I have a M:USBST2GB thumb drive that is not recognised on the Windows 98 Computer I need to transfer some files to. I have other thumb drives but they do not have the capacity to do the job. I have always had to down load drivers for them on this computer.
    Guru:
  • 1,342 Answers
I am trying to get some photos off an old computer running Windows 98. I have no CD burner only a couple of USB slots in the back. However when I put a USB Key in the back it does not recognise the key. I...
Ok the file system on windows 98 is called FAT, the file system on newer cmputers is called NTFS, It is forward compatibility but not backword. You need to put in a USB flash Drive also called a thumb drive or stick drive into the win98 machine and check for harware changes using these suggestion.
1. insert the flash drive into usb port
2. right click on "My Computer" > Manage - The Computer Management window popsup.
3. Select Disk Management
4. Locate your Flash Drive at the bottom where it starts with "Disk 0" which is your Hard Drive.
5. Your Flash Drive should say something like "Disk 1, removable", to the right it should have a blue line which means it's a primary partition.
6. If it has a Black line, then it means that the Flash Drive has not been partitioned. To fix this do this:
7. Right click on the black line. It should give you an option to partion it.
8. Go ahead and partition it to FAT or NTFS which ever option you can get or want.
9. Once it is finished, then you will be able to read and write from the Flash Drive.
Let me know if it does not work or if you are having problems.
Jan 01, 2011 | Computers & Internet
What is the best way to transfer data from my old computer to this one?
The most popular way to transfer files is to burn them to a cd. For this you would need a cd burner and a couple of blank cds. Not only are you moving the files but by burning them to a cd, you are also archiving them. You'll be thankful that you did when something goes wrong with your computer. If you have a cd burner that is compatible with cd-rw media, then you would be able to just use one cd to transfer. A cd-rw disk offers the option to erase the cd and then rewrite something else to it. Depending on the speed of your cd burner, this could be a quick or a timely process. It may be very repetitive if you have a lot of data to transfer An excellent way to transfer a couple of files from computer to computer is to transfer with a thumb drive. A thumb drive is a small hard drive that can hold anywhere between 16mb to 1 full gig. It is normally a plug and play device that you would plug into a USB port. It would show up as a removable drive in My Computer on Windows or if you a Mac user, it would show up on your desktop. If you have an older computer, you may have to install drivers for your USB ports or software for the device to be recognized. Please check your thumb drive manual for more information on the setup for different systems. If you're not afraid to open the computer up, you could just take your old hard drive and hook it up as a secondary or slave drive. This would allow you to transfer the files from hard drive to hard drive, within your computer. Before doing anything to your computer, please consult your computer manual
or an experienced computer professional . Never open your computer up while it is still plugged in.
Dec 16, 2010 | Dell OptiPlex GX280 PC Desktop
Seagate 9SF2A4-500 external hard drive on Windows 98
Windows 98 will not run a drive that large, so that is your problem. You will need to connect it to a newer system, and break it down into small drives by setting up different partitions. Perhaps it will see it then. Also, most manufacturers are no longer supporting Windows 98. You really need to just upgrade your system to a newer OS.
Feb 13, 2010 | Computers & Internet
Network Boot
hi,
i have dell c400 laptop, its to much simple to install xp
first you just take out hdd from laptop
plug in tht hdd in desktop pc by external usb box
now u just start windows 98 setup in it
when it started first format ur drive then install it
when windows 98 setup files copies to 100%. machine need to restart
u just plug out the hdd and plug in back to laptop
now the setup will remain start in ur laptop and when the installation complete u just upgrade ur windows from 98 to xp by intalling xp from external drive on OPERATING SYSTEM OF 98 WINDOWS
NOW WAT U SAY???
ITS TO MUCH SIMPLE just try once
Jan 29, 2009 | Dell Latitude C400 Notebook
PC does not recognize ML648B in USB Mode
Switch the Player to MTP Mode instead.
• The USB mode uses a file transfer class called the MSC (Mass Storage Class). This was developed as a way for files to be transferred onto an external drive such as a flash drive or an external hard drive.
• In this mode, your mp3 player will look and function like an external hard drive in that it will appear in My Computer as a separate drive. This transfer class is not very specific to the transfer of media files so the MTP (Media Transfer Protocol) was introduced.
• The difference with media files, specifically music files, is that they demand much more management.
• Downloading services can require special licensing and a limit on the number of playbacks a music file can have.
• The acquisition, restoration, updating, and backing up of these licenses as well as compatibility issues with file type and compression ratio within these digital music players demanded a more user-friendly and functional approach to file transfers.
• For this reason, you will need to have Windows Media Player 10 or 11 available on your computer to utilize MTP.
• Those with Windows Media Player 9 on their Windows 98 SE, Windows Millennium Edition, and Windows 2000 operating system will need to update using our Download Center.
• We recommend the use of MTP over MSC (the USB mode on your player) because it is more specific to the transfer of music files. To change this setting, press the power button on your device once it’s connected to the computer until the USB icon disappears.
Jan 27, 2009 | GPX ML648B MP3 Player
Cannot transfer any files from my computer to my external hard
Did you install the drivers for the drive? Is it recognised in Windows as a device? If not, try reconnecting and Windows should prompt you to install the drivers, Assuming the drive is recognised by WIndows, then are a few causes for not transferring data. I've attached a link to Western Digital's FAQ regarding Data Transfer problems with your drive....
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_alp.php?p_sid=nCt181pj&p_accessibility=0&p_redirect=&p_lva=1017&p_li=&p_page=1&p_new_search=1&p_search_type=answers.search_nl&p_sort_by=&p_search_text=transferring+data
Several page of possible solutions are listed above.... however, you can refine the search if it is only happening when running specific apps or @ specific times. The answer you seek is located in this link. If you can provide more details on the type of file(s) you are trying to transfer and how, I'll refine the solution for you....
Jan 14, 2009 | Western Digital 250GB MyBook External USB...
My GPX ML648B is not being recognized on any computer any longer
Jan 08, 2009 | GPX ML648B MP3 Player
No computer will recognize my player any longer and I don't know why. It did for months and now all of a sudden it will not. Please help!!!
Seagate Barracuda 7200.7 160GB
You don' t say what OS or even type of computer (PC, Mac, Windows XP, 98, vista etc) you are running, or whether the drive has been used before. If it's a new drive then it probably needs formatting, so you can allow the OS to do that. If it contains data that you need then DO NOT allow the OS to format it.
If you know it is formatted & contains data, then it sounds like the OS is not recognising the format. Windows 98 typically won't recognise NTFS disks formatted on Windows XP for example or Linux Ext3/4 format disks won't be recognised by Windows. In the latter case, you can download a free driver which will do that for you - google Ext 4 and Windows.
Aug 26, 2008 | Seagate Barracuda 7200.7 160GB 7200rpm...
Windows 98se to windows vista
you could put your files/documents and pictures on to disc and tranfer them this way plus you wil always have copies if you ever have problems tnis is what i do
thanks
Jan 05, 2008 | Microsoft Windows 98 for PC
Computers & Internet Logo
David Payne
David Payne
