Sharp LC-26SH12U TV. Sound has to be turned all the way up (50) to hear normally. Nothing but a DVD player connected - no cable, no regular tv. Using a composite cable. Troubleshooting done: tried a different cable, and different inputs - no difference connected a VCR to the TV - sound worked fine, maximum blasted me out of the house connected the DVD to an older TV - sound worked fine. ??
  • Anonymous Nov 21, 2008
    Weak sound. Has to be set at 40-50 in a bedroom!
My Sharp TV LC-26sh12U when at 50 is not good. After a hour or two I can hardly hear the program. What is happening?
Posted on Jul 09, 2009
SHARP LC- 26sv490u And trying to connect a Toshiba
Sounds like a preamp circuit might be blown on the Sharp.
Nov 17, 2017 | Audio Players & Recorders
My LC-26sh12u takes 10 minutes to
I had a similar problem where it displays "PLEASE WAIT" for several seconds alternating with blocky colors for several seconds and continuing anywhere from 5 to 30 minutes.
I inferred from a couple of sources that the TV is booting up when it says "please wait" by reading data from flash memory. I was able to fix my problem by resetting the data in memory to factory default values using this procedure from the service manual (wait until the TV is working before trying this):
Turn on the POWER.
Set the VOLUME to minimum.
Press both VOL. DOWN button on the set and Channel button (1) on the remote control for more than 2 seconds.
After the finishing of the initializing of shipping, the unit will turn off automatically
Nov 21, 2009 | Sharp Televison & Video
TV going black still hear sound
I suspect if you are using the DVD to play via a Scart connector , then the problem is simply that the Scart cable has became a bit slack. Try taking the Scart out of the rear connections from the DVD & the TV & then just pushing them back in again to make sure they have a good contact.
Apr 04, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos TV will not display contents of DVD using Microsoft Media Player 11
it sounds like a problem within your vga connection on the tv check around and see if there is some firmware for this fix or right click on your desktop were there is no icons and select properties select settings tab and set ur display as needed.
C
Oct 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Volume not loud enough
are you watching movies frm a dvd player with the sound up, if so, turn the sound up on the dvd player remote and see hwo that works. eor, if its movies on normal tv screen, go to settings and click booster sound too hear better. if yours does not have this, ring your manufacture for a refunded tv with better speakr sound quality.
Oct 01, 2008 | Sharp Aquos LC-32D40U Television
Sharp Aquos LC-26D4U sound problem
You want me to tell you how I fixed it for free, but you don't want to help me for free. What's with that?
Aug 01, 2008 | Televison & Video
'SHARP LC 26SH12U' & Philps DVP 5160
sounds like you are using standard audio/video cables (yellow, blk., wht) in the component conections on either the tv, vcr or dvd player. If you intend on using component connection you will need to use different cables.
May 04, 2008 | Televison & Video
Toshiba HDDVD Player Model HD-A3
well your TV has a 1920 x 1080 Pixels hi resolution is this what you mean?
I would hook up your HDDVD via HDMI to the TV and the regular DVD to Component1 on the TV,
hope this helps
Jan 13, 2008 | Sharp LC-45GD7U 45 in. HDTV LCD
Televison & Video Logo
392 people viewed this question
Top Televison & Video Experts
