Question about JVC AV-32260 32" TV
No picture Hi my jvc 32" color TV av32260g is out. when turn on power LED comes on and there is audio but no picture, when turn off power center of picture lights on and off quikly. have check all dc levels out of power supply check OK. please HELP. Thanks a bunch Roberto
  • 71 Answers
Try resoldering vertical output ic pins, no vertical deflection will shut off picture. may need ic replacing along with electrolytic cap.
Posted on Apr 27, 2008
Lcd tv has sound but no picture, checked the inverter board and light is coming on the screen but no image
1. Symptom: Powers up, relay clicks, LED turns green, backlight comes on but there's no display from any input, and no OSD.
Solution: On the T-Con board labeled 320WTC2LV3.7, stickered J01420PE7F0288, check/replace:
F1 = 2A, 35V SMD (measured 9 Megaohms in circuit) - OK!
Dec 27, 2013 | JVC LT-32E488 32 in. LCD Television
Jvc pd-35s5oj no picture
1) test the power for audio for +24 Vdc
2) IF there are test the following a) color sync b) color osc c) color i-f d)color demo e) amp video color.
see the block diagram
God bless you
Sep 22, 2012 | JVC AV-32S585S 32" TV
Our 32'' JVC TV model # AV-32030 has an obscured picture.
With the remote go to the Closed Caption menu and make sure it is turned off.
Let me know if this helps
Lone99star
Apr 03, 2009 | JVC AV-32020 32" TV
JVC LT 42x688 no picture just sound
Sorry, this has no easy fix. The good news is you do not need an LCD Panel. The bad news is the Video Processor has a problem.
This TV has x3 Boards. The one you should replace first is the one in the middle. If this doesn't fix it, try the one on the right. The Part #s are on the Boards if you wanna try ebay.
Dec 22, 2008 | JVC LT-40X776 40 in. LCD HDTV
Lost Picture
try tapping tv on side with palm and see if it works it might be a bad video chip
Oct 19, 2008 | JVC AV-32432 32" TV
JVC AV32260G COLOR TV
try resoldering vertical ic pins
Apr 19, 2008 | JVC AV-32260 32" TV
TV wont power on, clicking noise and flashing standby led
Sounds pretty bad to me, I had a computer monitor that did a similar thing when plugged in after blowing, it's not a good thing. I didn't even bother to mess with it. You may have to replace the whole power board or at least have a whole handful of pieces to re-solder. It most likely isn't worth it unless your other tv's are under 30" and you don't have a lot of money ;)
- Dave
Dec 28, 2007 | JVC AV-32D305 32" TV
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Sep 24, 2007 | JVC AV-32D305 32" TV
JVC AV-32730 36" picture problem..
From what you describe, a solder joint has probably cracked loose in a power supply or deflection circuit, which is quite common. Since you do sometimes see a good picture, all of your major components are fine. Repairing cracked solder joints is a very easy procedure and definately worth fixing on a 32 inch TV. The first 2 digits of the model number indicate the size of the TV.
Aug 04, 2007 | JVC AV-32D305 32" TV
JVC AV-32260 32" TV Logo
127 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
