Question about T-Mobile Sidekick ID Cellular Phone
How insert sim card
How i can insert sim card on my sidekick
    President:
  • 625 Answers
Which Sidekick?
Posted on Apr 23, 2008
Sidekick id
Posted on Sep 29, 2008
HOW DO I DELETE EVERYTHING ON MY SIDEKICK 08
Dear Friend,
  1. Remove the battery and the SIM card from your SideKick .
  2. Flip the sidekick open; press and hold the letter 'r' on the keypad.
  3. While holding the letter 'r' on your SideKick , place the battery back in the device. DO NOT INSERT THE SIM CARD YET INTO YOUR SIDEKICK.
  4. The sidekick will restart itself twice. Please make sure not to let the letter 'r' go until it has fully rebooted.
  5. Once your cell phone has fully been rebooted, remove the battery, re-insert the SIM card and battery and power up the SideKick.
  6. Once the device has fully rebooted, all prior information should be erased from the device and it should be restored back to the default factoy settings.
I hope This Helped You... If this Helped you Do RATE ME..... I like TO KNOW your Result / FEEDBACK Thanks For Using FixYa..
Apr 14, 2010 | T-Mobile Sidekick
How to open sidekick and get my simcard out
The SIM card door is covered by a rubber casing that peels back. Pull back the rubber flap to access the SIM card door. The flap that needs to be pulled back is the top left corner of the Sidekick above the Menu key.
Insert the SIM card into the slot with the gold contacts facing up and the cut corner facing out. When you release the SIM card, make sure it is locked into position behind the catch so it does not spring out. Replace the bumper, and then turn on the device.
It appears that inserting the SIM into a Sidekick is a rather tricky process. If the above does not completely solve your problem, here is a link to more details on inserting the SIM card. http://support.t-mobile.com/knowbase/root/public/tm50134.htm?
Nov 26, 2009 | T-Mobile Sidekick II
SIDEKICK LX
Here is your solution:
Now follow these steps to a "T" don't do any shortcuts etc, this is "across the board" for all sidekicks it worked on my Sidekick Slide and on my Sidekick 2008.
1. Remove battery and the SIM card from the devise.
2. Flip the sidekick open; press and hold the letter "r" on the keypad
3. While holding the letter "r", place the battery back in the device. DO NOT INSERT SIM CARD YET.
4. The Sidekick will restart itself twice. Please make sure not to let the letter "r" go until it has fully rebooted.
5. Once it has fully rebooted, remove the battery, reinstall the SIM card and battery.
6. Power up device.
7. Once the device has fully rebooted, all prior information should be erased from the device and it should be restored back to the default factory setting.
Oct 03, 2008 | T-Mobile Sidekick
Sidekick 2
Sorry, the sidekick II doesn't have a battery that can be pulled out. You need to pull back the bumper on one side to access the sim card slot.
    1. Follow these instructions to remove your operator-supplied SIM card from your device:
    2. Turn off your device by pressing the power on/off key.
    • Expose the SIM card slot by peeling back the bumper from the top-left edge of the device: t02005-2.jpg
    • Press down on the silver "catch" and the SIM card will spring out of its slot. Remove the SIM card carefully. (Always handle your SIM card carefully since the card and gold contacts can be easily damaged by scratches or bends. Be sure to keep SIM cards out of reach of small children.)
    1. Now insert the SIM card containing the contacts you want to import:
    2. Insert the SIM card into its slot with the gold contacts facing up and the cut corner facing out. t02005-1.jpg
    • When you release the SIM card make sure it is locked into position behind the catch so it doesn't spring out.
    • Replace the bumper and turn on your device.
    GrinningFool
  • www.repairmysidekick.org
  • May 09, 2008 | T-Mobile Sidekick II
    Installing sim card in sidekick II
    Hi
    I can't find where to locate the sim card for a sidekick II mobile, can you help?
    May 03, 2008 | Motorola Mobility V180 Cellular Phone
    Sim card not found
    clean sim cart and simcart compartment.
    Jan 03, 2008 | T-Mobile Sidekick II
    Used Sidekick
    Call your carrier and ask them to detach your device IMEI from the username locked in. Once that is done, hard reset without your SIM card inserted
    Jan 02, 2008 | T-Mobile Sidekick ID Cellular Phone
    Sidekick
    The SIM card slot on a Sidekick II is located on the top left corner of the device, under the rubber "bumper". The support section of T-Mobile's website has a diagram showing how to insert the SIM in a Sidekick 2.
    Dec 06, 2007 | T-Mobile Sidekick II
    hello, hope these instructions help: 1. To expose the SIM card slot, peel back the bumper from the top-left edge of the device. (fig 1) 2. Insert the SIM into the slot with the gold contacts facing forward and the cut corner facing out. (fig 2) 3. When you release the SIM, make sure it is locked into position behind the catch so it will not spring out. 4. Replace the bumper and turn on the device. Any problems, let me know :) Si
    Oct 03, 2007 | T-Mobile Sidekick ID Cellular Phone
    T-Mobile Sidekick ID Cellular Phone Logo
    105 people viewed this question
    Top T-Mobile Cell Phones Experts
    Starnley Johnwells
    Starnley Johnwells
    Computer Repairing
    Computer Repairing
    Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
