Question about Kitchen Ranges
I have an electric glass-top stove. I only use the cleaner on it when it has to be cleaned. There is a big black stain on one of the rings (not scratched); and a black circular stain on another of the rings. I cannot remove these stains and they look awful. The stove top cover is only about two years old; if that. What can I do to remove these stains without having someone come and charge me to fix same I certainly paid enough for it when I got it.
    Genius:
  • 1,073 Answers
You may try jewlers rouge the have it in the tool department at lowes in the dremel tool section it comes in a small bottle
by the way a little goes a long way, put a dob of it on a cloth and go in circles it should remove the ring it will take some time so be patient a lot cheaper than a new top
Posted on Apr 23, 2008
I love stainless steel appliances and have a lot of them at home. But, it is trouble cleaning them. They look really bad if they are not kept clean regularly. How can I get rid of the stains and marks on...
get a 'oxygen' based cleaner soak overnight.
normal cleaner works based on surfacetant. oxygen cleaners works by dissolving the stains.
of course, you can use some elbow grease and polish them.
Oct 16, 2013 | Ronco 'Showtime' Rotisserie and BBQ...
Hi, I have a wonderful Maytag speckled black smooth top stove. Over Christmas someone caused a big (2 " diameter) stain. I've tried everything to get it out. is it possible to have a new ceramic...
Ceramic cooktop cleaning tips - especially for 2-in difficult-to-remove stain:
Best Idea: "Cerama Bryte" + plastic scrubbie
Cerama Bryte is specifically designed for this cooktop, works on stains, avail at Hardware Stores.
Other ceramic cooktop tips:
1. "Soft Scrub" plasic scrubbie
2. Comet cleanser + sponge
3. Single-edge razor blade held at 45-degree angle - scrapes off material
4. "Cook Top" cleaner (WalMart) + Mr. Clean "Magic Eraser" abrasive pad
5. baking soda on damp sponge
6. soak stain for awhile with Formula 409, Fantastic, or citrus degreaser ("Orange Clean")
7. ammonia + water - in a 1:1 solution
8. Easy Off oven cleaner - it foams on the stain and does the work for you - let it sit 20 min.
9. the nuclear option:
Cerama Bryte under a plastic scrubbie under an orbital sander with sandpaper removed
(just the pad down on top of the scrubbie), after pre-soaking in Citrus Degreaser.
The sander is a power tool which only saves your joints, and speeds up the chore.
Jan 17, 2011 | Maytag MER5775Q Electric Kitchen Range
Stains on black enanamel stove top
use caustic soda power mixed with water and wallpater paste so its a thin jelly . apply with a brush and leave over night . rince with warm water on a clean cloth. use rubber gloves and glasses for protection
500g caustic powder
2 pints water
add wallpaper paste powder little at a time till jelly like
Feb 19, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
Good morning; We have a new Jenn-Air black glass
Any proprietary glass top cleaner should be suitable. Avoid using a wire based scouring pad but the Scotch type 'plastic/foam' cleaning pads are ok.
Jan 04, 2010 | Jenn-Air Ovens
Cant get food stains removed from top of stove i use a special cleaner and a special scrub and it still doesnt come off. it can be any kind of stain. the new stove tops are very hard to clean. any help...
I recommend a product called of all things "barkeepers friend". It comes in a can with holes in the top to sprinkle the powder out of.
Moisten the stubborn area and sprinkle this product on the stain then add enough water to make a paste. Make sure the paste covers the entire stain. LET IT SIT FOR AT LEAST TEN MINUTES. Then rub with a wet cloth. It always works for me and I have a black stove.
Jul 27, 2009 | Stoves 12 in. (1248-1100) Electric Cooktop
Puiter stain on stove top
ITS NORMAL FOR GLASS CERAMIC, NO KIND OF CHEMICAL TO CLEAN.
TNX GERBEE
May 26, 2009 | Jenn-Air JED8230 Electric Cooktop
How do i clean my flat stove top electric stove
There is a special solutiun to clean electrc stoves
Jan 18, 2009 | KitchenAid KESA907PSS Electric Kitchen...
Having trouble cleaning splatters off Ingis Glass Top Stove.
Use DeBruce Polish- a true multi-surface cleaner. There is a transfer of particulates from pan to glass surface aided by the heat. The cleaner will remove this "staining". Also use on stainless steel rubbing with the grain- this is the one product that truely cleans the surface. Follow up with baby oil or a stainless steel "polish that is oil based to "seal"the surface.
debrucepolish.com
Jan 13, 2009 | Maytag MER5730 Electric Kitchen Range
Stains on glass top
This is smooth glass - you can use a razor blade on it. Hope this helps!
Jan 13, 2009 | GE Profile Spectra JBP95 Electric Kitchen...
Cleaning
get some ceramic glass cook top claener.that will take care of it
Mar 28, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
185 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
