Question about GoVideo Go Video DVD/VCR Combo
Fast forward of Disk on my Go.Video2140
If I try to fast forward my disk, it skips to the next channel on the disk(about 5 minutes) -- If I do this on a vhs tape, it goes faster 2x, 4x like it should.
How can I fast forward on a disk rather than skipping forward
thank you
Ron C Rettus
Try keeping pressed the skip button to do fast forward on a Disc.
Posted on May 05, 2008
Shuts off when trying to play or record
This could be due to the VHS tape sticking on the tape reel, that triggers the overload and the shutdown. Try fast forwarding if possible.
Nov 01, 2017 | Emerson EV787 VHS VCR
The DVD part of the machine keeps skipping and now just won't play any DVD's.
I push the VHS Cartridge in, it drops down to the play position, the front door opens, the tape comes out, it goes around the chrome wheel that is spinning, but it will not play, will not rewind, will not fast forward. It then shows "Error" and the machine shuts off, with the tape still around the chrome wheel, When I turn the machine back on, the VHS Cartridge ejects from the machine. This machine has been used very little, I loaned it to my Son In Law and it came back with the VHS Tape Deck not playing. I have the machine open, so I can see what it is doing.
Dec 11, 2010 | GoVideo Go Video DVD/VCR Combo
TV is on channel. VHS player has tape for playback loaded. Player is on but when PLAY is pressed 5 seconds later it turns off by itself. Model number is DVP3200V/37. Can anyone help, please.
Dirty magnetic head. Run a commercial tape head cleaner through it. You can get one at the box stores. Also, put your tape in a tape rewinder and rewind and fast forward the tape for about 30 seconds. Sometimes the tape ribbon gets wound too tight or is loose. If these fail, then you have to open the unit up and clean the magnetic head manually with some isopropyl alcohol and cotton q-tips. Also, look for capacitors on the power inboard chip that look burned and replace them.
Feb 04, 2010 | Philips VR621CAT VHS/S-VHS playback VCR
Vhs tape won't play
sounds like to me the tape is to tight .try rewinding the tape all the way then fast forward all the way till it stops repeat and it should loosen up. if not the tape is no good the blue screen might go away after the tape is loosened n try cleaning the tape player good luck
Sep 19, 2009 | JVC DF420 D-VHS Tape
Won't recognize blank DVD+R disc
Try the next disc in the stack, and see if it will recognize the next one. If not, the problem is most likely the recording speed of the +R disc. Before you go changing disc types, however, I would also check the Record Mode you have set for the dub - if the REC Mode is set for XP, try changing the mode to SP and see if you have any luck. If it still won't work, try one of the tested +R discs:
SONY (2.4x, 4x, 8x, 16x)
TDK (4x)
Mitsubishi (4x, 8x)
Ricoh (2x, 4x, 8x)
-Tha Mp3 Doctor
Feb 14, 2009 | Philips DVDR3320 DVD Recorder/VCR
Forward fasts on its own
you may want to try fast forwarding at 2x (that is, press the FF key twice), although the speed will be faster, it may actually stop for you, when you press play, rather than going to the end.
Feb 05, 2009 | Arris DCT6200 DTV Receiver
VCR sv 670 wont play or fast forward tapes.
Open the bottom Cover, and check the belts.
Nov 29, 2008 | Samsung SV3000W VHS VCR
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
Problems with recording/rewind/fast forward
You probably have a bad power supply. But as you will learn, repairing any VCR will cost more than buying a new one.
Feb 17, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
GoVideo Go Video DVD/VCR Combo Logo
83 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
