Question about Canon FaxPhone B95 Plain Paper Inkjet
I've refilled the ink cartridge & have not been able to decent copying quality since. I've clean the cartridge a number of times & still get broken copy. When I took the cartridge back to the vendor they told me there were no problems with it. Is there a setting I'm missing or a way to align heads, etc. Please advise.
    Problem Solver:
  • 9 Answers
If you are using refills the first thing i would do is take them out and buy originals as when you get them refilled that all they do is refill them. they do not replace the printhead which seems to be the problem you have
you can also scroll through the menu to clean and algin printhead
Posted on Jun 14, 2008
My workforce 520 printer renders illegible document printing and copying. my alignment page is not sharp either. should i trash it or can it be rehabilitated?
Factory reset, and then clean your printhead with the built in cleaning protocol. Make sure that the print quality on your computer is set to the highest resolution (best DPI) and best quality setting (usually image) that will fix the problem but also significantly increase the ink usage.
Note: using non-standard ink (ie Cartridge World ink or recycled ink cartridges, or refilled cartridges) can lead to poor print quality.
Jun 07, 2015 | Epson Office Equipment & Supplies
Poor print quality
Make sure you are using genuine Lexmark cartridges. Lexmark products work best with original supplies. Lexmark does not recommend the use of refilled, re-manufactured, or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark.
Check your cartridge ink levels. From the printer operator panel, go to Maintenance > View Ink Levels. Replace the cartridge that has low ink level. If your ink levels are still substantial for printing and you are using genuine Lexmark supplies, please contact Lexmark Technical Support Center for further assistance.
Dec 28, 2011 | Lexmark X9350 All-In-One InkJet Printer
I have refilled ink in my cartridge but when i try to print nothing comes out i.e it gives faint copies
Ink is full but nib is faulty will pen writes? similarly cartridge refilled with ink but nozzles are clogged/blocked then print wont happen properly..before refilling the cartridge check nozzle status, clean nozzles properly then refill it. Remedy1:Take little warm water pour in small container dip nozzles in water wait some 2-3 minutes clean nozzle area with dry smooth cloth...try it till print quality improves..Remedy2: You can do clan/align process through printer drivers properties..
Nov 15, 2011 | HP LaserJet M1522nf Multifunction Printer...
I have try to print but its not printing. i've allready fill the ink still the page come out blank.
It could be due to the refilled cartridge that you are using. Refilled cartridges tend to degrade print quality and cartridge performance.
You can try to clean the cartridge nozzles. Please follow the steps below to fix the problem:
  1. On the printer control panel, press Copy.
  2. Press Options until Maintenance is highlighted.
  3. Press the right arrow until Align Cartridges or Clean Cartridges appears, and then press Select. A test page will then be printed forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that the cartridges are working.
If that doesn't help, I would suggest you replace your cartridges with new genuine Lexmark cartridges.
Aug 17, 2011 | Lexmark X6150 All-In-One InkJet Printer
My printer dont print right it skips and i just put a new refill in
It could be due to the refilled cartridge you are inserting in the printer. Refilled cartridges tend to degrade in print quality and cartridge performance.
You can try to clean the cartridge nozzles. On the printer operator panel, on Copy mode, press the Menu button > Tools > Maintenance > Clean Cartridges. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that the print quality has improved.
If that doesn't help, I would suggest you replace your refilled cartridges with new genuine Lexmark cartridges.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
Uneven printing]
Your cartridge is not able to supply that density of ink for that number of lines of solid color.
Could be any of the following:
1. Dirt in the cartridge
2. Low ink level
3. Bad ink in a refilled cartridge
Solution:
1. Print 1 copy in "draft" mode to see if cartridge can keep up. If so, it is simply ink supply... Replace cartridge, refill cartridge.
2. Run the "Clean" maintenance routine before trying to print a strong demand image.
3. Replace the printer for a quality image device (laser is best, all others are less). Good quality HP is better in inkjets. Decent Lexmark is fair - but VERY expensive to own/run/maintain. Kodak is cheap enough to buy and keep filled. Reliability is a potential problem...
Hope this provides some useable insight. -Jim
Oct 23, 2009 | Computers & Internet
How to reset the ink level for a HP 60 ink cartridge? I have just refilled a HP 60 black ink cartridge but can not find anything on how to reset the ink level. I would do the "3 ink cartridge" trick but I...
You cannot reset the ink level indicator for the HP 60 ink cartridge. It shouldn't matter anyway because the level is only estimated for "management purposes only" (see user manual) meaning to let you know when it's near time to order a new cartidge. I have tried cycling through 3 different cartridges to reset the ink level for the one I refilled but it didn't work. Refill and just ignore the ink level indicator. Also, it's a good idea to clean the print heads with the solvent in the refill kit before refilling to remove old ink and imrpove print quality.
Apr 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
WHILE TRYING TO FIGURE OUT WHY MY PRINT QUALITY IS SO POOR. AFTER CLEANING THE HEADS A FEW TIMES I WENT TO PRING A "QUALITY TEST PAGE". The MFC said i was out of paper. i refilled the paper (with the...
the messages you get for cartridges other than the original are not trustful. You will get the right reading for original(from Brother) cartridges. Some ink is poor for printing photo quality.
not any refillable ink is right for printing photos, sometimes too dark, sometimes you don't get the right mix of colors.
Mar 30, 2009 | Brother MFC-5840CN All-In-One InkJet...
Some print lines fade out making a poor copy
If you are seeing lines it is the cartridge and it's bad.
Refilled cartridges usually only work about one time and then the cartridges run into problems. They either leak or the cause lines in the copies.
If you can return and get a non refilled one, that should work.
May 20, 2008 | HP DeskJet 5550 InkJet Printer
Canon FaxPhone B95 Plain Paper Inkjet Logo
57 people viewed this question
old marine
old marine
