Question about Vacuums
Received hoover powermax fusion vac today and the handle will not go down as indicated in diagram.
    President:
  • 1,673 Answers
What is your model number? A Savvy and Powermax are differntent models. The Savvy the handle slides on and there are 4 screws to hold it in place. The Powermax has 2 screws to hold it in place. have you removed them before trying to put the handle on. If you have, you just have to work so it will slide down then put in the screws to secure it.
Posted on Apr 24, 2008
Install upper control rod
Hi, it's Jeremy from Crucial Vacuum.
To attach the upper handle to your Hoover Steam Vac remove the clean solution tank (upper tank) from the deep cleaner. Then, attach the upper handle to the lower handle by pushing the upper handle down onto lower one. Use the provided bolts to secure the handles. Push the bolts into the accompanying holes on the front of handle. If the bolts do not go through the holes easily, your handle is not pushed completely down. When the handle sections are completely together, squeeze the trigger on the upper handle to snap the trigger rod into place.
If you require further help with your assembly, you can find a step-by-step manual at: http://www.searspartsdirect.com/partsdirect/user-manuals/f5865900-hoover-parts-steam+vac-manual
You can also purchase all of your Hoover Steam Vac replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover+steam+vac
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 10, 2014 | Vacuums
I have one of these types how do you put the handle down
At the base of the handle there is a button push it and the handle at the same time
May 23, 2011 | Hoover Fusion Plus Cyclonic Upright Vacuum...
The air flow indicator on my hoover elite rewind bagless vacuum shows mostly yellow. we have followed all the directions in the manual - empty dirt cup, cleaned filter, checked two locations for blockage,...
Hi, sounds like you may have a small leak in the vacuum body. After changing the filter etc. turn machine on and run your hands alond vac. body. If there is a leak you will feel or hear it. If leak is found the light should change when you cover it. I hope this helps you./ Its hard to give advice without seeing it. Give it a try then let me know how you are doing. Chris
Feb 09, 2011 | Hoover U5507900 Elite Rewind Bagless...
How to replace Hoover PowerMAX power nozzle cord?
You can get the new cord at your local vac shop or you can take the power nozzle to the shop and have it repaired
Apr 27, 2017 | Hoover Powermax S3601 Bagged Canister...
HOW TO REPLACE BRUSH BELT ON A HOOVER POWERMAXll VAC. DWSMITH1624@AOL.COM
bottom of vacum theirs clips un latch them it comes off then remove the brush upward then switch belts
Mar 25, 2010 | Hoover Powermax S3601 Bagged Canister...
Vacuum will not pick up dirt. plate in hose stays shut. It has a spring that goes to the plate assemily but will not open. What make it open and close. U6616-900 Hoover Vac Alex
Sounds like you have a valve arm not operating properly. The valve door sould spring open when you lower the handle and will shut when the handle is raised and pushes down on the rear valve arm. See a parts diagram and look at parts 39-41 and 19.
Feb 09, 2010 | Hoover U6616-900 WindTunnel Bagless...
Hoover powermax s3530 spitting out dust
recently had same issue with friends. remove the filter and see the other thin filter there that goes to your motor compartment.. remove that and clean it. also check inside your tubes make sure not partially clogged.
Apr 17, 2009 | Hoover Powermax S3530 Bagged Canister...
I can't seem to find the direction guide for my Hoover F6213-900 Steam Vac PowerMax TurboPOWER
It's on the Hoover website, I just looked it up.
www.hoover.com F6213900
Let me know if you need anything else.
Feb 01, 2009 | Hoover F6213-900 SteamVac Agility...
Does the Hoover Fusion plus vacumn have a reset button
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=628595
Generic problem for all Vacuums
Posted by bfranklin on May 28, 2008
Does the Hoover Fusion plus vacuum have a reset button
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I did a search on the Hoover Fusion and to the best of my knowledge the Hoover Fusion does not have a reset button and it would be my suggestion is that to call the Hover Factory phone # listed below to see if they can answer your question as I could not find the model # for the item you are requesting. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 28, 2008 | Vacuums
HOOVER STEAM VAC SPIN SCRUB
Cannot hook the upholstery cleaner into slot..lost manual in fire
Jun 16, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
51 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
