Question about Hitachi P42H401 42 in. Plasma HDTV
Closed captioning I can't seem to remove the closed captioning from my screen. It says 'off' in the settings, and I even tried to reset to factory settings. When the set is turned off (or even in standby mode) then on, the closed captioning is set to 'auto'. It just won't go away! Can anyone help??
I called the cable company and they guided me through changing the menu on the cable box...seems that even if your tv is set up right, your cable box can change the settings automatically.
Posted on Nov 10, 2013
I experienced the same problem for about an hour before recognizing that the "continuous on" closed captioning had been activated on my cable box, not the TV. The signal feeds through despite the CC settings on the TV. If you haven't already, try checking the CC settings on whatever device is supplying your video.
Posted on Oct 12, 2008
  • Kellie Seed
    Kellie Seed Nov 10, 2013
    THANKYOU!!! I called the cable company and they fixed it!! The digital audio drives you nuts if you're not used it.....
Cannot remove closed caption option. when i go to
try to reset factory setting and after unplug from the wall and wait 2 min until theres no more power at all and plug it back it should work
Dec 23, 2009 | Insignia Televison & Video
Closed caption will not turn off in any menu options.
Leave it off unplugged from the mains overnight. This should reset the TV to factory settings removing the closed caption problem.
If this fails you should be able to find factory reset in the set up menu.
Jul 27, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
I have a black rectangle covering the center of the screen from top to bottom. How do I get rid of it? I tried the menu for Closed Captioning but it did not seem to work.
Try turning off the closed caption and text also check v chip, if you have a channel or channels blocked it could cause a black rectangle to pull up on the screen, if that doesn't work try resetting the unit to factory settings
Jun 16, 2009 | Toshiba 50HP66 50 in. Plasma Television
How to remove closed caption from JVC TV without original remote
how can i get rid of the closed caption on my magnavox tv without the original remote
Mar 19, 2009 | JVC C-20810 TV
Unable to remove the closed caption through the remote control (Haier) 42 inch flat screen tv. Went through the function and selected 'No' to Closed Caption, but it does not remove it. Thanks, Sandy
I dont know what model you have i see two on there website. i read manual for one of the 42 inch lcd tvs and i do see where you confirmed you said off to closed caption mode am i correct? Ok try this turn the closed caption on and exit menu. now shut off tv and turn it back on. now go into menu and turn closed caption mode to off now and exit menu and see if that helps. ok i hope this helps ....oh i forgot to mention make sure that you didnt enable the closed captioning on your cable box remote. Just might want to check with that. It might not be your tv at all it could be the cable boxes closed captioning service. I hope some of this helps if not see if there is a factory reset in the menu.
Feb 20, 2009 | Haier Televison & Video
A black box sometimes appears on my tv screen. can you tell me if this is from having the closed caption butten on and why it happens?
Yes, if the closed caption mode is turned on in 'text mode' the set will display a black box even when no closed caption text is available. the normal closed caption mode is cc1. try turning closed caption to cc1 or off. tech7
Jan 04, 2009 | Televison & Video
Viewsonic n3251w will no longer display Closed Captions
You can reset your viewsonic remote control by removing the batteries, and holding the power button down for 10 seconds. Just 10 minutes ago I repaired my remote, which was doing absolutely nothing, not even turning the set off and on, Called Viewsonic, they told me this, and it worked ! Yay !
Dec 11, 2008 | ViewSonic N3251w 32 in. LCD HDTV
Closed caption
maybe in cable box setup?
May 27, 2008 | Samsung DLP HL-P5663W 56" TV
Can't shut off closed caption
I have the JVC I Art 46" TV. The Close Caption was turn on accidentally by my grandson. After lots of searching for the original remote. I called JVC Customer Support. He told me to change the Close Caption settings to CC2 and T1. That fixed the CC without having the original remote.
Apr 10, 2007 | JVC AV-32F704 32" TV
Hitachi P42H401 42 in. Plasma HDTV Logo
194 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
