Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
DLP picture problem
How i can test the HP Pavillion DLP TV lamp L2114A
  • Mitsubishi Master
  • 8,617 Answers
No way to test it other than install it in a known working set unfortunately. What seems to be your problem with the mitsubishi?
Posted on Apr 22, 2008
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
The picture is not bright in a light-filled room. Will a change of DLP lamp help? Are there different lamps that will improve picture quality?
Yes.Depend how old is ur DLP tv,the Projection Lamp only a light source,mostly depended on the Light projection Engine itself.Get the original RCA DLP lamp or same lamp model now inside the tv,will help and work best for ur tv.Just don't get generic DLP tvs lamp,it cheaper poorer quality.
Dec 17, 2010 | RCA HD61LPW167 61" HDTV
Hp pavillion televisions' blue light blinking and wont turn on. no sound or picture just turned off and wont turn on
CK your Fans if they stop running set will shut off other wise replace the Lamp call fox 1-800-227-5369
make sure your Lamp Fan is OK if you need Fan call Encompasss Parts 1-800-638-3328
Dec 21, 2009 | HP Pavilion MD5020N 50" DLP HDTV
Blue power light keeps flashing, but the tv won't turn on
Same thing just happened to mine. I think these replacement lamps (L2114A) are nearly impossible to find. They are no longer available through HP and I've ben unable to locate one through a reseller.
Oct 31, 2009 | HP Md5880n 58 in. HDTV
My Samsung DLP hln567w tv has NO picture on all
If the Lamp ignites and stays lit, but screen is completely black, not even the on screen display, then it is likely a bad DMD board.
If the lamp ignites and then turns off after a couple seconds then it is likely the color wheel is seized.
If the lamp never fires, but the TV clicks a bunch of times, then it could be a bad Ballast or the Lamp itself.
Sep 18, 2009 | Samsung DLP HL-P5663W 56" TV
Test
Ballast Lamp provide back light in DLP TV and if its bad / broken TV wont power up. If lamp is weak, dark or less bright picture will come in screen. Color wheel is responsible for colors in picture and if its broke, TV wont power up and common problem with color wheel is high pitch noise while it spins.
Jun 12, 2009 | Sharp 65DR650 65" Rear Projection...
Samsung DLP HLM-617W/XAA
with lamp out (door closed) the ballast should "strike" or give an arc sound, trying to fire the lamp. If it does not do that maybe the color wheel is not spinning up - has to do that first.........then the set will try to fire the lamp
Jul 18, 2008 | Samsung DLP HL-P5663W 56" TV
Hewitt Packard high definition DLP tv Product #EX543AA#ABA need part, hp no longer carries them.
I have a brand new L2114a lamp for sale. I paid 299 plus shipping on ebay but it turned out to be the wrong one (despite what the manual says). I ordered the correct one I needed from HP. I am willing to part with it for 200. I can send pictures of the lamp and the box and the reciept. This is a BRAND NEW LAMP.
This lamp works in the following televisions and replaces the lamps listed below:
HP Pavilion md5020n 50-inch High Definition DLP TV L1735A
HP Pavilion md5820n 58-inch High Definition DLP TV L1736A
HP Pavilion md6580n 65-inch High Definition DLP TV L1737A
HP Pavilion md5880n 58-inch High Definition DLP TV L1798A
Jan 28, 2008 | Televison & Video
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
