Question about Black & Decker D2030 Iron
Iron is plugged in but does not heat up. I have tried multiple outlets
    Genius:
  • 1,142 Answers
Check the thermostat roll switch it must be turned down to off mode select the cloth type u want to iron thten it should work.
Posted on Apr 22, 2008
KOakaKO
  • 135 Answers
SOURCE: Light comes on, but iron will not heat up
No electricity is getting to the heating coil inside the iron. It has to be disassembled to find out if the heating coils are broken, or just not connected properly.
Posted on Aug 09, 2007
geox29
  • 65 Answers
SOURCE: Why isn't my Iron heating up?
I do believe the thermostat is defective.All the iron have a small thermastat top control the temperature and is working like a switch.If the switch don`t work get stuck on the same position.Unfortunatly sometimes is better get a new one themn fix an old one but this is The Market and nothing i can do personally.Also make sure the thermostat knob is working properly.If you hear a click when you turn is ok.
Good Luck
Posted on Jun 19, 2008
oliso iron turns on when plugged in green light flashes but iron will not heat up
Posted on Apr 11, 2009
  • 19 Answers
SOURCE: shark G1490 doesn't light up or heat up when I plug it in.
circuit board has shorted out that control iron functions or power wire lead has broke off inside of iron
Posted on Aug 16, 2009
reddyanantha
  • 205 Answers
SOURCE: My iron is not heating. Yes, it is plugged in a
hello mam
please change the thermostat of the iron and also check the heating element.
Posted on Oct 02, 2009
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
Jan 25, 2013 | Philips GC 2510 Iron
Is no workig i needcramic heat control
1. you need a multi tester.
2. check the power supply of your outlet, or check the fuse or circuit breaker.
if has power go to 3.
3.open the back of your electric iron, the end of the cord or plug. then try to check the continuity of two wires if any is open. if its open or no continuity replace the cord or plug, either cut the only open wires and reconnect it again.
4. Or check the heating element of your electric iron if no resistance replace the heating element or you buy a new one.
Feb 16, 2011 | Conair Irons
My Rowenta iron will only heat when plugged into one specific outlet (other things work in the outlets that the iron "doesn't like"), and sometimes it will only heat if you giggle the cord around a bit in...
Sounds like the plug and/or the cord are bad...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Dec 05, 2009 | Rowenta Perfect Iron
hello mam
Oct 02, 2009 | Irons
Rowenta precision iron DM 561 will not heat up
Most irons for which you pay more than $10 (like this nice Rowenta) will have a replaceable heating element. The problem seems to be to try to find where you can get the heating element. My best bet would be for you to contact a Rowenta service center (see listing at http://tinyurl.com/danr9x). They should be able to tell you where you can get the heating element.
Before you go that route, I am assuming you already plugged the iron directly into the outlet in the wall (not in the surge strip)? Wouldn't be the first time a single outlet of a power strip goes bad.
Good Luck,
Mar 14, 2009 | Rowenta DX6700 Iron
Feb 13, 2009 | Irons
Shark G1490 doesn't light up or heat up when I plug it in.
Jan 12, 2009 | Euro-Pro Shark GI490 Iron
Why isn't my Iron heating up? Just finished filling my Krups V65 iron with water. Was ironing linen shirt on linen setting, all of a sudden, heat dropped all the way down to light one (very low heat) and...
Good Luck
Jun 12, 2008 | Irons
I have the same problem with my black and decker iron. I will not buy orrecommend this iron to anyone.
Aug 09, 2007 | Sunbeam Safety Glide 3891 Iron
Black & Decker D2030 Iron Logo
151 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
