I am building my own speaker for he first time.i have 2 subb woofers/mid and tweeter but only ave three way cross over what would be the best and safest way of wiring up the speakers?
  • 88 Answers
Hi first thing: do you have a passive or active crossover??
  1. Passive crossover: you can connect the two output together to your subwoofer to have in the same time the low bass and the mid range of frequency.
  2. Active crossover: NO solution you have choose one out put of your crossover, i guess the best is the low output, but the choice is in your hand try the the two output(low/mid) once and choose the best for you
Let me know, bye
Posted on Apr 23, 2008
What can cause a sub woofer and room speaker woofer to stop
Check wiring for loose connection...may have to open speaker enclosure.
Jan 04, 2016 | Velodyne CHT-8 Subwoofer
Hi,i hear alot about bi wireing could someone explain what it actually is used for and what's it meant to do could I'm thinking bout trying it on my speakers?
It's a big job, but the results are great. Bi amp-ing is where the tweeters and mid range speakers are separated and connected to separate amplifiers. You'll need to have the correct gear before messing inside your speakers. You'll need to have another amplifier. Not knowing what amp you have now, getting a stereo signal into the second amp may be a problem since you'll need a line level signal into the second amp. An external crossover is best. Technically, you could use the ones in the speakers, since you'll be removing them anyway. Now for the speaker mods: On the panel where the posts for the speaker wires are you'll need to install another set of binding posts. We're assuming you have separate subs. Open the speakers and remove the cross over. The wires from the original posts should now connect to the mid range speaker. Add wires from the second set of posts and wire it to the tweeters. Now connect the output of the amp to the removed cross over and wire the mid range out on the cross over to the posts that connect to the mid range speaker. Do the same for the tweeters.If you have three way speakers, you'll have to run a 3rd set of wires from the crossover to the woofers in the cabinet using another set of binding posts. Controlling the volume on the second amp will be difficult since you'll have to adjust it manually. Remote control volume level will be lost on the second amp.
Aug 08, 2015 | Audio Players & Recorders
What is the impedance of the midrange speaker and the tweeter speaker in the Pioneer cs r5100 ? I have the crossovers and the woofers I use for my front channels (L&R)
If you are running three 8 ohm speakers in parallel then the total impedance would be 2.667. If running two 8 ohm and one 6 ohm speaker in parallel you would have 2.4 ohms. This will burn out your amp pretty quick. And very possible won't play at all. Though I have never attempted to play a home amp down that low in ohms. Guessing you may have an older model Denon type amp.
Aug 01, 2014 | Pioneer Audio Players & Recorders
Diamond 8.4 serie are there 2 way or 3 way
These speakers are 3-way there are 2 woofers and 1 tweeter per speaker. Here are the technical specifications of each speaker:
Two 6.5-inch Kevlar woofers and 1-inch silk-dome tweeter per speaker
86 dB sensitivity
20 to 150 watts recommended power (per channel)
6 ohms impedance
30 to 20,000 Hz frequency response
Please rate my answer if this helps.
Many thanks,
Chris
Mar 02, 2011 | Wharfedale Diamond 8.4 Main / Stereo...
I need recommended factory specs for this 10 inch Sub woofer (I am building my own box)
depending on the make of speaker there should be a minimum of 3.1 ltrs and no more than 5.4 lts with 2 32mm set 4 inch subb ports
Dec 22, 2010 | Car Audio & Video
Testing this item
Depends on the mid-woofers you're using. I'd use the cross-over with the mids too first. Exparimenting won't hurt, just make sure the tweeters are run through the cross-overs or you'll smoke them quick.
Apr 18, 2010 | Kicker KS13 Car Tweeter
I have a Cerwin Vega E-315 speaker and the Woofer has stopped working. The Tweeter and Mid-Range still work just fine. I just do not get any sound from the Woofer.
Pull speaker so you can get to the terminals in back. Take an ohm meter and check the ohms of speake, a 4ohm speaker could measure up to 5ohms and still be good. If the reading is way off then it is blown. If speaker is good, then check the cross over thats in the speaker, some models put fuses on the units for protection, but mostley on the high frequency of the cross over, not the low.
Mar 06, 2010 | Cerwin Vega E-315 Speaker
I have floor speakers that i replaced all the speakers in it with 4 ohm speakers and i just bought a onkyo receiver n it gets really hot and shut off 1 time....i was wondering if there is a way to wire it...
Home audio is typically 8 ohms. If the speakers you used were designed for mobile audio then this would be why the receiver is overheating. You may be overloading the output
Dec 04, 2009 | Audio Players & Recorders
I have a kenwwod AX-7 home theatre systems. the right side top speaker (tweeter) on one side does not work. i'm thinking there is a fualt with the amplifier on the right side.
If the only problem is the tweeter, and the woofer is still working, you do not have a problem in the amplifier. The problem is the speaker. The tweeter is blown or you have a problem in the cross over network in the speaker.
You can always switch the speakers and connect them to the opposite channel. You can do this very easy at the back of the receiver where the speaker wires are at. Put the left speaker wires on the right speaker and the right speaker wires on the left speaker. If the same speaker still has no tweeter you know that the speaker is the problem.
The only way this could be a problem in the amplifier is if you have two different sets of inputs for each speaker, one being the low end for the woofer and the other being the high end for the mid range and tweeter. That would mean you have two sets of speaker wires going to each speaker. Each set of speaker wires would have a positive wire and a negative wire for a total of 4 wires going to each speaker. I don't remember this system being set up that way, but I could be wrong.
I hope this was helpful, you should be able to get the speaker fixed at an authorized Kenwood repair center in your area for a reasonable price. As a guide, my shop only charges $25 for the labor plus the cost of the tweeter to replace a tweeter. Any other shop should be similar. Kenwood does sell replacement drivers for almost all of their speakers.
Jun 21, 2008 | Kenwood Audio Players & Recorders
Bi-amp
After examining a picture of a 5802 ( I have been servicing adcom for over 20 years ), these are not bi amp posts, but bi wire posts.
Bi-amp means that 2 amps are being used, one for highs, one for lows. This means that you have no crossovers in the speakers, instead, you have an electronic crossover between the amps and the pre-amp. The highs and lows are separated in the electronic crossover. One amp handles the lows, one handles the highs.
Bi-wire means that you have the crossovers still inside the speakers. The amp handles the full range of music ( highs-mids-lows ). Different kinds of speaker wire produce different results. If you have bi-Wire terminals on your speaker, they come with shorting wires, that tie the tweeter + to the woofer + on the back of the speaker, and the tweeter - to the woofer - . When the shorting wires are removed completely, you have now electrically separated the tweeter and woofer from each other, while maintinaing the crossovers ( inside the speaker ) for each.When this is done, you can now bi-wire the speakers and amp, and use different kinds of wire for the lower frequencies and the upper frequencies, depending on your ears ( everyone hears a little differently, thats why there are so may makers of components, and wire ).
Why do we have crossovers?.....the tweeter voice coils ( the things that make the sound ) are made of hair thin wire. This wire cannot handle much power and if you were to put bass in to a tweeter, you would burn the tweeter out almost instantly. A tweeter is a very light, fast moving device which can react very quickly to high frequency sounds ( symbols, triangles, guitar strings....). Woofers are more rugged. They have voice coils made of heavier wire and are designed for larger movements that Bass demands. Subsequently, woofers aren't very good for high frequencies because they are slower devices.
So what do we do ?.....Keep the lows away from the tweter and the highs away from the woofer.....thats the job of the crossover.
In the event that your speaker has the crossover OUTSIDE the speaker box, you should check ( as always ) with the manufacturer of the speaker to see how it can be changed to suit your needs. Remember to always read and follow your owners manual. Good luck....Rob
Feb 22, 2008 | Audio Players & Recorders
204 people viewed this question
 Grubhead
Grubhead
