Question about Yamata FY700 Mechanical Sewing Machine
Do you have an illustration of the correct needle install for a Yamata YF5318 Sewing machine? It is an industrial walking foot. Thank you...
  • Anonymous Mar 12, 2014
    I need needles for my machine; 1 1/2" long by 1/8 round
    Problem Solver:
  • 14 Answers
You can get a pretty detailed instruction/manual here for the FY5318. http://www.feiyueusa.com/Manual/92966.pdf
The 92966 is the FY5318 sold through Harborfreight.com
Posted on Jul 08, 2008
Why will the walking foot number 1/p60443 not work on my berina virtuosa160
Are you not able to attach it to your machine or does the walking foot not work properly once it is attached?
The number should fit your machine unless someone inadvertently sent you the wrong foot.
If it attaches but doesn't "walk" when you sew, then it is not installed correctly. Be sure the needle clamp screw is "inside" the C-shaped lever of the walking foot. Hint: it helps to tilt the walking foot when installing in order to get it in the correct position for attachment as well as getting the C-clamp around the needle clamp screw.
installing Bernina walking foot Google Search
Aug 07, 2017 | Sewing Machines
Why doesn't walking mechanism work?
if the pressor foot anvil doesn't move up and down /back/forth , the machine might be in "DARNING " mode this is usually a small button in the bobbin area , but some machines have them on the back of cabinet as well
Feb 26, 2016 | Sewing Machines
I have juki 1541 industrial machine needle want pick up bobbin thread??
Is your needle inserted correctly? Try taking it out and inserting again. Is your bobbing threaded correctly? Try taking it out and re-threading. You might also try cleaning the bobbin area. The only other think I can think of is that you may have the wrong needle in.
Feb 13, 2015 | Juki DNU-1541 Industrial Walking Foot...
Brother cs6000i thread tension issue
Logically, the top thread should not be affected by a walking foot as the thread operates independently of the presser foot.
Suggest removing the top thread totally from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Check that your walking foot is installed correctly--the fork-shaped piece needs to encircle the needle clamp screw.
If you continue to experience problems with the walking foot but none of the other feet, recommend contacting a Brother technician.
How do attach the walking foot Brother
Jun 26, 2017 | Sewing Machines
What size needles fit a Rex 26-188 walking foot machine?
16x63 needle system, unless it's been retimed for something else. Suggest you might want to find the dull, bent up or otherwise still intact needle and show it to your industrial supplier or repair person, so they can check for you.
Needle system tells you about the length and timing distance of the needle: see, e.g.: http://designer-entrepreneurs.com/blog/illustrations/Singer_Needle.pdf Size tells you about the diameter of the needle: here's a suite of home sewing machine needles, all of the same needle system, but one of the photos shows a comparison of sizes:
http://www.picturetrail.com/sfx/album/view/17206792
Jan 18, 2014 | Brother XR-65t Mechanical Sewing Machine
Where can I buy a needle bar for Yamata FY 5813 industrial sewing machine?
How about an industrial sewing machine supply? Allparts has some parts for Yamata... great folks to work with.
http://www.allbrands.com/search?search=yamata
Sep 24, 2012 | Sewing Machines
SERVICE MANUAL FOR YAMATA FY8700 INDUSTRIAL SEWING MACHINE
my thread deeps bursting, tension is normal. what to do?
Sep 24, 2012 | Yamata Sewing Machines
Yamata fy 5318 manual
I just received my FY5318. The manual has OK diagrams, but the text is Chinese. The Consew 205RB-1 is the same exact machine as the FY5318 and comes with the same manual but translated into English. It is downloadable from the Consew website.
http://www.consew.com/View/Consew-Model-205RB-1
Nov 17, 2011 | Sewing Machines
Bobbin case
Make sure there is no fabric or thread on the bobbin case shaft. Needle has to be in up position.
Feb 19, 2008 | Yamata FY811 Mechanical Sewing Machine
Needle won't move
Make sure the clutch motor is powering up. make sure voltage toggle switch is on 110v and not 220v. Also rotation set correctly. Independently, make sure the motor runs. With your hands and motor belt disengaged, attempt to turn the handwheel toward you. If it is moving, then make sure motor is running. It handwheel does not turn it could be the machine. Make sure the stitch length dial is set at 2 or 3 and not 0 or 5. That could be that problem as well.
Nov 03, 2007 | Yamata FY811 Mechanical Sewing Machine
Yamata FY700 Mechanical Sewing Machine Logo
323 people viewed this question
Top Yamata Sewing Machines Experts
Lyle Siemens
Lyle Siemens
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Douglas Plant
Douglas Plant
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
