Question about Compsee Apex II
Error Message When I turn on the scanner, * ERROR 44 * appears. Thought it might be battery related since they hadn't be changed in awhile, but that didn't help.
Click Alt R
Posted on Apr 24, 2008
WHAT IS ERROR E046 CANON SCANNER
E046 Main drive PCB
(Controller CPU judgment)
If a communication error occurs between
the motor or sensor and PCB, an error
message appears. If it appears, reset the
main body and computer power. If the same
error message/code still appears, check the
connection of the related part, and if it is faulty,
correct it. If there is no problem with connections,
replace the related part. For motors,
check the connected drive transmission parts
and operation check sensor as well.
May 12, 2014 | Canon Dr-7550c Color Duplex SCSI-Iii USB...
Error 44 precor eliptical 546
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Nov 22, 2012 | Precor EFX 546i Elliptical Version 4
Scanner error 5
The only fix that I know is to get the scanner/copier assembly(that's the assembly at the very top where the copier is) replaced.
I don't imagine that it is cheap. Get an estimate 1st.
Nov 12, 2011 | HP LaserJet 3055 All-In-One Printer
Canon MP 648 suddenly appeared a message: ERROR 5012, then after the power off and turned on again appears ERROR 5050. Printer error has occurred. TURN POWER OFF THEN BACK ON AGAIN. SEE IF THE PROBLEM...
From the service manual, both errors relate to the scanner unit:
[5012] An error occurred in the scanner FB motor.
(1) Cable connection (2) Part replacement: - Scanner unit
[5050] The AFE was faulty.
I don't know if the following YouTube video will help, but you could watch and see if it applies to your printer.
Error 5011 and 5012 Printer Canon MG 2570 MP 237 MP258
Feb 09, 2018 | Computers & Internet
I have not used the calculator for awhile.. it would not turn on, so i thought the problem was the battery, but now i've changed the batteries, it still won't turn on. what is the problem? how can resolve...
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Jul 21, 2010 | Texas Instruments TI-84 Plus Calculator
Hp 4600 error message 51.2c The message appears as soon as i insert the cyan cartridge. It was working properly but after printing 2000 pages (mostly blue color) there was noise and after that the message...
errors in the 51 range are laser scanner errors, it's saying either the laser is out or the scanner motor is not turning, or not turning fast enough. A good shop repair.
Aug 12, 2009 | HP LaserJet 4600 Printer
Brother Model DCP-340CW - Unable to clean
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
  1. Check for foreign objects, such as a clip or ripped paper, inside the machine.
    Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
  1. If the error continues to appear, the machine may have a mechanical problem.
    If the error message continues to appear, the machine will need to be reset. Disconnect the machine from the power source for several minutes then reconnect it.
If the message continues to appear on the LCD, please contact Brother Customer Service.
hope this helps please leave rating (vote)
Jan 26, 2009 | Brother DCP-350C InkJet Printer
HP 4400c scanner
I~m considering that you already have turned everything off (computer, scanner, all the power) and turned on again. Your parallel port may be damaged. You shoult try to use your scanner in another PC, if it works, you will have to replace the parallel port. (there are some PCI cards with parallel port, it´s cheaper than to replace the entire motherboard.
Apr 29, 2008 | Office Equipment & Supplies
"The Scanner has reported a hardware error..."
Version:1.0 StartHTML:0000000105 EndHTML:0000008195 StartFragment:0000002796 EndFragment:0000008159 Normal 0 0 1 464 2648 22 5 3251 11.0 0 21 0 0 I brought a coolscan 9000 the last month without the film holders, software etc just the scanner. A friend of mine sold me it for a good price. I run Leopard in a Powerbook G4 15” 1.2 ghz 2 Gigas ram. I installed the Nikon scan 4 and when I open it the scanner report an error: The Scanner has reported a hardware error... every time that I run the program this message appears. I thought that this was because I hadn’t got the film holders. When the film holders arrive from USA the same problem appears : The Scanner has reported a hardware error... Them I tried Silverfast Software. In this case the scanner report another error: there are not film holder ( or something like that). I uninstalled Nikon Software with the same utility to install it. Reinstall the Software and the same ****** problem. When I switch on the scanner a loud noise came from inside, after this the blinking light stopped and nothing happen ( no calibration, no light inside, nothing). Just one thing. The Scanner has reported a hardware error...
I checked on internet and the solution of switch it of and on doesn’t work. CALL TO THE NIKON SERVICE that’s was my only solution.
Of course I didn’t . The price of the scanner was 300 Pounds.
SO I OPENED IT.
I REMOVED THE SCREWS FROM THE BACKSIDE AND FROM THE BOTTOM OF THE SCANNER. I TOOK THE METALLIC CASE OF: PICTURE 1. After a while looking everything without touch I’m start to check for the connection cables one by one, WHEN DISCOVER THAT ONE CABLE PLUG THAT GOES FROM THE SCANNER TO THE FIREWARE BOARD WAS DESCONECTED…. PICTURE 2 Maybe on the shipping this plug looses his place. SO I SWITCH ON THE SCANNER AND THE PROBLEM DOESN’T APPEAR. Now the problem was that the film holder wasn’t recognising from the scanner. So I followed the steps that most frequently indicate on the web:
1-Close the scan program –
2-Turn off and unplug the scanner
3-Plug the LS9000 back in and turn it on
4-Reopen the scan program
The scanner worked. When I switch on the scanner take a minute or so to calibrate and determinate the film holder. Them I open the Nikon Scan 4 and every looked nice. I could scan my first negative ALELUYAAAAA. So I close everything without the screws so I put the scanner vertical to put back the metal case ones I finished I turned on the scanner and the Nikon program. For my surprise the same ******* error I couldn’t believe it.
I opened it again and I found the cause of the problem . BECAUSE THE SCANNER WAS ON VERTICAL BEFORE, THE METALLIC GUIDE THAT CONNECT WITH THE SERVO WAS MOVED (Move the scanner from one place to another may cause this issue) So with my finger I putted it in the same place. THE SCANNER WORK’S.
After this the only problem was a big loud gnashing and grinding noise that I sorted with CELOTAPE BETWEEN THE TWO PIECES THAT WAS SEPARATED BEFORE.
PICTURE 3
Now the scanner work fine. Sorry for my **** English and I hope that someone can find useful this information.
Feb 27, 2008 | Nikon CoolScan V ED Film Scanner
Dell A940 - Unlock Scanner then press power
See
http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
Unlock Scanner message
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Dec 08, 2007 | Dell A940 All-In-One InkJet Printer
Compsee Apex II Logo
198 people viewed this question
Top Compsee Computers & Internet Experts
David Payne
David Payne
Are you a Compsee Computer and Internet Expert? Answer questions, earn points and help others
