The washer will not hold water it just keep running.
  • 101 Answers
The dump valve defective or stuck. check and replace. hop this will help you
Posted on Apr 22, 2008
Pressure washer won't start. It has gas, oil and I turned the switch to turtle and to rabbit position. Does it matter if water is on first or not? It won't start either way.
Turn the water on, hold trigger down and let water run thru the hose to prime the air out of the hose. If it still will not start check the spark plug and clean it or replace it. A bad spark plug will keep it from starting
Aug 22, 2011 | Briggs Stratton 020273 Elite Series...
Won't stay running
Pressure washer when you first try to start them that stop underload. We had the same type of problem with 11 hp Honda if you hold the trigger open the motor will be under less load we found by running the motor for about a minute it would work normally. Remember to make sure the water hose is turned on pull the trigger on, until water is coming out of the wand , now try and start the motor but also hold the trigger open, now you will not be building maximum pressure, after about a minute release the trigger and see if it keeps running.
Feb 19, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
My washer machine does not hold the water keeps draining
Here is a tip that I wrote about the problem you are having with your washing machine...
Water will not stay in Washing Machine
http://www.fixya.com/support/r4696322-water_will_not_stay_in_washing_machine
heatman101
May 07, 2010 | Admiral AAV7000A
I own a Troy-Bilt pressure washer, 2550 psi w/ a 6.75 hp motor. It will not keep pressure, I checked the water supply,hoses for kinks,tips for clogs and made sure the sun wasn't in my eyes. but it holds...
Mike, water supply is important. Make shure your running a 3/4" dia. supply hose to the pressure washer. The longer the supply hose is the less the water supply pressure is so keep as short as possible. Hopefully your hose hookup is running 3/4" pipe to it. It sounds like you've been diligent in checking everything. I hope this was helpful. Jeff
Apr 03, 2010 | Water Heaters
Water keeps filling up washer
u have a bad water valve. thats the plastic piece behind the washer that the hoses hook upto. part roughly 39.99-89.99 labor 75-125.00 depending on were u live and who u use. if you decide to do it yourself i would say a 5 on a scale of 1-10 . turn water supply off, remove both hose.turn off power remove top panel 2screws in back and push panel back and off. remo 2 screws that hold water valve in place. remove wires from pld valve too new one. reassemble . hope this helps.
Oct 07, 2009 | Kenmore Elite 45986 Front Load Washer
Will not release pressure and dies
Your unloader valve is not functioning. Take it apart and make sure it all the parts are able to move freely under the spring. You may need a new o-ring or two if you see damaged ones.
Aug 02, 2009 | Cam Spray 25006HT 2500 PSI Cold Water Gas...
Constant running of water
You need a new water inlet valve. this will fix it.
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
My kenmoe washer starts filling up with water but won't fill up. Water is just keeps running through but won't hold the water.
You drain hose must be higher than the tub. you can solve this with a standpipe or a siphon break kit.
Dec 31, 2008 | Kenmore 24032\24036 Top Load Washer
Water doesn't stop
you have a defective hot water inlet solenoid valve. you have to replace that part.
tnx 4 using fixya,
drcool
Oct 25, 2008 | Washing Machines
Water keeps running
missmelissa, sounds like you are siphoning. Lift the drain hose from the drain and see if it fills then. You need to have a air gap on the drain so you don't get the siphoning affect. Catriver..post back.
Feb 23, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
