Question about Fantom Vacums Cyclone XT Upright Vacuum
Fantom cyclone belt status light
I bought this vacuum at an estate auction so i have no manual. It worked well for a while then the roller quit working the belt status light is on. I have taken off the cover but the belt is intact. So do i change it or is this a bigger problem?
    President:
  • 1,673 Answers
The belt may have stretched to the point that it won't turn the brush roll, you might try a new belt and hope that fixes it. Parts for these older Fathoms are scarce and are obsolete.
Posted on Apr 24, 2008
Euro-Pro Fantom FC-251 Canister Vacuum; Bought one of these 'gently used' at an auction. Would like a user manual if available.
You can download the manual by following the instructions on the following link. I used the security code to download it.
http://safemanuals.com/314159.php?k=4789186c8ac87e31888cf7e7294a3bd7&ID=347344&q=FANTOM FALCON FC251
Jan 08, 2011 | Euro-Pro Fantom FC-251 Canister Vacuum
Replace belt on fantom cyclone vacuum? the manual does not decribe replacing the roller belt - i can't get it open to expose the belt
On my 10-year-old model, the two screws securing the cover are under the two llight bulbs. Pry off the clear plastic covers, take out the bulbs and screws, and the cover lifts off.
Dec 01, 2009 | Fantom Vacums Cyclone XT Upright Vacuum
How do i replace the belt on my vacuum
There are two black screws on the back of the hood top that need to be taken out and then the top hood will come off forward. Then you can see the belt and rollerbrush. Slide to rollerbrush out and put on a new belt to the motor pulley and then put belt onto the roller and insert it back into the nozzle housing
Nov 26, 2009 | Fantom Vacums Cyclone XT Upright Vacuum
My Fantom Fury upright beater bar stopped working.
Hi at the bottom of the vac were the roller brush is there is a cover you would have to take that off and then you will see were the belt is located
Oct 07, 2009 | Fantom Vacums XT450K Upright Vacuum
How do i replace the belt in the Fantom Cyclone XT vacuum
remove the covers over the headlights and under the shiny foul. there are two screws. there are two tabs that hold down the cover over the wheels, they just pop on/off with a click.
on my xt. i had to remove the rolling brush and clean out all the hair that was stuck in the bearings. remove the screw holding down the motor and belt. pry out the roller brush to get to the bearings. there was some serious hair ball in there.
reassembled mine and it works perfectly now :)
Dec 19, 2008 | Fantom Vacums Cyclone XT Upright Vacuum
Fantom cyclone xt quit working in the middle of using it
you probably have a broken wire in cord or the power switch has gone bad two options take it to qualified electrical repair shop or if you just purchased it recently return it to the store also try another appliance in same outlet to make sure you havent thrown a circuit breaker hope this helps
Aug 20, 2008 | Fantom Vacums Cyclone XT Upright Vacuum
Fantom Cyclone XT Vacuum Cleaner
Here is the owners manual which goes over some troubleshooting problems.
http://www.fantom.com/fantom/manuals/Cyclone.pdf
At first I would think it was the thermal overload, which is covered in the manual. But I would guess that you have let it sit for 30 minutes to cool down and tried again and the vacuum still didn't work.
I would think you may have one of four problems.
1. Your thermal overload was tripped and is stuck and will need replaced.
2. You have a clog in your vacuum lines or the brush roller is froze, which keeps causing the thermal overload to trip.
3. Your power cord has a short, which would need replaced.
4. Your power switch is bad, which would need replaced.
Out of these 4 possible problems I would say the only one you could fix on your own would be problem #2. Make sure the vacuum is unplugged and take the brush roller off and clean it, make sure it moves free. Check your vacuum lines to make sure you do not have a clog, other wise the motor does not get air flow to cool it down causing the thermal overload to trip. As for problem 1, 3, and 4 I would suggest taking it to a repair shop.
Hope this helps, post back.
Jul 11, 2008 | Fantom Vacums XT450K Upright Vacuum
Broken Belt for Fantom Crosswind 600XL
Hello, your Fantom vacuum will take a Panasonic U vac belt, to replace it, their are two screws in the back, one on each side of the back of the housing, take out the two screws and lift off the top hood, and the vac belt is on the side, remove the brush roller clean any debis away, put the new belt around the metal motor shaft first then around the brush roller, and pull down into the housing, make sure it locks in evenly, then turn the roller to make sure it moves freely. then put the hood back on front first, hold down and put the screws back in, in the back. now your ready to vacuum. Any question or more help I can give, please call 1561-848-3387 Thank you, Teresa.
Jun 16, 2008 | Westinghouse WST1550 Wired Deluxe Upright...
Fantom Vacums Cyclone XT Upright Vacuum Logo
178 people viewed this question
Top Fantom Vacums Vacuums Experts
Richard Agent
Charles T Nevin
Charles T Nevin
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
