Question about Karcher 2500 PSI Pressure Washer
Tractor mower failing to collect grass
I just acquired a used tractor mower, only 3 years old. The grass collection sometimes works perfectly (I get an alarm when the bag is full) but, more often, fails abysmally, leaving all the grass behind. I cannot see any seal looks as though the bag is clicking into place very snugly.
I have the grass height set very low. The problem is worse when the grass is longer (I see long lines of left grass where I know it's been growing at its longest). What am I doing wrong? Thanks for any help you can give me
Sorry I had to choose a pressure washer...there was no match for my lawn tractor, which is a HONDA 2417 HTE
  • 33 Answers
Ok i need to know what kind of collection sys. you have.if there is an electric blower type system it may be that the blower isn't working. if the system works by the blade blowing the grass up the chute then you may want to check the blades to see if the up turned tabs on the back of the blades are still there and not broken off. also if your mowing too fast the chute gets clogged and the grass just balls up onder the deck ubtil rolled out.if a blower type set up check to see if there is a fuse to the blower motor.
Posted on Apr 21, 2009
The grass collection tube keeps getting plugged up and will not pass into collection bins.
Tom, Grass chutes get rough on the inner walls of chute over time, try to wipe/scrub inner chute the best you can. After thoroughly clean and dry, try and wax and buff inner chute with car wax the best you can, so chute will be a little more slippery and expel grass better. You may have to do this once or twice a season. Good Luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 16, 2016 | Garden
My ride on lawn mower is cutting out every time i try to engage the cutting blades
Sometimes it is due to the ETHANOL fuel you are using. ETHANOL is attracting moisture and after a while it builds up water in the tank.
Jul 06, 2015 | Garden
Why is my flymo 360 eg not collecting the grass
If you have changed blades or have low lift blades this will be the problem. For good grass collection you should have high lift blades
Apr 30, 2014 | Garden
LA 140 48 inch deck front blow out
This is going to be something custom-tailored to your equipment set up as well as your turf/landscape.
These things are never a perfect system, either, so keep that in mind, too. First, I'd go to your blades. You want to make sure you have enough lift to send clippings up the chute efficiently, but little enough to not try to overpower that same chute.
My run-of-the-mill blades have too much lift at first to be used with a collection system on any brand of my mowers. I have to run them a good week or two before they'll grind down to a reasonable level. After that, they run for another month or so just fine.
What kind of grass are you cutting? My suggestions are best suited for Northeast Florida and the grasses that are common here. Your situation is different at least in some way, so expect different resultes.
Oct 17, 2012 | John Deere 420,1020,2010,2020,2510,2520...
Craftsman riding lawnmower won't bag grass
A very common problem since mowers were made noise compliant, to collect grass you need draught, this is produced by putting a large wing on the ends of the blades and having a high engine speed, unfortunatly large wings and high engine speeds mean high noise, so today the wings are very small and the engine revs low, this leads to low draught and grass blockage, you need to keep the under side of the deck clean and free from old grass clippings, make sure the machine is fitted with collection blades, not mulch blades, i cannot tell you to increase the engine revs, however if for some unknow reason the engine were to start reving higher it would help.
Oct 13, 2012 | Craftsman Garden
My 2 year old Husqvarna riding mower, with the welded steel deck, has the mulch kit installed ( I installed it). When cutting, the mower ususally leaves a thin line of uncut grass. More, when the grass...
I too have had that same problem. I found that "old" blades when repeatidly sharpened and worn will cause the same problem, also aftermarket blades instead of original manufactures recommended blades may not be dimensionally correct, too short. I have had to go back to using original blades to correct the problem.
This should work for you.
Good luck.
Sep 06, 2011 | Husqvarna Lawn Tractor  25 HP 54in Deck...
I've got a simplicity 3415 , that has the hydrostatic . Recently , I was useing it when it stopped pulling , I checked the fliuds they were all full. what can I do to fix this problem ?
You didn't mention how old the tractor is, but if the tractor has been used for several seasons I would suggest draining the transaxle and cleaning the filter. Refill the transaxle with fresh hydrostatic oil and a seal conditioner.
Many times as the tranaxle components wear the metal shavings collect around the pumps sump filter and begin to restrict fluid intake. As the mower is in use the metal particals that are circulating in the oil collect on the filter, it slowly begins to plug of the supply and the tractor stops.
Good luck.
Dec 03, 2009 | Garden
Stopped to empty bag now won'tstart.
Sep 27, 2009 | Garden
Can a mulching blade work in a non-mulching mower?
True Mulching mowers have a specific deck design to them, but I would say yes to your question.It's been quite a few years, but I have done this little conversion myself - replace regular blade with a mulching blade. Just make sure the mulch blade does fit your mower. Also, use something substantial in terms of strength to close the discharge opening. There can be a good deal of force placed at the opening from flying debris. You'll also want to make the cover removable, so you can mow damp grass without the cover.
Jun 02, 2009 | Garden
Karcher 2500 PSI Pressure Washer Logo
115 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
