Question about Hotpoint RB757 Electric Kitchen Range
Timer buzzer The timer buzzer is making a squealing or light beeping noise constantly unless you unplug range. I would like to know which color or wire I can just unplug to make it stop. We do not use the timer anyway so would like to just unplug it
  • atrst Feb 07, 2009
    In the middle of the night the timer buzzer just came on, I have not been able to turn it off, reset it or just make it stop. I have to turn the stove off at the breaker to make it ******* it is annoying. How can I just disable it? RB754
I found the wire that stopped the ticking but it was also the power to the control panel. When I plugged it back in it started ticking again.
Posted on Jul 21, 2008
I took the top of range apart to see if I could unplug the buzzer. Wasn't sure which wire it was so I just unplugged the bottom four wires one at a time.....don't really know what it did but it stopped buzzing and all the wires are plugged back in. Only thing I can think of it must have re-set something cause it works fine now
Posted on Apr 24, 2008
The dryer buzzer keeps going off even when dryer is off
When the dryer stops can you advance the timer a little to turn off buzzer? Or when you open the door does the buzzer stop? I was trying to find a schematic for that model but I have had no luck. Power should come from the timer to the buzzer. If you know how to read a schematic. Unplug the unit and remove the back to the control panel. Check to make sure that all the wires to the timer are on the right connections. You may need an appliance repair service from your area to come out and diagnose it for you.
Apr 02, 2013 | Frigidaire Westinghouse Electrolux...
Danfoss 103 timer is making a constant buzzing noise!!...everything's works fine but I want to stop this buzzing noise. Any actions I should take or advice would be much appreciated. Thanks.
How much wattage is going through the timer and what is its rated load max? try unplugging whatever is plugged into it and see if it stops but if you exceeded the max load might be damage to the internals which can cause that buzz.
Feb 05, 2013 | Hardware & Accessories
My Intermatic T103 Indoor 120-Volt 40-amp timer emits a constant peeping sound
Intermatic T103 is mechanical timer with moving gears.
Timer makes audible sound when tripper clicks on-off, but it should not make constant noise unless gears are causing noise.
Turn off power and spray WD-40 on gears and see if problem continues.
WD-40 vapor is extremely flammable hydrocarbon when sprayed, and should not be sprayed on live electric circuits.
If problem continues, turn off power, pull mechanism out and spray WD-40 on plastic gears of clock motor.
Open following links for illustrations of clock motor and removing mechanism.
http://waterheatertimer.org/images/WH40-005-gears-350.jpg
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Aug 12, 2011 | Intermatic T103 Indoor 120-Volt 40-amp...
I have an older stove and the kitchen timer buzzer keeps going off...at random times...i have never actually used the timer
un plug stove, pull cover off . if you dont use it unplug the timer wire put wire nut on it. and call it a day.
Apr 11, 2010 | Kitchen Ranges
Buttons/timer don't make sound
Unplug the range.
Remove the control panel to access the touchpad and electronic control.
Remove the touchpad ribbon from the control inspect for and clean any corrosion and reinsert it.
If this fails, replace the touchpad.
Feb 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Tappan Range 560S111PO1 Timer buzzer won't turn off
You have to set the timer alarm just right on the 12 'o clock position or .........................BZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
Jun 12, 2008 | Tappan TGF363 Gas Kitchen Range
Constant beeping from the clock/timer
sound as if u got water in your controls which would cause the electronic clock assembly to short. unplug for 24 hrs to allow it to dry if the probelm coming back it eca is bad
Jun 01, 2008 | Tappan TGF320 Gas Kitchen Range
SQUEALING NOISE AND SET TURNING OFF
The squealing noise is a defective color wheel. When the color wheel does not get up to speed (or stay up to speed) the set will shut down with the blinking you describe. You need to replace your color wheel or have a tv shop replace your color wheel.
Josh
Mar 04, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Whirlpool super capacity 465 timer won't beep
clock timer and motot for a black electric oven 220Volt. oven number on plate at bottom of door is these two RGE 1600 P 5.8 and MK 93877451 4.4
rge
Jan 12, 2008 | Whirlpool GBS307PR Electric Single Oven
BEEPING OVEN
The F1 and constant beeping is an error code indicating that your electronic control board (clock/timer) is defective. The fault cannot be reset and the control board must be replaced. This can be an expensive repair if your range is no longer covered by a warranty or service plan. The cost to buy a new control board can be in the neighborhood of about $200. Sorry...but I do hope this helps you.
May 01, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Hotpoint RB757 Electric Kitchen Range Logo
420 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
