25, 2014
    find the fuse at Maplins online. It was 79p
Check the thermal fuse it is located on a bracket at the rear of the fan oven.
Posted on Oct 06, 2008
Whrre is the battery compartment for flavel cascade 50 cooker please
Flavel : Manuals
www.flavelappliances.com/Products/Manuals
If you've lost or misplaced an instruction manual to one of your Flavel products, don't ... Electric Fan Oven with Separate Grill ... 60cm Side Control Gas Hob.
Sep 09, 2015 | Ovens
Bush AE66DCA cooker main oven wont come on
Hi guess you would have got your cooker fixed or replaced by now but I thought I would comment as we have had the same problem.
First I checked the bulb inside the cooker to see if there was a fault but the bulb was intact, I then checked the cooker over visually inspecting suspect broken parts I noticed the Thermosat control (3rd in from left hand side) wasn't turning properly so I ordered a new one. Couple days later it arrives and I remove the old switch and replace (very simple task) once the cooker is apart I get it all back together and it still doesn't work. So I grab my multi tester and perform a continuity test on the elements which proved to be normal range (43ohms was the reading). I was stumped. I began checking the whole cooker wiring and checking everywhere for a fault. After some time I notice a abnormality inside the main cooker control (2nd from the left hand side). Under closer inspection I realise one of the brass pins and spring has dislodged and no longer giving an electical connection. After ordering a new switch I stripped the old one and replace the pin and spring and rebuilt for a temporary fix. Rebuild the cooker and hey presto it works. Couple days later new switch arrives so I changed them over. Touch wood nothing else goes wrong but there's not much to them once they are apart.
Hope this helps others with their problem.
Feb 03, 2014 | Ovens
Flavel cascade 100 fan oven not heating, but fan still going. Grill and other oven still work. Is the oven lamp in the circuit? That has blown so just wondered if the two things are linked?
Heating element has blown IRCA Type RL6 1800W Remove back panel unscrew 2 screws remove the 3 conected cables open oven door remove 2 screws at rear of oven that holds faceplate in place remove face plate and take old element out and replace with a new element
Oct 08, 2013 | Ovens
Cooker flavel milano 60 4 years old Oven working fine, but grill makes problms.may be i am not using right method. Actually every thing is fine, but when i start grill and close the grill door its fir
Hello, you're probably not getting enough air in to keep the flame sustained, check for an outside air tube that might be clogged, if not than try keeping the door a crack open. Hope this helps
Oct 19, 2012 | Ovens
I have a cooker model venezia FE 8622EX and i dont have a manual for it and cant work out with knob does what as the writing is rubbed off through use...please help!
The 3 knobs each have 6 positions corresponding to clock-face positions 2,4,5,7,8,10 o'clock.
Left - Grill Temperature 1-6. (Note Oven Temp needs to also be turned on before grill will work.)
Centre - Function
1 - Lamp
2 - Defrost (fan only)
3 - Fan Assisted Oven
4 - Grill
5 - Grill with Fan
6 - Fan & Bottom Element
Right - Oven Temp 50,100,150,200,250,Max (celsius)
Sep 12, 2011 | Ovens
Have a new electric cooker but the oven and 1 of the hob plates isn't working dc5422 beko
hi chances are that the internal thermal cutout fuse has gone this fuse is situated on the right hand side of the cooker when you have taken the back plate off about half way down it has two wires attached to it and is screwed with a self tap on the right hand corner of the body of the cooker near the middle of the cooker. You can buy this part and have it delivered for about £6 so is a very cheap fix.
Sep 17, 2010 | Ovens
Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Aug 26, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Oven does not heat up
Generraly speaking, if the fan is working o/k , then it is more than likely that the oven element is faulty, and will need to be replaced.
Please rate my solution.
Thanks.
Aug 06, 2009 | Ovens
PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Thanks.
Apr 27, 2009 | Bosch HBL 5032 Electric Single Oven
Ovens Logo
2,365 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
